Author Topic: I need help! :( [UPDATE!]  (Read 3053 times)
Offline kdiz
« on: Fri, 10 July 2015, 17:24:18 »
Hello everyone!
I'm writing this post with a hope and a shame.
I just broke a spacebar in my CM Storm Quickfire TK Cherry MX Red keyboard. ;_;
I can't find a replacement in the webs. I even wrote a letter to Cooler Master support with a question, if they can sell me one; need to wait for the response.
And here's my case with you guys. If CM won't sell me it, where can I buy one in the internet, because I know it's a special size spacebar (6,5 units, http://deskthority.net/wiki/Space_bar_dimensions#6.5_units_.28123mm_wide.2C_3_mounts.2C_52.25mm_apart.29) and it's really hard for me to find one.
I still got a guarantee for the keyboard, if it would help anyway. I really would love for someone to help me, because I don't want to buy new keyboard. :(
In advance, I'm sorry for my ignorance and placing this thread in the wrong subforum.
« Last Edit: Mon, 13 July 2015, 20:34:28 by kdiz »
Offline VinnyCordeiro
Re: I need help! :(
« Reply #1 on: Fri, 10 July 2015, 18:10:51 »
Offline kdiz
Re: I need help! :(
« Reply #2 on: Fri, 10 July 2015, 18:45:22 »
Thank You man!!!
You saved me. Also last question, so for my keyboard it would be DCS profile right?
Re: I need help! :(
« Reply #3 on: Fri, 10 July 2015, 19:07:49 »
I believe so. I just want to warn you that the DCS space bars available there are either red or blue plastic, I hope that doesn't bother you.
Offline Fullcream
Re: I need help! :(
« Reply #4 on: Fri, 10 July 2015, 19:15:47 »
If you haven't changed the key caps on your board then DCS profile will still fit and work but it might be a tad shorter and have a steeper angle than the standard bottom row of key caps.
Offline kdiz
Re: I need help! :(
« Reply #5 on: Fri, 10 July 2015, 20:25:29 »
So, then DSA profile would be more similar to the type Cooler Master uses?
Offline KatzenKinder
Re: I need help! :(
« Reply #6 on: Sat, 11 July 2015, 01:53:13 »
DSA is totally flat, so DCS is probably still closer than DSA would be.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: I need help! :(
« Reply #7 on: Sat, 11 July 2015, 02:22:52 »
In order:
OEM>DCS>Cherry
OEM is very tall, DCS is a mix between the 2 afaik, and then cherry is low profile cylindrical sculpted, and in my opinion, the best.
Re: I need help! :(
« Reply #8 on: Sat, 11 July 2015, 06:51:31 »
You're biggest problem will be finding a 6.5x space bar.  Most space bars are 6.25x.
Maybe grab a couple of DCS ones from SP/PMK just in case.
And keep them as spares if CM are able to provide replacements.
Offline kdiz
Re: I need help! :(
« Reply #9 on: Sat, 11 July 2015, 08:00:12 »
Thank You for help guys! I really appreciate it :)
Also, where can I buy those DCS spacebars for best price, because with shipping to my country, it's really expensive converting to our currency ;<
Offline kdiz
Re: I need help! :(
« Reply #10 on: Mon, 13 July 2015, 20:33:32 »
UPDATE:
Well, basically, does Cooler Master got one of the best customer services in the world? I'm a little flattered and I don't know if I really should take the key for free ;C
Also, what did he mean by RMA keyboards? :P
Cheers~
« Last Edit: Mon, 13 July 2015, 20:35:43 by kdiz »
Re: I need help! :( [UPDATE!]
« Reply #11 on: Mon, 13 July 2015, 20:39:53 »
UPDATE:
Cheers~
He means he will take the key off of a board someone else returned.
