Author Topic: RS84 version3 75% kit (Salvage Update)  (Read 150387 times)
Offline KHAANNN
Re: RS84 version3 75% kit
« Reply #50 on: Wed, 22 July 2015, 16:02:18 »
yum
is it programmable tho?
does tmk_keyboard support it for example?
Offline ys9527
« Reply #51 on: Wed, 22 July 2015, 17:21:07 »
I'm interested but what's the expected delivery date?
Offline Metr0
  • HHKB or nuttin
« Reply #52 on: Wed, 22 July 2015, 18:03:35 »
Is there any examples of the plate colours anywhere?
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline Invaderevan
« Reply #53 on: Wed, 22 July 2015, 20:48:13 »
yum
This.
Also, I am curious if anyone has used one of the previous versions on a mac?
« Last Edit: Wed, 22 July 2015, 21:12:52 by Invaderevan »
WTTF Ribbits, Ashen V2 MX, Bronins
Offline a-c
« Reply #54 on: Wed, 22 July 2015, 23:07:06 »
yum
This.
https://github.com/kairyu/tmk_keyboard_custom/tree/master/keyboard/RedScarfIII
and
https://geekhack.org/index.php?topic=69282.0
Hmmm. RS III and RS84 V3 seem to be different keyboards. The matrix is a different layout with a 10key incorporated.
In his other thread Ivan says it is running TMK based firmware: https://geekhack.org/index.php?topic=69064.msg1661983#msg1661983
Haven't found it anywhere yet.
« Last Edit: Wed, 22 July 2015, 23:29:03 by a-c »
Offline KHAANNN
« Reply #55 on: Thu, 23 July 2015, 03:07:29 »
yum
This.
+1
based on the information a-c provided tho, I'm guessing the answer to both of the questions is 99% yes
Offline rpeterclark
  • RPTR ❌
« Reply #56 on: Thu, 23 July 2015, 06:25:43 »
yum
This.
+1
If it's the same PCB as the previous RS84, then yes it's 100% programmable and is essentially the same as programming the RSIII. Between the RSIII flashing guide here https://geekhack.org/index.php?topic=69282.0 and the details that geniekid and digi worked out here https://geekhack.org/index.php?topic=69064.msg1799365#msg1799365 I was able to reflash it with a custom layout.
Offline Metr0
  • HHKB or nuttin
« Reply #57 on: Thu, 23 July 2015, 16:43:55 »
Would I need PCB mount stabs for this KB? And if so where would I be able to get them?  ;D
Offline KHAANNN
« Reply #58 on: Thu, 23 July 2015, 17:43:01 »
dunno, but imsto has pcb stabs
Offline Wannabe
  • Independent Adjudicator
« Reply #59 on: Thu, 23 July 2015, 17:56:01 »
Yea you need to get your own PCB mount stabs. GON and Winkeyless have sets for TKL boards that includes wire that should do the job. I found the stab parts number on the MX datasheet and found that Mouser has stabs in stock. They have a few wire sizes in stock but not 6.25x for spacebar so I just ordered an extra set of 2.5x stabs and am making my own wire.
I liek keyboards
Offline rpeterclark
  • RPTR ❌
« Reply #60 on: Thu, 23 July 2015, 18:06:32 »
Also SPRiT has them available as parts on this order form: https://geekhack.org/index.php?topic=60887.0
Offline KHAANNN
« Reply #61 on: Thu, 23 July 2015, 18:07:45 »
Plate-mount cherry stabs would theoretically work too?
But the ones from ortholinear was too thick for my taste for example, harvesting a wire from another keyboard is also a nice idea
Offline azhdar
  • Praise the AZERTY god
« Reply #62 on: Fri, 24 July 2015, 01:13:41 »
Plate mounted stabs will not work with this keyboard.
Azerty Propagandiste
Offline openmiceagle
« Reply #63 on: Fri, 24 July 2015, 01:40:37 »
Howdy guys.
I'm new to the keyboard community - recently ordered my first mech keyboard - but am interested in putting one together myself. This seems like a great deal. If any of you could give me some pointers and/or essentially hold my hand through the process it would be incredibly appreciated.
Thanks for the time!
Offline Metr0
  • HHKB or nuttin
« Reply #64 on: Fri, 24 July 2015, 05:29:20 »
Howdy guys.
Hi there, I've been in the scene a while and this is my first time building my own. This build actually comes with most parts pre soldered including the usb connector, underside RGB LEDs and the diodes. The only thing you need to get it up and running is to solder in the switches and any in switch LEDs that you want. Then program the keyboard with help from some of the links above me and there you have it :)
Offline Metr0
  • HHKB or nuttin
« Reply #65 on: Fri, 24 July 2015, 05:31:42 »
So PCB mounted stabs with the plate will work fine?
Offline unipsykal
  • ghostly lurker
« Reply #66 on: Fri, 24 July 2015, 05:49:17 »
Make sure you use PCB mount stabs with straight spacebar wire. The bent ones have a clearance issue with the plate.
Offline Metr0
  • HHKB or nuttin
« Reply #67 on: Fri, 24 July 2015, 06:37:59 »
Thanks for the help, is there any place where I would be able to order one of them? I ordered a set of PCB mount stabs from SPRiT last night, are they straight wired?
« Last Edit: Fri, 24 July 2015, 06:46:17 by Metr0 »
Offline azhdar
« Reply #68 on: Fri, 24 July 2015, 07:03:53 »
Sprit stabs should be straight.
Offline Metr0
  • HHKB or nuttin
« Reply #69 on: Fri, 24 July 2015, 07:17:48 »
They're the ones I have ordered :D
Offline Invaderevan
« Reply #70 on: Fri, 24 July 2015, 21:29:37 »
Im in! Cannot wait, I have really been wanting a lightweight 75%er
Offline coast9x72
« Reply #71 on: Fri, 24 July 2015, 22:30:38 »
im in
Offline Metr0
  • HHKB or nuttin
« Reply #72 on: Sat, 25 July 2015, 14:46:33 »
also in!
Offline Jixr
« Reply #73 on: Mon, 27 July 2015, 10:55:56 »
Anyone manage to get the programing for the fn layer with backlight settings to work?
I can't figure it out, the rs3 guide fn thing does not work for me.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #74 on: Mon, 27 July 2015, 11:15:57 »
We just went through all the programming funsies here:
« Last Edit: Mon, 27 July 2015, 15:07:08 by digi »
Offline Metr0
  • HHKB or nuttin
« Reply #75 on: Tue, 28 July 2015, 10:03:18 »
Hey Ivan, if everything sticks to schedule and order finish on August 10th what is the usual turn around time for a GB since this is my first one? I go away to University in mid September and was just wary.
Offline mozaiq
« Reply #76 on: Wed, 29 July 2015, 06:21:45 »
Now what am I going to sell in order to join this?
Offline arcvile
« Reply #77 on: Wed, 29 July 2015, 08:03:52 »
I hear human organs are a good place to start. Don't necessarily have to be your organs, perhaps a drifter with no diseases?
Offline unipsykal
  • ghostly lurker
« Reply #78 on: Wed, 29 July 2015, 12:19:19 »
Plasma is a realistic option.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #79 on: Thu, 30 July 2015, 13:20:29 »
It will probably be a month or few before I receive them. I can always update your shipping destination if needed.
Offline Unwise
« Reply #80 on: Tue, 04 August 2015, 10:58:05 »
Hi everyone,
New here. Just bought an rs 84 with gateron blacks (assembled by someone else from previous group buy) and am trying to determine what keycap set to purchase. Can anyone point me in the right direction? It seems that any std base + mod DSA set from signature plastics with two additional 1.5u should cover it. Is that correct? Anything else I should be aware off? Any help would be appreciated! Thanks!
Offline unipsykal
  • ghostly lurker
« Reply #81 on: Tue, 04 August 2015, 18:01:50 »
Hi everyone,
Make sure you have a 1.75 right shift as well.
« Reply #82 on: Wed, 05 August 2015, 08:17:27 »
I would reccomend the Gateron keycap sets. It has everything you would need for these in any possible layout build.
Offline Metr0
  • HHKB or nuttin
« Reply #83 on: Wed, 05 August 2015, 18:49:40 »
Would this include the "enjoy pbt" such as the dye sub red pbt ones?
Offline ika
« Reply #84 on: Fri, 07 August 2015, 23:45:03 »
Is there a Taobao listing for this version of RS84? I can only find the ones with the alu top bezel (which is also called v3?).
Offline beltet
« Reply #85 on: Sat, 08 August 2015, 18:48:40 »
Made my order now. Thanks Ivan!
EDIT: By the way, is there any other cases you can use with this? Can you use a MX Mini case for an example?
« Last Edit: Sat, 08 August 2015, 18:50:51 by beltet »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #86 on: Sat, 08 August 2015, 18:55:40 »
Last time I checked this thread, it said CONUS only. Now I come back and it's $175 shipped INTL.
****s sake. I can't afford that now I've committed to Dark R2, CMYK and Classic Beige... Sigh...
**** YOU I'VE ORDERED. GOING BROKE GOING BROKE. My bonus can't come any faster...
« Last Edit: Sat, 08 August 2015, 19:08:27 by katushkin »
Offline Glissant
« Reply #87 on: Sat, 08 August 2015, 20:01:17 »
Offline beltet
« Reply #88 on: Sun, 09 August 2015, 08:21:14 »
I'm really sorry. I need to cancel my order. How do I do that? I have double ordered with qtan. I thought he had missed my order but I got a message just after I placed the order at this GB. I'm deeply sorry for the inconivence...
Offline Ronnn
« Reply #89 on: Sun, 09 August 2015, 22:59:23 »
Hi Ivan, I placed an order yesterday and I haven't received invoice. Just want to double check if my form got submitted  successfully.
Offline Defect
« Reply #90 on: Mon, 10 August 2015, 08:11:03 »
I submitted but not have received invoice yet--dont want to miss out on this
Offline Glissant
« Reply #91 on: Mon, 10 August 2015, 09:49:03 »
Don't worry. You'll get the invoice.
Offline katushkin
  • Just the guy
« Reply #92 on: Mon, 10 August 2015, 09:52:08 »
****, can I add a plate to my order please Ivan? A black one?
Edit: I accidentally submitted another form. I didn't mean to D:
« Last Edit: Mon, 10 August 2015, 10:02:27 by katushkin »
Offline ys9527
« Reply #93 on: Mon, 10 August 2015, 10:29:11 »
Ordered, waiting on invoice.
Offline fliptrik
« Reply #94 on: Mon, 10 August 2015, 10:36:52 »
Ivan, I couldn't remember if I submitted my order already. I didn't receive an invoice so I'm going to assume I didn't. I submitted it again to be safe.
Offline ys9527
« Reply #95 on: Mon, 10 August 2015, 18:29:03 »
Just paid my invoice.
However, I am going to move at the end of this month. So do I just PM you about my new address?
Offline bladegesnow
« Reply #96 on: Mon, 10 August 2015, 20:51:07 »
I'm in. I see lots of last-minute orders xd
More and more and more...
Offline ika
« Reply #97 on: Mon, 10 August 2015, 21:24:25 »
Now I can't decide between this or a winkeyless combo... RS84 has a better looking case for sure, and everything would be soldered, but I'd have to source stabilizers somewhere, and at WKL I'd be able to get a numpad at the same time. Decisions...
Offline mbrown559
« Reply #98 on: Tue, 11 August 2015, 08:32:56 »
Does anyone know what kind of stabilizers to use with this guy? I ordered one awhile back and paid the invoice.
Does it use cherry stabilizers? (I did buy a plate if that matters)
Offline azhdar
« Reply #99 on: Tue, 11 August 2015, 08:34:54 »
you need Cherry pcb mounted stabilizers.
