Author Topic: 75% keyboard  (Read 11586 times)
Offline last100yen2
75% keyboard
« on: Thu, 16 July 2015, 09:37:36 »
I do not see many people with 75% keyboard, is there reason why?
Offline Jokrik
Re: 75% keyboard
« Reply #1 on: Thu, 16 July 2015, 09:43:40 »
I still in the look for the perfect aluminium 75% board
Think it would be awesome
Offline Jotokun
Re: 75% keyboard
« Reply #2 on: Thu, 16 July 2015, 12:09:52 »
1) Many of them use non-standard cap sizes. While there are exceptions and you can find ways to make many of them work you can't just throw any cap set on them. The column to the right will have an improper profile with most sets that aren't uniform.
2) Mechanical keyboards are a niche, and 100%/TKL/60% are the established sizes in that niche. Most looking for a smaller size will either go for a TKL or a 60%. As such, there's not much incentive to make a 75% which is probably why bigger companies (Ducky, Filco etc.) don't make them.
3) Almost all 75% boards use Cherry style switches. If you want something else like ALPS, BS, Topre... tough.
It's kind of a shame, IMO 75% is the perfect layout.
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline davkol
  •  Post Editing Timeout
Re: 75% keyboard
« Reply #3 on: Thu, 16 July 2015, 12:54:45 »
Almost every laptop without a numpad has a 75% keyboard. ~_^
Half of the existing mechanical keyboards with a 75% layout have Alps switches/mount (Matias Mini * Pro, Siig, Ortek).
Offline Jotokun
Re: 75% keyboard
« Reply #4 on: Thu, 16 July 2015, 13:26:45 »
The Matias Mini isn't a 75%. Same for the Leopold FC660C. Not sure what you would call them... 65%?
I had forgotten about the Siig and Ortek, I'll give you those. Still not many options compared to Cherry (Data911, Deck Ice, Keycool 84, Choc Mini, KBT Race, various customs). Supposedly Unicomp has a 75% in the works but I'll believe that one once it's actually out.
« Last Edit: Thu, 16 July 2015, 13:28:30 by Jotokun »
Offline davkol
Re: 75% keyboard
« Reply #5 on: Thu, 16 July 2015, 13:31:38 »
I don't see how Matias Mini * Pro aren't 75% keyboards. They have the alphanumeric section, a row of function keys, dedicated arrows and a half of the nav cluster.
Offline davkol
Re: 75% keyboard
« Reply #6 on: Thu, 16 July 2015, 13:38:48 »
…and speaking of options, I didn't mention KPT, Dauphin, Acer or SMK either.
BTW "Cherry style switch" is a confusing term. There's a sticky that requires calling MX-compatible switches "MX-compatible". Especially in this context, because Cherry themselves make a 75% keyboard (G84-4100), but with ML switches.
Offline quake4mhg
Re: 75% keyboard
« Reply #7 on: Thu, 16 July 2015, 15:09:10 »
 Most people don't need function keys on the go? But I need them both when game/work.
And my Vortex Race1 with me work on location this weekend, like any other days :D
Offline Jotokun
Re: 75% keyboard
« Reply #8 on: Fri, 17 July 2015, 12:17:24 »
75% keyboards are supposed to have all of the nav cluster. If you need to use a function layer to get any of Insert/Delete/Home/Page Up/Page Down/End, it's not a 75%.
Offline Wannabe
  • Independent Adjudicator
Re: 75% keyboard
« Reply #9 on: Fri, 17 July 2015, 12:41:51 »
75% is by far my favorite size. Got a Keycool 84, Noppoo Choc Mini, TG3 BL82, and a Neutrino (though that's technically a 65% I think). I'm getting a Red Scarf in the next Group Buy too. The only thing that bothers me is the nonstandard keycap sizing so I can't use off the shelf keycap sets, but with the amount of custom sets and Group Buys that are occurring, most of them offering tsangen options it's not really an issue. To me the 75% is the perfect compromise between the smaller form factor and comfort of a 60% and wanting to keep dedicated arrow keys and not having to use a fn layer.
I liek keyboards
Offline davkol
Re: 75% keyboard
« Reply #10 on: Fri, 17 July 2015, 14:17:30 »
Except you're wrong.
You're listing Noppoo Choc Mini, Keycool 84 and KBT Race as 75 %. Neither has a dedicated Insert key.
The TG3/Deck keyboard has Insert and Delete instead of right Alt and Control.
Offline Jotokun
Re: 75% keyboard
« Reply #11 on: Fri, 17 July 2015, 14:43:33 »
It is a relatively non-standardized size and there is variation. They're still better choices for those who don't want to rely on a function modifier than the Matias because they're only missing one key instead of four. Right Ctrl isn't explicitly used by much (Only Virtualbox comes to mind, and then only for guests without driver support) so it seems like nitpicking to count it as a missing key. You could always remap something else to insert, such as the break key on the Keycool. Not an ideal solution, but physically it works.
By your logic, anything with more keys than a 60% yet physically smaller than a TKL is a 75%. Just as a JD40 must be a 60% because it doesn't have the nav block or arrow keys and uses function keys to get more functionality. Yet, I somehow think at least some used to a 60% would have a hard time using a JD40 which is often refered to as 40%. Same thing here, most looking for a 75% would not consider the Matias because it's missing too many keys.
« Last Edit: Fri, 17 July 2015, 14:54:59 by Jotokun »
Offline davkol
Re: 75% keyboard
« Reply #12 on: Fri, 17 July 2015, 15:01:50 »
Ugh.
Matias Mini keyboards have *three* keys from the sixkey.
AltGr is necessary to type in plenty of national layouts. Right Control is useful to alternate hands without cramping the left pinkie.
…and apart from being wrong, be so kind and don't put ridiculous BS into my mouth. Most of these layouts are relatively well defined.
~40% … alphanumeric section - number row
60% … alphanumeric section
~65% … alphanumeric section + arrows and something
70% … alphanumeric section + function keys
75% … alphanumeric section + function keys + arrows and something (without the Model M spacing in navigation section)
Offline KRKS
  • Your friendly neighbourhood umbrella
Re: 75% keyboard
« Reply #13 on: Fri, 17 July 2015, 15:20:33 »
Define "something"
There is no standardization in 75%. And that's a good thing, maybe someone will dare to use a spacebar that *gasp* isn't standard but actually fits nicely and allows for properly sized six or seven mods beside it, like 6u(1.25|1|1.25 both sides) or 4u(1.5|1.5|1.5 both sides or 1.5|1|1.5|4|1.5|1|1|1.5)
« Last Edit: Fri, 17 July 2015, 15:24:50 by KRKS »
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline Jotokun
Re: 75% keyboard
« Reply #14 on: Fri, 17 July 2015, 17:06:27 »
Ugh.
So I got a detail on a keyboard I don't own wrong. Still doesn't invalidate my point that it doesn't fit the demographic 75% keyboards are meant to fill. You're missing the forest for the trees if that's all you got out of my post.
I agree about right Alt and never said it wasn't important. There aren't many 75% ISO boards, this could be part of why.
I fail to see how I was putting "ridiculous BS into [your] mouth". I was just trying to draw a comparison that I hoped would show you why I don't consider it a 75% board, I never said you were confusing 40% and 60%. Even Matias himself sees that it doesn't fit everyone's use case which is why he put together his own "60%" (his classification choice, not mine) with a different set of keys from that nav cluster.
The only layout I said wasn't well defined was 75%, and that one is true, almost all 75% on the market have slightly different layouts. What they have in common is that they have as many of a TKL's keys as they can fit into as small a space as possible. The Matias doesn't fit this description.
Whatever the case, I give up. You clearly expect something different out of a 75% than I do. Let's just agree to disagree.
I guess this does add to OP's answer though. You cant have many people owning a style of board if you can't agree what that style actually is.
Offline davkol
Re: 75% keyboard
« Reply #15 on: Fri, 17 July 2015, 17:19:54 »
Congratulations, you've just defined the 75% layout as it's commonly understood.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: 75% keyboard
« Reply #16 on: Sat, 18 July 2015, 14:11:02 »
Don't like the odd concessions on available off the shelf production models? Maybe a kit board like the RS84 is for you?
