Author Topic: A little help with switches  (Read 2250 times)
Offline trenzafeeds
  • **** off
« on: Mon, 20 July 2015, 11:55:47 »
Because it doesn't say anywhere, I'm just wondering, are these Gaterons pcb mount or plate mount?
« Last Edit: Mon, 20 July 2015, 12:18:35 by user 18 »
demik will never leave.
Unless he gets banned.
Offline user 18
Re: A little help with switches
« Reply #1 on: Mon, 20 July 2015, 11:58:45 »
Review on the page lists them as plate mount, as does a customer question. Also, your link is a little bit broken.
Avatar by ashdenej
« Reply #2 on: Mon, 20 July 2015, 11:58:53 »
Your link doesn't work but AFAIK, Gaterons only come in PCB mount.
Offline trenzafeeds
  • **** off
« Reply #3 on: Mon, 20 July 2015, 12:09:38 »
Yeah, sorry about the link, won't fix for me for some reason. Is there any good place to buy a bunch of PCB mount Gaterons?
« Reply #4 on: Mon, 20 July 2015, 12:12:29 »
Classifieds or wait for another buy from Massdrop/Geekhack. Not sure if anyone is carrying them yet. Could check MK.com too.
See below :)
« Last Edit: Mon, 20 July 2015, 12:15:18 by CPTBadAss »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Mon, 20 July 2015, 12:13:47 »
mk.com and zealpc are the only vendors carrying them right now
Offline user 18
« Reply #6 on: Mon, 20 July 2015, 12:18:59 »
Fixed it for you :thumb:
Avatar by ashdenej
