Author Topic: Steel vs aluminum vs acrylic plate  (Read 6496 times)
Offline asgeirtj
« on: Sat, 25 July 2015, 05:05:29 »
I've seen some discussions about which plate is best.  What do you guys think is the best plate?  I personally really dislike pcb mount, will that mean that I'd like the hardest plate (steel) the best?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline azhdar
  • Praise the AZERTY god
Re: Steel vs aluminum vs acrylic plate
« Reply #1 on: Sat, 25 July 2015, 05:16:41 »
I don't know what would be the difference between Steel and Alu, is suppose more solid on the Steel part.
Apparently acrylic comes close to pcb mount, you still feel the flex that pcb mount provide, but with some support from the plate.
Azerty Propagandiste
Offline Leslieann
« Reply #2 on: Sat, 25 July 2015, 05:28:37 »
I haven't used aluminum, but steel has at least one advantage, weight. I prefer a keyboard with some heft, it doesn't slide around as much, and feels more solid. In theory, given equal thickness, steel should also be the stiffest.
Acrylic is fine for experimentation, but really, I think it needs some support to be stiff enough unless it's been milled from a thicker plate.
Everyone has their preferred amount of flex.
Me? I stuck a stainless steel plate inside a thick (and heavy) aluminum case.  :))
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Snarfangel
« Reply #3 on: Sat, 25 July 2015, 09:24:34 »
I wish I could get this plate in steel or aluminum for a reasonable price...
Add Cherry MX Reds and a rubber sheet like they have on a Data911
106502-0
And voilą! Heavy-duty Toprefied Maltron.  :))
