Author Topic: [IC] GMK SKIDATA+ (GB IS LIVE)  (Read 1594695 times)
Offline heedpantsnow
  • Old enough to know better
Re: [IC] GMK SKIDATA+
« Reply #50 on: Sun, 02 August 2015, 11:34:51 »
Not sure what does this mean... You mean 60% non standard bottom row?
Hmm, might be interested if there's 60% support.
Hello sir what I meant is most of the 60s that I know about use 1.25x bottom rows with one of them usually a Fn (in place of the menu key typically). So adding a 1.25 blank or Fn or some logo or something would support all of those boards.
This will be covered, as Fn is already included in the HHKB support keys.
Cool.
I'm back.
Offline mbrown559
« Reply #51 on: Sun, 02 August 2015, 17:57:03 »
Def interested in more GMK goodness and love the black/orange scheme.
« Reply #52 on: Sun, 02 August 2015, 18:58:48 »
I'm intredasted in a set.
Offline shimmy1996
« Reply #53 on: Sun, 02 August 2015, 19:04:27 »
Definitely interested  :p
Offline mason
  • have fun with her, ryan
« Reply #54 on: Sun, 02 August 2015, 19:27:05 »
I'm interested  :D
Offline Giorgio
« Reply #55 on: Sun, 02 August 2015, 19:32:09 »
At this moment the geekhack logo is skidata. This is brainwashing!
« Last Edit: Sun, 02 August 2015, 19:33:59 by Giorgio »
Offline zhihuichan
  • Click,click,click
« Reply #56 on: Mon, 03 August 2015, 01:02:17 »
Supporting 1800 and 75%? I'm in!
Offline Oobly
« Reply #57 on: Mon, 03 August 2015, 07:31:16 »
Any chance for an inverse alphas pack (Grey on Orange alphas, like an inverse Nostalgia set)?
I really like the colourway on this, but would like more separation of the alphanumeric and mods areas.
I also support KHAANNN's suggestion for an extra pair of homing keys with bumps instead of scoops.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline trenzafeeds
  • **** off
« Reply #58 on: Mon, 03 August 2015, 07:55:49 »
As do I. I would most likely only buy if we had a bump homing option.
demik will never leave.
Unless he gets banned.
« Reply #59 on: Mon, 03 August 2015, 08:08:27 »
Seriously, this. How do people type with scoops instead of bumps?
Offline KHAANNN
« Reply #60 on: Mon, 03 August 2015, 08:22:48 »
good, good, good, our future is bumpy :)
bumped keys also look better than the scoops
Offline swimmingbird
  • keyset hoarder
« Reply #61 on: Mon, 03 August 2015, 08:32:47 »
KHAAAAAAAAAN!
I still want the scoops!
Offline KHAANNN
« Reply #62 on: Mon, 03 August 2015, 08:52:05 »
KHAAAAAAAAAN!
I will send you a pair of dolch flats :)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #63 on: Mon, 03 August 2015, 09:30:24 »
I vote lines over bumps for alternate homing.
Offline trenzafeeds
  • **** off
« Reply #64 on: Mon, 03 August 2015, 09:32:13 »
Ok, if people are asking for lines then I'll happily jump on the line train!
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #65 on: Mon, 03 August 2015, 09:35:48 »
Gateron has the best idea, scoops + lines, but after that I like scoops the most, then lines, then bumps. I still want scoops to be in there, because that is what the OG set has, but if there has to be an alternate, I would vote for lines.
Offline KHAANNN
« Reply #66 on: Mon, 03 August 2015, 09:51:45 »
The terminology also seems to be mixed, at least I'm mixing it, I don't think GMK has the bumps on ABS's, we probably all mean bump == line in this context
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #67 on: Mon, 03 August 2015, 09:52:59 »
I have some OG cherry w/ nipples.
Offline whentheclouds
« Reply #68 on: Mon, 03 August 2015, 09:56:24 »
directly in the center of the cap?
« Reply #69 on: Mon, 03 August 2015, 10:08:05 »
Most likely, a la "5" on the numpad.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #70 on: Mon, 03 August 2015, 10:11:07 »
yep, also on f & j
« Reply #71 on: Mon, 03 August 2015, 10:14:57 »
yep, also on f & j
Oh, I have some boards that have the bump on F & J but the nipple on 5, which is most common for me. Weird.
Offline Oobly
« Reply #72 on: Mon, 03 August 2015, 14:05:34 »
Oh, by "bumps" I meant lines, not dots.
Anyone else like the idea of Orange alphas?
« Reply #73 on: Mon, 03 August 2015, 14:31:27 »
Yes, orange alphas with white legends...
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #74 on: Mon, 03 August 2015, 14:33:00 »
Then we can call the whole set "Burnt Creamsicle"...
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #75 on: Mon, 03 August 2015, 14:34:33 »
eww
« Reply #76 on: Mon, 03 August 2015, 15:40:02 »
eww
Okay, let me clarify. Uniform orange with white legends.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #77 on: Mon, 03 August 2015, 15:42:50 »
eww
oooooh
eww
« Reply #78 on: Mon, 03 August 2015, 15:45:06 »
eww
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #79 on: Mon, 03 August 2015, 15:45:51 »
eww
Offline bcredbottle
« Reply #80 on: Mon, 03 August 2015, 17:12:30 »
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #81 on: Mon, 03 August 2015, 18:02:57 »
Would the keyset be priced to beat buying a whole skidata board?
http://www.ebay.com/itm/Keyboard-Trackball-Skidata-Ps-2-Multimedia-Mechanical-Cherry-Keys-/271456070304?hash=item3f340aeaa0
It is difficult to directly compare the base set with the Skidata keyboard because they are two different things. After shipping, the keyboard will be very expensive.
The benefit of buying the keyboard is that you get switches in addition to the keycaps, but it is ISO only, and it's not so cost effective after shipping fees.
The SKIDATA+ base set will support ANSI, 75%, 60%, HHKB, and other layouts. The original Skidata does not support any of those layouts mentioned above and only comes in ISO.
Offline bcredbottle
« Reply #82 on: Mon, 03 August 2015, 19:32:28 »
Would you consider having a set of 1.5u blanks for Ergodox users? It would only be one extra key...
Offline rsadek
  • raging keyboard monkey
« Reply #83 on: Mon, 03 August 2015, 23:46:40 »
I must have it.
Interested +10X. My poor wallet....time to go sell some blood.
-R
❤️Keeboardz
Offline luckyryan333
  • #There'sNoToolForTyping
« Reply #84 on: Tue, 04 August 2015, 02:40:48 »
eww
Like this?
107311-0
ps) I still give the scoops my support.
« Last Edit: Tue, 04 August 2015, 02:50:14 by luckyryan333 »
No PaiN, No GaiN
How to order from Taobao from outside of China and WITHOUT an Agent
daily driver: C70 w/ Oblivion
on the way: d65_12/gmkblk_3
Offline KHAANNN
« Reply #85 on: Tue, 04 August 2015, 02:52:57 »
eww
Like this?
I also want some orange modifiers, doesn't matter how I get it, I'm going to purchase any set for an orange tab
Also, no one is trying to take away scoops, we're merely requesting additional homing keys
Are you opposing the idea?
« Reply #86 on: Tue, 04 August 2015, 07:48:51 »
I want some fries with it.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #87 on: Tue, 04 August 2015, 07:52:27 »
As far as extra homing keys, what about doing it on an accent color like Ivan did in Dolch?
Offline Karura
  • SKidata life.
« Reply #88 on: Tue, 04 August 2015, 13:23:06 »
Just wanted to clear some things up:
I am not aware if GMK is able to make scoops + dash keys; this will have to be looked into, but conventionally, it is not popular and the original Skidata came with scoops only. Perhaps this could be added to a modpack, if it is financially feasible.
As much as I would love to offer many different colourways, such as the suggested burnt orangesicle, and some other suggestions, this is going to stay true to Skidata, as I know many people have been waiting for a long time for the opportunity to finally get a complete GMK Skidata keyset.
« Last Edit: Tue, 04 August 2015, 13:25:01 by Karura »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #89 on: Tue, 04 August 2015, 13:27:01 »
It's skidata, not orangesicle. You want orangesicle? Go make another thread
« Reply #90 on: Tue, 04 August 2015, 13:31:03 »
Holy ****, we can't even mention something else in an IC thread? TIL.
Offline Karura
  • SKidata life.
« Reply #91 on: Tue, 04 August 2015, 13:34:31 »
Discussion is always welcome! That said, this buy will only contain Skidata colourways, I hope people can respect that. :) No need for any mads.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #92 on: Tue, 04 August 2015, 13:36:05 »
I'm just not sure why someone would even need to suggest turning this into what would be basically an entirely different set
« Reply #93 on: Tue, 04 August 2015, 13:36:16 »
I love Skidata colorway, but I bought Charred Orange long ago.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #94 on: Tue, 04 August 2015, 13:36:48 »
So why are you here? This is for all the people that actually want Skidata, not to accommodate the people that already have a similar colorway and want their own set done
« Last Edit: Tue, 04 August 2015, 13:38:43 by hwood34 »
« Reply #95 on: Tue, 04 August 2015, 13:39:24 »
Apparently to annoy you.
And to support Karura's buy, if only morally.
And since you don't seem to get it, hwood, I mentioned the white on orange because I would love to see it run in another buy. Not this one. People were throwing out ideas about orange.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #96 on: Tue, 04 August 2015, 13:44:52 »
How do you know the orange was discovered before the carrot? Because it's called an orange.
« Reply #97 on: Tue, 04 August 2015, 13:46:24 »
Orange you the clever one? ;)
« Reply #98 on: Tue, 04 August 2015, 13:46:54 »
So will this basically look like charred orange? I really didn't care for it, I wished the orange would have stood out more.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #99 on: Tue, 04 August 2015, 13:48:38 »
No, it will be a brighter orange. I like to think of Charred Orange as a mistake. The color is dull, doesn't pop at all, compared to Skidata where it pops nicely, and the Charred Orange legends appear translucent. If my description isn't detailed enough Karura has a post w/ some more info.
