Author Topic: [IC] GMK SKIDATA+ (GB IS LIVE)  (Read 1594693 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: [IC] GMK SKIDATA+
« Reply #100 on: Tue, 04 August 2015, 13:49:31 »
So will this basically look like charred orange? I really didn't care for it, I wished the orange would have stood out more.
No, it will be a brighter orange. I like to think of Charred Orange as a mistake. The color is dull, doesn't pop at all, compared to Skidata where it pops nicely, and the Charred Orange legends appear translucent. If my description isn't detailed enough Karura has a post w/ some more info.
Yeah, a big problem with Charred orange was the orange legends, which were super pale in part because they were also pretty translucent.
« Reply #101 on: Tue, 04 August 2015, 13:55:38 »
These LEDs are orange, but the legends don't appear to be translucent on Charred Orange, at least to me they don't. Keep in mind this is a phone pic.
So, how will the legends in the Skidata+ set differ from those in Charred Orange? Doesn't GMK only have a limited color selection? I assume Originative used the standard orange color. Will Skidata+ use a custom color?
« Last Edit: Tue, 04 August 2015, 13:59:30 by jdcarpe »
« Reply #102 on: Tue, 04 August 2015, 13:56:31 »
That is what I was trying to ask. ;)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #103 on: Tue, 04 August 2015, 14:03:33 »
I can't remember, but there was a picture of the legends glowing a little. I am sure Karura will post some more w/ the information he has. He showed me a little bit of info about the difference.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #104 on: Tue, 04 August 2015, 14:12:21 »
Alright, I understand this is a pretty important topic, so I would like to clear this up once and for all.
I have both Skidata and Charred Orange, and while they are the same colour way, the orange on Charred Orange is actually darker/less bright. They look different.
GMK Charred Orange (Originative) is a flawed set
Most importantly, it is flawed in two ways:
1) The doubleshot process was flawed, I do not know how or why, but the orange itself is "thinner" and appears less bright and more "translucent"
Why is thinner/translucent a problem? Because the base of the keycap is dark grey/charcoal, having a thinner/translucent orange means that Orange on top becomes darker, and as a result, loses the "pop" and contrast of the original Skidata orange.
2) The tab mould used was a really weird one that is not standard.
I came to this conclusion after doing some keyboard science. I did not take good photos at the time, but since this is a pretty important point I am making, I will go and re-do the experiment and take some photos.
Before I go AFK and take some photos, I would like to quickly highlight the flaws in the charred orange set, using Longzilla's photos:
Please view in full-size to see the subtle differences.
1) Look at the Alt key, notice how "A" and "t" are lighter coloured (translucent looking) than the "l".
2) Look at Control, notice how the bottom half of the entire "Control" plastic is translucent.
3) Same with the Shift, Capslock, and Tab as well. Basically the whole keyset has this problem with translucent/thin orange plastic, including the alphas.
The original Skidata did not have this problem, and I will bring this up with GMK and do my best to offer a perfect set for this GB.
This appears to merely be a quality control issue with the double shot process.
« Last Edit: Tue, 04 August 2015, 14:19:46 by Karura »
« Reply #105 on: Tue, 04 August 2015, 14:23:45 »
I wasn't and am not trying to say there is anything wrong with this buy, so please don't misunderstand. In fact, I think it's a great idea to go ahead with it, even if it were exactly the same as Originative's Charred Orange set, save for the Tab legend.
However, the difference in the legends between the original Skidata set and Originative's Charred Orange MIGHT be due to a reformulation in the plastic composition between then and now. I'm only speculating, as we were told the formulations had changed since some of the historical sets, e.g. Triumph Adler, we're produced. It was said that the original blue color of the TA set yellowed over time, to give a nice teal color, which would not happen with GMK's modern plastic formulation. Thoughts?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #106 on: Tue, 04 August 2015, 14:27:38 »
I don't recall when TA was made, but Skidata was 1994, and was made completely by GMK. I don't know the relevance of this to your question, but it might answer or give hint to answering the question, or at least un-fog some areas.
Offline Karura
  • SKidata life.
« Reply #107 on: Tue, 04 August 2015, 14:29:32 »
You raise some good points, and don't worry, I understand where you're coming from :)
I personally feel it's quite a shame that Charred Orange was not able to be "perfect", that is one of the reasons why I wanted to do this colourway.
I know there are lots of people who believe it has been done before, but since CO was such a failure, I'd rather not count it ;)
Regarding the plastic reformulation, Skidata itself is actually not that old, and is not a Cherry-made keyboard.
I have disassembled mine before, and peeking inside the PCB, I discovered that Skidata is an 100% GMK made keyboard (so it is fairly modern). This means that the problem with the legends is most likely related to the plastics in some way, but I don't think it is a reformulation if Skidata was originally manufactured by GMK.
Edit: Looks like while I was typing this up, Seth had already replied haha.
« Last Edit: Thu, 06 August 2015, 16:02:31 by Karura »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #108 on: Tue, 04 August 2015, 15:05:04 »
Maybe some sort of reformulation for environmental concerns? Basically the only two logical reasons would be that and cost
Offline Karura
  • SKidata life.
« Reply #109 on: Tue, 04 August 2015, 15:10:52 »
Alright, time for some Keyboard Science!  :thumb:
Here we have:
1x Poker2 with bright white LEDs on the WASD cluster, Esc, and Spacebar.
1x WASD from OG Skidata
1x WASD from Charred Orange
With the naked eye, Charred Orange is very slightly more translucent and darker, but it is difficult to capture with my phone camera.
Lights offs, LEDs on, Charred Orange:
Now, with OG Skidata:
As we can observe, it appears that all doubleshot keycaps are at risk of bleeding light, but in the case of Charred Orange, it seems to be bleeding a lot more.
I have also ran this test with the following: (Due to the difficulty of photography, I did not take photos of these).
EK Red WASD
Ivan GMK Dolch WASD
Results were similar to the OG Skidata, where you will see a little light around the stem area, but nothing drastic like Charred Orange.
Conclusion: Originative's Charred Orange is a flawed set. Something must have gone wrong during the double shot process.
« Last Edit: Tue, 04 August 2015, 16:06:02 by Karura »
Offline LechnerDE
« Reply #110 on: Wed, 05 August 2015, 05:05:41 »
Thanks for the tests  :thumb:
I am sure if you make GMK aware of those issues, they can do some internal tests beforehand and not screw up the final production run.
If this set came out like Charred Orange I'd probably never use it...
« Last Edit: Wed, 05 August 2015, 05:52:04 by LechnerDE »
Offline KHAANNN
« Reply #111 on: Wed, 05 August 2015, 05:19:06 »
I have to say the Charred Orange seems more "unique" rather than "flawed" - the bleed-through might even be considered a feature, with backlights on, it becomes more like a "spooky orange" set
Of course, these all affect people who use backlighted keyboards, that's not me :)
I hope you don't mind me saying, but, with the Originative Orange available instantly, the only way (in my mind) for this set to reach MOQ is with some awesome extras
With Massdrop starting to pop a new GMK keyset one after another, the GMK scene seems more challenged
Offline Oobly
« Reply #112 on: Wed, 05 August 2015, 05:44:30 »
What we all really want is Orangesicle: https://geekhack.org/index.php?topic=70797.0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #113 on: Wed, 05 August 2015, 05:52:59 »
Can't argue with statistics :))
Offline Karura
  • SKidata life.
« Reply #114 on: Wed, 05 August 2015, 16:05:26 »
No problem, I am glad to educate :thumb:
I will bring it up with GMK for sure, and chances are, we will avoid this problem, as it only seems to exist on the Originative sets. No other GMK/Cherry keycaps have had this problem in the past.
I would like to respectfully disagree, because no other GMK or Cherry keysets have had this problem.
Also, if you look at my photos again, you will see that the Charred Orange light-bleed is very blotchey and uneven. It is very difficult to capture on camera and I tried my best.
If it was actually even throughout, I'd be happy to agree :) It would actually be pretty cool, but not when it's inconsistent and uneven.
« Last Edit: Wed, 05 August 2015, 16:19:31 by Karura »
Offline Karura
  • SKidata life.
« Reply #115 on: Wed, 05 August 2015, 16:17:37 »
While I do appreciate the discussion, the colourway for this buy will stick true to V2 (Orange) and N9 (Dark Grey).
It's not public knowledge, but SKIDATA+ has actually been in the works for over 10 months, and most of the layouts and design choices have already been finalized.
To be completely transparent, it started with reaching out to JaccoW and other members of the community that had already owned the set, to me actually acquiring both the Skidata keyboard, and Charred Orange, only to be disappointed that Charred Orange had some flaws with the legends and colours.
Then additional research on GMK legends, layout design and support, and other important factors that contribute to a successful group buy was conducted.
There was a lot of legwork involved and research done to reach the point where I felt comfortable in starting an IC.
I am completely dedicated to making this happen, and together, I am sure we will have a successful GB  ;)
« Reply #116 on: Wed, 05 August 2015, 16:23:38 »
I miss my OG skidata, hope this goes through
Offline hoggy
  • * Ergonomics Moderator
« Reply #117 on: Wed, 05 August 2015, 23:57:18 »
I've got a typenow solid that would look great with these caps.
Offline Oobly
« Reply #118 on: Thu, 06 August 2015, 02:43:55 »
Don't get me wrong, I ALSO want this set :) And I'm not alone in that. Didn't mean to say that this set isn't worth getting.
I really like the look of the original SkiData boards, but not such a fan of their layout, so with this set I can get the same look, but in the layout I like. :D I almost pulled the trigger on the Charred set a few months back, very glad now that I didn't.
Offline Karura
  • SKidata life.
« Reply #119 on: Thu, 06 August 2015, 03:25:19 »
Thank you, I am really glad to have your support. Really, thank you and everyone else for showing so much support. GMK should be back from vacation in a week or two, and hopefully I will finally be able to explain the layouts using the mockups :)
Offline 64rky
« Reply #120 on: Thu, 06 August 2015, 10:41:43 »
With you 100% captain Orange!  :thumb:
I am relatively new to this community, and am always blow away by how much time and effort everyone puts into these group buys, which benefits Sooooo many people. The level of detail that goes into these designs is extraordinary.
Apologies for my waffling, but I'm impressed.
I hope this kicks off, I love the idea!
Offline yicaoyimu
« Reply #121 on: Thu, 06 August 2015, 19:04:26 »
Want so bad!
Offline Data
« Reply #122 on: Thu, 06 August 2015, 19:15:28 »
This post helps your GB (IC) in ways you may not even realize.  That's an impressive amount of research and planning.  If I was on the fence before, I'm definitely a fan now.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #123 on: Fri, 07 August 2015, 13:48:21 »
Keeping my eye on this one.
« Reply #124 on: Fri, 07 August 2015, 13:49:44 »
Whoa, who is this guy? :P ;)
« Reply #125 on: Fri, 07 August 2015, 13:50:01 »
Literal eye. He has one eye. He's a pirate. A butt pirate. Arrrrrrr matey
  • HHKB Wannabe
« Reply #126 on: Fri, 07 August 2015, 13:53:23 »
Will there be 1x mods included as well as tsangan sets?
« Reply #127 on: Fri, 07 August 2015, 13:55:49 »
Hush child, don't make a fool of yourself. Just text me lol
  • HHKB Wannabe
« Reply #128 on: Fri, 07 August 2015, 13:56:27 »
But what fun is that?
Offline Karura
  • SKidata life.
« Reply #129 on: Fri, 07 August 2015, 13:58:30 »
WKL keys, including 1u window keys will be included.
I have literally seen no one use 1u Ctrl, Alt keys so those will probably not be included. Do you require it?
  • HHKB Wannabe
« Reply #130 on: Fri, 07 August 2015, 13:59:51 »
No just the win keys. Thanks.
« Reply #131 on: Fri, 07 August 2015, 14:07:20 »
I use a 1u Alt on my JD40 :)
« Reply #132 on: Fri, 07 August 2015, 14:08:08 »
Quiet you! :D
Offline 64rky
« Reply #133 on: Fri, 07 August 2015, 16:59:38 »
This group buy and the orange ducky one is my next work board,  done!
Offline Orca
« Reply #134 on: Fri, 07 August 2015, 17:45:55 »
Some ideas for modifiers,
grey + orange legends
white + orange legends
orange + black legends
Offline mrflow3r
    • T
« Reply #135 on: Mon, 10 August 2015, 02:56:07 »
Gr. Take my money. All of it.
Offline Data
« Reply #136 on: Mon, 10 August 2015, 11:02:37 »
I'd support a separate GB for inverted (black legends on orange) modifiers for this set.  That's very nearly my dream set.  But it's probably too much to ask from this GB.  GMK's MOQ doesn't play nice with add-ons.  :(
Offline Karura
  • SKidata life.
« Reply #137 on: Tue, 11 August 2015, 02:26:19 »
Almost everything that people have mentioned in the thread has already been considered months ago, and many ideas have already been included in the design of the entire set. The design has been finalized for many months now.
Sit tight and wait for the mockups. You won't be disappointed.
Offline LechnerDE
« Reply #138 on: Tue, 11 August 2015, 02:38:43 »
So what's the planned timeline for this GB?
Do you plan to launch it after GMK Classic Beige is finished?
I am just asking so I can manage my keyboard budget accordingly  :thumb:
Offline Giorgio
« Reply #139 on: Tue, 11 August 2015, 03:10:35 »
Are the ISO keys included in the main package - like all the gb, except classic beige - or are they available as an addon? Do you plan to ship from the usa or do you have a proxy? Delivering from the usa should be better (no vat and no import taxes if the value is"correct").
Offline maroder
« Reply #140 on: Tue, 11 August 2015, 04:33:01 »
Interested.  A option for German ISO-Layout would be an Instant-Buy.  :thumb:
Offline Data
« Reply #141 on: Tue, 11 August 2015, 08:42:49 »
Yeah I wasn't asking you to add anything.  Actually, the opposite.  :P
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #142 on: Tue, 11 August 2015, 11:29:07 »
Very interested in this set!   :thumb:
Offline jerue
  • (Whenever that happens :P)
« Reply #143 on: Tue, 11 August 2015, 21:55:35 »
Working on getting a Data 911, I think this keyset would look great on it.
Gonna have to vote for 1u CTRL and ALT keys at least. Not sure if 1.25 and 1.5 Shift keys have been discussed but I think I'll need those as well. I'm sure I could find a blank 1.5u key for that weird "1" key, or maybe I could get an extra add on.
Offline KHAANNN
« Reply #144 on: Tue, 11 August 2015, 22:04:00 »
I don't know too much about GMK's, but I don't think there is a 1.5 Shift
If the "1" key is up above, I don't think you can find a satisfactory blank either
Offline Giorgio
« Reply #145 on: Wed, 12 August 2015, 02:27:54 »
Do F and J have a dash or a deep dish?
Offline LechnerDE
« Reply #146 on: Wed, 12 August 2015, 02:56:54 »
Since this is a GMK set that tries to be faithful to the original I assume there will be scoops.
Offline KHAANNN
« Reply #147 on: Wed, 12 August 2015, 03:20:29 »
I would say 99.99% scoops :)
gmkgbers don't care about us dashers
Offline Giorgio
« Reply #148 on: Wed, 12 August 2015, 03:52:38 »
I want an usable set, not a faithful one. How can you be faithful by adding keys that weren't in the original set (which furthermore was probably iso)?
Faithful... let's talk about how faithful are the colors of TA ;-)
« Last Edit: Wed, 12 August 2015, 03:56:03 by Giorgio »
Offline LechnerDE
« Reply #149 on: Wed, 12 August 2015, 04:07:04 »
So you are saying scoops are unusable?
I bet the majority of Geekhack will disagree with that statement...
