Poll
What's your favorite type of switch?
herry MX
28 (44.4%)
LPS
3 (4.8%)
uckling Spring
18 (28.6%)
opre
10 (15.9%)
herry ML
1 (1.6%)
ther (Please Specify)
3 (4.8%)
Total Members Voted: 62
Author Topic: What is your favorite type of switch?  (Read 17240 times)
Offline msiegel
« Reply #50 on: Tue, 13 October 2009, 18:54:51 »
Quote from: AndrewZorn;125118
alright so what is the terminology then
if there is none or we dont know it how about:
"outer cap" to describe what i was saying "there's no way" about, and
"inner stem sleeve" to describe what i think might actually stop the key (and what you seem to be talking about)
a taller "outer cap" should do nothing, as it should not matter.
a taller "inner stem sleeve" that covers more of the stem should actually prevent the switch from fully going down, reducing the throw, but hopefully not TOO much...
in which case, a "shorter" "keycap" would provide longer throw...
still extremely curious
EDIT and if the switch's internals actually stop the key, then any different results from the cap are purely placebo.  your fingers might be starting out lower from the desk but they would move the same distance.
YES, this sounds right to me :)
Offline timw4mail
    • https://timshomepage.net
« Reply #51 on: Tue, 13 October 2009, 19:18:18 »
Quote from: ripster;125128
Model Fs and Ms are different.  One uses a capacitive switch and the other uses a membrane switch.  That's why they should be separated in this poll.
Bwahahahahahahah!
And there are so many different types of Cherry MX switches, and even more ALPS switches. It's fair in that way.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline AndrewZorn
« Reply #52 on: Tue, 13 October 2009, 19:52:29 »
so all this, and no discovery?
if the inner stem sleeve is stopping a cherry from bottoming out, then filing it down (while retaining enough length to keep it in place) would give you more room to bottom out, but the same distance to actuation.
which would be awesome... what if they made a variant of the cherry switch, but with an inch-long stem, and a short enough inner stem sleeve... so that you basically CANNOT bottom out, but the switch still actuates at the same point.  might feel awkward at first, but no more bottoming out, ever...
would be awful for games
Offline AndrewZorn
« Reply #53 on: Wed, 14 October 2009, 08:01:09 »
so the keycaps cannot affect it at all.
right when i was going to bed i realized why it could NOT have been the "inner stem sleeve".  imagine trying to put the caps back on after having removed them.  the pressure would push the switch down, all the way, and you would never be able to get the cap fully 'on', because every time you tried you would just be pushing the switch in.
Offline timw4mail
« Reply #54 on: Wed, 14 October 2009, 09:40:42 »
Quote from: AndrewZorn;125237
Unless your keys are actually molded onto the switches, keys still do have an effect on feel:
- How much of the tactile point is obscured
- How smoothly the switch goes down, depending on the fit of the cap on the slider
- How much over-travel, until you hit the top of the switch casing
Keys have a very big impact on switch feel, its just difficult to quantitatively measure.
Offline FourOhFour
« Reply #55 on: Wed, 14 October 2009, 15:22:37 »
My BS board came yesterday, and I replaced the rivets with screws (more than half of them were broken) today... now I just need a PS/2 adapter so I can actually use the damn thing.
But just from banging around on it, I think I'll be voting BS :-P
(And I thought people only voted for BS on the first tuesday after the first monday in november...)
Offline timw4mail
« Reply #56 on: Wed, 14 October 2009, 15:39:28 »
Quote from: FourOhFour;125393
You seriously don't have a PS/2 port on your computer? Or is it a laptop?
Offline ch_123
« Reply #57 on: Wed, 14 October 2009, 15:41:11 »
He could be using one of them fancy Appletoshes.
Offline FourOhFour
« Reply #58 on: Wed, 14 October 2009, 15:43:00 »
Quote from: timw4mail;125399
It's a MacBook, so no... but neither does my brother's dell desktop.
Offline itlnstln
« Reply #59 on: Wed, 14 October 2009, 15:49:57 »
PS/2 ports are pretty hit or miss these days.  My 1 year old desktop has them, but my 2.5 year old laptop doesn't (the docking station does, though).
Offline ch_123
« Reply #60 on: Wed, 14 October 2009, 16:32:29 »
The real fun will happen when USB is replaced. And there's talk of technologies that could start to replace it within the next 5-10 years.
Offline FourOhFour
« Reply #61 on: Wed, 14 October 2009, 17:09:05 »
Quote from: ch_123;125413
Eventually we'll need a string of adapters 5 deep to use a decent keyboard.
Offline AndrewZorn
« Reply #62 on: Wed, 14 October 2009, 18:17:13 »
USB 3.0 is backwards compatible.  You can see where they just stuffed more pins in where it didn't affect the old design.  So I think it's more likely that far far later, it still LOOKS like a USB plug, but has a ton more stuff inside.  It with glow like a Toslink plug because of its optical connection, etc.
Offline timw4mail
« Reply #63 on: Wed, 14 October 2009, 18:28:37 »
Quote from: FourOhFour;125425
It seems I have to use two for my Model F, as my main desktop can seem to power it through PS/2.
Offline ch_123
« Reply #64 on: Thu, 15 October 2009, 02:46:59 »
Quote from: AndrewZorn;125446
I wasn't talking about USB3, was moreso referring to Intel Light Peak and the like...
Offline timw4mail
« Reply #65 on: Thu, 15 October 2009, 05:58:03 »
Quote from: ch_123;125524
Ugghhh... I'd rather have all my different types of cords.
Offline itlnstln
« Reply #66 on: Thu, 15 October 2009, 08:05:50 »
Did someone recant their vote for BS?  I swear BS had 12 votes yesterday.
Offline timw4mail
« Reply #67 on: Thu, 15 October 2009, 08:06:46 »
Quote from: itlnstln;125573
You can't change your vote.
Offline itlnstln
« Reply #68 on: Thu, 15 October 2009, 08:18:54 »
I didn't think so, but I swear BS had 12 votes yesterday.  Oh well, no biggie.
Offline ch_123
« Reply #69 on: Thu, 15 October 2009, 09:05:54 »
Quote from: timw4mail;125547
Whyso?
Offline ch_123
« Reply #70 on: Thu, 15 October 2009, 09:08:36 »
Which reminds me, why did we need another one?
Offline JBert
« Reply #71 on: Thu, 15 October 2009, 09:20:32 »
Well, with all the infighting and dubious fragmentation, the previous one wasn't really clear cut.
This one is more about different key designs rather than individual key switches (where the Alps would actually need a poll of themselves).
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline erricrice
« Reply #72 on: Thu, 15 October 2009, 09:54:36 »
Quote from: ripster;125601
ALPS polls are always easy.  You only have 3 people.  They can just PM each other.
Nah, I'm pretty sure we all agree with one another.  Real Complicated white ALPS.  Maybe somebody on fukkas but that's only because they feel like Real Complicateds lol.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline itlnstln
« Reply #73 on: Thu, 15 October 2009, 10:41:57 »
Quote from: ripster;125609
The Fukka Tsunami ended up being a 3 inch wave.
Strong.
Offline ch_123
« Reply #74 on: Thu, 15 October 2009, 11:09:45 »
the fukka tsunami ended up being a 3 inch wave.
QFT
The Beam-Spring seems to be the hot switch of the season. Shame that only the most dedicated IBM hackers can really do anything with them.
Offline itlnstln
« Reply #75 on: Thu, 15 October 2009, 11:30:25 »
Quote from: ripster;125657
That switch will also fade pretty quickly unless you can make it put a character onto a PC screen. I know, I'm picky.
Stop it.  We can all pretend, can't we?
Offline timw4mail
« Reply #76 on: Thu, 15 October 2009, 11:35:01 »
Seems like a legitimate complaint to me. I don't care if its the best switch that exists, because 1) It's too rare, and 2) It's too much work and research to get it to work with a modern computer.
Offline ch_123
« Reply #77 on: Thu, 15 October 2009, 13:21:06 »
Pfft. Come on folks, where is your sense of adventure?
FANBOI. I'm telling!
« Last Edit: Thu, 15 October 2009, 13:58:32 by ch_123 »
Offline msiegel
« Reply #78 on: Thu, 15 October 2009, 13:23:20 »
yeah, some of us really like tech archaeology, reverse-engineering, and unique custom-made items... :)
Offline JBert
« Reply #79 on: Thu, 15 October 2009, 13:23:31 »
Quote from: timw4mail;125660
Well, the rarity kills it for me. I would like to get it to work should I have one though - at least it sounds challenging.
The storage list:
[/SIZE]
Offline msiegel
« Reply #80 on: Thu, 15 October 2009, 13:33:54 »
patience, it's a really big mod :) study, planning and design also playing major roles...
Offline AndrewZorn
« Reply #81 on: Thu, 15 October 2009, 13:44:13 »
if i were to vote right now i would vote topre
but i shouldnt until i try blue and bs
Offline FourOhFour
« Reply #82 on: Thu, 15 October 2009, 14:02:14 »
Well, I can finally use my BS board... and I'm voting BS. The Cherry keyswitches that are actually available in keyboards are too light, and the clears are only in one ugly and large keyboard.
Offline itlnstln
« Reply #83 on: Thu, 15 October 2009, 14:04:32 »
Quote from: FourOhFour;125733
I'm voting BS.
Well, I'm calling BS.  So there.
Offline FourOhFour
« Reply #84 on: Thu, 15 October 2009, 14:07:55 »
Quote from: itlnstln;125736
Oh? What's his phone number?
Offline itlnstln
« Reply #85 on: Thu, 15 October 2009, 14:15:09 »
Bob Smith: 1-800-777-4886
Offline PRISONER 24601
« Reply #86 on: Sun, 27 December 2009, 03:55:18 »
Voted other because blue monterey are not up there.
Probably not my favorite switch forever, but right now they're a little ahead of cherry browns.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline alipstadt
    • http://www.lipstadt.com
« Reply #87 on: Mon, 28 December 2009, 01:59:37 »
Well, now that someone revived this, I feel ok posting.  Voted BS, but I can't say as I'm a fanatic.
BS by a hair, then Cherry Blue.  Topre and Cherry Browns after that, but Topre much more.  Do not like Cherry Blacks, even though I have a few.  The last time I used ALPS was in the 80s, so I'm not sure I should comment.
I do so miss my Model F+PC/AT, though, lost to time, storage, and relocation...
Adam
On the go:
HHKB Pro JP Black | TG3 KBA-BL82-5RBUVS | Apple Compact Aluminum (USB and BT) | G84-4100PTMUS | Filco Zero Fukka Tenkeyless (broken, for the moment)
At home:
IBM/Maxiswitch M13 Black + Nostromo n52 + Logitech diNovo Mini | G80-11903LPMUS/03 | Model F (AT) with Keypatch 10 | G80-8113HRBUS-2 | TG3 KBA-BLT-5RBIVS | Deck 82 Toxic | G84-4100PTMUS
Other Pieces:
FrogPad Bluetooth, (right hand) | Datahand DH200 | Chicony KB-5181 | AEKII | Power Computing/Macally MK 105X | Sun Type 6 USB | Sun Type 5c | Airlink/Dolch Luggable K6 with Blue Cherries
Offline Oqsy
« Reply #88 on: Mon, 28 December 2009, 02:22:46 »
my current fave is not on the list, so I voted Cherry ML just to be a troll :D
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
