Author Topic: keycap profiles  (Read 2610 times)
Offline flizz
keycap profiles
« on: Mon, 17 August 2015, 20:55:35 »
Hey guys, I recently ordered something from mass drop
https://www.massdrop.com/buy/vortex-pbt-keycaps
I have a filco majestouch(first gen) keyboard I was wondering if the cherry profile will fit my keyboard.
Also if you guys have a preference cherry profiles or OEM profiles. Thanks guys.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: keycap profiles
« Reply #1 on: Mon, 17 August 2015, 20:57:10 »
Profile won't affect compatibility, you'll be fine.
And definitely Cherry profile
Offline flizz
Re: keycap profiles
« Reply #2 on: Mon, 17 August 2015, 21:04:41 »
thanks for the quick reply! seems like i made the right choice thanks :D
Offline kivx
Re: keycap profiles
« Reply #3 on: Tue, 18 August 2015, 03:05:37 »
There will possibly be some interference between this Vortex keycap set and Costar Stabilizer, especially the first generation of Filco.
However, you still have chance not to encounter this.
Offline flizz
Re: keycap profiles
« Reply #4 on: Tue, 18 August 2015, 15:47:02 »
uh oh, can you explain in some more detail if i should cancel my order then? :(?
Offline kivx
Re: keycap profiles
« Reply #5 on: Tue, 18 August 2015, 19:17:26 »
I can't tell you if you should cancel or not because you still have chance not to encounter this interference.
As s result of this vortex keycaps are thicker then normal ABS or other PBT keycaps, the costar stabilizer wire might hit the inside face of keycap when you press down the switch.
Not every keyboard with costar stabilizers would have this interference.
« Last Edit: Tue, 18 August 2015, 20:32:14 by kivx »
Offline 108
  • Yeet. Yeet.
Re: keycap profiles
« Reply #6 on: Tue, 18 August 2015, 20:13:29 »
You may just want to wait and see. If they don't work I'm sure there will be someone willing to take them off your hands.
Offline flizz
Re: keycap profiles
« Reply #7 on: Wed, 19 August 2015, 21:41:30 »
alright will do, hopefully it all works out :X
