Author Topic: [Postoned] FingerSK/UP (75%) + Finger (65%) Cases in development  (Read 23744 times)
Offline meiosis
  • Time
Orders postponed until an ETA is given on case and plate development, sorry everyone.
If someone really wanted their orders of just pcbs please resubmit!
Form:
http://goo.gl/forms/d6xHdDdVTE
« Last Edit: Thu, 10 September 2015, 20:17:34 by Meiosis »
Keyboards:
Aripeko TKL
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: [GB] FingerSK (75%) + FingerUp (65%) + AEK2 (Alps) PCB's
« Reply #1 on: Tue, 18 August 2015, 23:29:26 »
Yep, 15$ includes all parts!
Offline Data
« Reply #2 on: Wed, 19 August 2015, 09:24:32 »
If we purchase the RGB version will the RGB LEDs also come soldered like the controller parts?
@sethk_ Can you expand on the extent of soldering services you're providing?  I'm trying to figure out if that's something I need.
Forgive me, this was probably asked and answered in the IC thread but I'm not seeing it.
Offline geniekid
« Reply #3 on: Wed, 19 August 2015, 09:36:37 »
The OP could use more details.  We should not assume everyone interested in this GB has read through the IC.
Do the PCBs include unsoldered diodes and/or resistors?  If not, what diodes or resistors are needed?
What layouts does the FingerSK support?
What is a "Panda design"?  Is this an option that will be added later to the order form?
Offline Norman_the_Owl
« Reply #4 on: Wed, 19 August 2015, 10:19:06 »
How are the RGB SMD leds controlled? Are they controlled at all? What comes presoldered? Any diodes, resistors, etc?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #5 on: Wed, 19 August 2015, 11:09:32 »
I offer soldering services in a thread I have, and for this GB I will be offering Resistors & Diodes, but if you are requesting more than just that, PM me and we can work out the details. My thread can be seen here: https://geekhack.org/index.php?topic=73610
It does not include parts for diodes and resistors.
These are the diodes you will need: http://www.mouser.com/Search/ProductDetail.aspx?R=1N4148W-7-Fvirtualkey62110000virtualkey621-1N4148W-F
And resistors come in different Ohms, but this is the general type, and you can find other Ohms: http://www.mouser.com/Search/ProductDetail.aspx?R=ERJ-6ENF8060Vvirtualkey66720000virtualkey667-ERJ-6ENF8060V
Layout and assembly guide: http://lzlife.tistory.com/entry/Finger-L3-PCB-assembly-guide
Leeku's new PCBs all support similar layout options.
Only controller parts come Presoldered AFAIK, not sure about RGB LEDs. For 15$, I am offering a service where I will solder on the diodes & resistors. If you need more than just that for assembly, you can see my thread where I posted it earlier in this post.
Offline tjweir
« Reply #6 on: Wed, 19 August 2015, 11:16:16 »
Are there any finished examples of the FingerUP 65%?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #7 on: Wed, 19 August 2015, 11:17:48 »
This is the one that is used inside LZ SQs I believe
Offline tjweir
« Reply #8 on: Wed, 19 August 2015, 11:19:17 »
Ah yes, I believe you mentioned that in another thread, I forgot.
Offline geniekid
« Reply #9 on: Wed, 19 August 2015, 11:19:52 »
Thanks for the info sethk :thumb:
Offline tjweir
« Reply #10 on: Wed, 19 August 2015, 11:49:30 »
Form submitted for a FingerUP.
The bottom row layout options sealed the deal for me.
Squeee.
Offline meiosis
  • Time
« Reply #11 on: Wed, 19 August 2015, 20:59:24 »
Hey everyone, was pretty busy today, Diodes and Resistors are not included, if they are needed I can source them and include 100x with each order for a bit more.
More photos will be added tonight or tomorrow!
The $5 RGB chip will come soldered on :)
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #12 on: Thu, 20 August 2015, 08:34:17 »
I asked for sethk_ to assemble my FingerUP, so I'll need those parts.
Offline JonasDK
  • Let me poo on you
« Reply #13 on: Thu, 20 August 2015, 13:30:59 »
i'd be in for sure if there's a case and plate made made for it.
We are in talks, there might be an acrylic case option!
What's the status with the case?
Offline AKmalamute
  • HHKB Scrub
« Reply #14 on: Thu, 20 August 2015, 23:11:49 »
 From the look of it, (I'm in for the FC660M looking 'fingerup') two pieces of acrylic would be more than adequate but I'd need the .DXFs to go that route.
 Actually, speaking of the DIY case route Meiosis, can you find out if a metal "rim" would be a problem? That is, let's say you were to get an aluminum layered case ... would it short anything out if the "acrylic" case were made of metal (e.g. cut by big blue saw)?
HHKB-lite2, Dvorak user
Offline thelectronicnub
  • drowning in keyboards
« Reply #15 on: Thu, 20 August 2015, 23:17:22 »
In for a FingerSK, and definitely interested in an acrylic case
KUL ES-87 w/MX Greens
B/S/T Thread
Offline ika
« Reply #16 on: Fri, 21 August 2015, 01:25:03 »
How long will this buy be running? I would like to wait and see what case options will be made available, if any. Very interested in the 75% though.
Offline meiosis
  • Time
« Reply #17 on: Fri, 21 August 2015, 01:32:51 »
I will try my best to make this happen, I just want to make sure it's a reasonable price since I have no idea how many people would be interested in a whole set. (I'm guessing 10-20) Although I believe the MXmini files are out there, and would just need an acrylic cutter. (read below on why I  haven't mentioned it completely!)
It won't, there aren't any traces near the area, and the traces are covered :P.
Cases are still being discussed, I will try to run it by someone who has made them before... As for affordability of the cases I don't know what MOQ would be feasible so I have been skeptical to give an exact answer to whether they will be an option.
The GB will finish 9/12 (or before)
« Last Edit: Fri, 21 August 2015, 01:35:24 by Meiosis »
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #18 on: Fri, 21 August 2015, 08:53:50 »
I think I want to update my order from 1 FingerUP with assembly to 2.
Should I simply resubmit the form?
Offline Cameron
« Reply #19 on: Fri, 21 August 2015, 09:27:25 »
I'm only going in if there's a case option unless anyone knows of any existing cases that will fit this on taobao or anything
Offline Data
« Reply #20 on: Fri, 21 August 2015, 10:14:37 »
Plates and cases were tossed around in the Interest Check.
I'm still deciding if I want to get in on this...
Offline Invaderevan
« Reply #21 on: Fri, 21 August 2015, 10:39:29 »
I <3 75%!
In for 2! I would buy diodes if you wanted to sell them to me!
WTTF Ribbits, Ashen V2 MX, Bronins
« Reply #22 on: Fri, 21 August 2015, 12:04:20 »
Also waiting for possible case/plate options
I'll probably be in for a FingerUp anyway, but no sense hopping in too early
Offline gogusrl
« Reply #23 on: Fri, 21 August 2015, 12:30:30 »
Split spacebar but no ISO ? :(
Offline meiosis
  • Time
« Reply #24 on: Fri, 21 August 2015, 12:38:27 »
If anyone wants to change their order just submit another one! I'll go through and just use the most current!
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #25 on: Fri, 21 August 2015, 13:22:45 »
Thanks.
Offline tjweir
« Reply #26 on: Fri, 21 August 2015, 13:48:50 »
Do we know what controller this uses?
All of the firmware stuff I've seen about Leeku boards is Windows-only, if so, this is going to be a problem.
If it uses an ATMEL atmega32XX maybe I can port tmk from @hasu.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #27 on: Fri, 21 August 2015, 22:25:11 »
theres ISO
Offline meiosis
  • Time
« Reply #28 on: Fri, 21 August 2015, 22:46:52 »
How complicated is the key mapping you are planning, if you would like I could flash it to your preferred layout or hot keys. You are ordering assembly
Too? From the form haha
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #29 on: Sat, 22 August 2015, 07:37:51 »
The current plan is pretty complicated, I'll get the link to the layout.
Two? One for work, one for home, only baller status for me.  :)
Offline meiosis
  • Time
« Reply #30 on: Sat, 22 August 2015, 07:40:10 »
Woops I was on my phone and hit return :p , I meant you were having it assembled by seth? And ahh if it's custom I understand that it has to be exactly as you want.
As for everyone else would a full acrylic or skin case be preferred? (Still hypothetical)
Keyboards:
Aripeko TKL
Offline meiosis
  • Time
« Reply #31 on: Sat, 22 August 2015, 09:05:46 »
As of now I believe there will be plates available although there will be screw holes if there was a case, perhaps I started the gb a bit too early, but things are looking up.
Keyboards:
Aripeko TKL
Offline Jokrik
« Reply #32 on: Sat, 22 August 2015, 09:08:16 »
Would be very interested if there's a case and plate with it :) (75%)
keep us updated!
Offline meiosis
  • Time
« Reply #33 on: Sat, 22 August 2015, 09:09:03 »
keep us updated!
Yeah one thing I can say though which might deter but instead of raising hopes, is it will be mostly acrylic.
Keyboards:
Aripeko TKL
« Reply #34 on: Sat, 22 August 2015, 09:24:00 »
Not too early, just let it run for a while longer if necessary. It lets orders come in over time. And gives my wallet time to prepare :P
I just shelled out for some round 5a caps, god knows i need the recovery time
« Reply #35 on: Sat, 22 August 2015, 12:02:15 »
Would a Winkeyless B.mini case be compatible with this?
B/S/T Thread
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #36 on: Sat, 22 August 2015, 12:13:30 »
Yes
Offline hippo008
« Reply #37 on: Mon, 24 August 2015, 23:21:04 »
Seriously interested in the FingerUP. Here I was sitting at home trying to cram arrow keys into a 60% I was planning and this comes along! Perfect.
My only question is on case compatability. I'm assuming we have to have our own plates and cases cut?
Offline meiosis
  • Time
« Reply #38 on: Tue, 25 August 2015, 00:04:36 »
Not to get anyones hopes up but...
http://kbdlab.co.kr/index.php?document_srl=2640505&mid=board_housing
this might be happening..
Keyboards:
Aripeko TKL
Offline E3E
« Reply #39 on: Tue, 25 August 2015, 00:49:09 »
My wallet is on lock down for the most part. Only a few more things I have left to buy to fulfill some board projects I have. As much as I wish I could slot this in, it'd just be redundant. I can't justify it. Tjweir IS a baller though. :))
That LZ tho.  :-\
Offline ika
« Reply #40 on: Tue, 25 August 2015, 00:58:37 »
oh no... I did not need to see that... and if there is a 65% option like this, I expect a chorus of tears from every bank account I have.
Offline tjweir
« Reply #41 on: Tue, 25 August 2015, 07:28:19 »
Ya, down for that tub case for a 65% if possible.
Offline stoic-lemon
« Reply #42 on: Tue, 25 August 2015, 07:52:59 »
A case would make this 65% very difficult to pass up.
Offline hippo008
« Reply #43 on: Tue, 25 August 2015, 08:41:13 »
That would be awesome! And if anybody is interested, I've been looking for a project recently. I'd be happy to work on the files for having a case and plate cut for the FingerUP 65%
Offline Dreamre
    • kbdlife
« Reply #44 on: Tue, 25 August 2015, 10:34:02 »
What kind of case material is that?
Offline JonasDK
  • Let me poo on you
« Reply #45 on: Tue, 25 August 2015, 13:13:37 »
Wait, so this board wont support ISO?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #46 on: Tue, 25 August 2015, 13:19:03 »
It does, I don't think that guide shows it though
Offline hippo008
« Reply #47 on: Tue, 25 August 2015, 13:50:12 »
I had some free time so I made up a plate and visual mockup for the FingerUP.
The R4 layout I chose -
Le plate for said layout -
Link to CAD file for plate - https://drive.google.com/file/d/0B-w0V8tjga_QbTJ5SkE0M2E4c0E/view?usp=sharing
Visual Mockup featuring the Carbon set -
Offline Cameron
« Reply #48 on: Tue, 25 August 2015, 20:12:24 »
You seriously have my attention sir. Make it happen. LET ME GIVE YOU MONEY
Offline ika
« Reply #49 on: Tue, 25 August 2015, 22:04:28 »
Is there more info about the capabilities or pictures of these PCBs? I found the LZ-SQ here (http://lzlife.tistory.com/entry/Finger-L3-PCB-assembly-guide) and more detail about the FingerUP (or Finger L3?) but can't find much detail on the FingerSK.
