Author Topic: HHKB pro 2 or realforce 87 variable weight  (Read 3694 times)
Offline bocahgundul
  • a seal
« on: Tue, 18 August 2015, 09:09:35 »
Hello guys this is my first post  :cool: i just wanna know what is better realforce or hkhb. I cant get the realforce 55 gram because i dont know where to buy it and if i buy it from EK im scared of the price and TAX. well the i can get the variable weight realforce for just 130 dollar and hhkb well 220 i just want to hear what you guys prefer more  :)
Offline absyrd
  • CPT HYPE PADAWAN
Re: HHKB pro 2 or realforce 87 variable weight
« Reply #1 on: Tue, 18 August 2015, 09:23:34 »
What are you using the keyboard for?
Offline bocahgundul
  • a seal
« Reply #2 on: Tue, 18 August 2015, 09:28:09 »
just typical typing and gaming and some coding i had to sell my leopold fc750r and k70  just to try topre bro and i want my first topre to be good and my second topre will be novatouch
Offline saturnotaku
« Reply #3 on: Tue, 18 August 2015, 09:36:21 »
I wouldn't recommend the HHKB for gaming, especially if you use the function keys with any regularity. At the same time, the Realforce variable weight isn't great for gaming either because the lighter actuation force of the keys on the outside can result in a greater chance of accidental key presses.
In all honesty, for your purposes, I would suggest getting the Novatouch. It doesn't feel quite the same as a Realforce or HHKB, but it's not bad by any stretch of the imagination. Plus you can easily swap the keycaps out with any Cherry MX compatible set.
Offline bocahgundul
  • a seal
« Reply #4 on: Tue, 18 August 2015, 09:44:39 »
Well i want to buy the novatouch bro but i just dont want to wait for another gb for keycaps. Well i just play some csgo or some dota 2 so its not a big deal cuz i dont play sc2, and 1 thing that i'm scared of novatouch i'm scared that the build qulity is not as good as realforce and the fell will be different  thats what i'm scared from the novatouch. I know that the novatouch have the mx stems thats 1 thing that keeps me want the novatouch.
Offline saturnotaku
« Reply #5 on: Tue, 18 August 2015, 10:00:21 »
Having used a Novatouch, Realforce, and HHKB, I can tell you there is very little difference in build quality among them.
Offline Polymer
« Reply #6 on: Tue, 18 August 2015, 19:43:24 »
Variable sucks for gaming IMO....The HHKB will be much better....
Not a fan of Topre for gaming in general..but the variable weight for gaming would be odd...I suppose you can get used to it but it just feels wrong...
But 130 for a variable is a great price....I probably use that keyboard more than any other...
« Reply #7 on: Tue, 18 August 2015, 19:49:22 »
I'm having a similar debate man.. Fc660c or 87u..
Offline Cicada88
« Reply #8 on: Tue, 18 August 2015, 19:53:28 »
I would just go with the HHKB especially if you plan to get the NovaTouch in the future which you can dedicate towards gaming.
I game with my HHKB and find it equal to my Filco TKL with MX Reds in that regard.  If you were heavy using Function keys though it could be a problem.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #9 on: Tue, 18 August 2015, 19:54:41 »
Blank fc660c! Do it, :P
Offline Hypersphere
« Reply #10 on: Tue, 18 August 2015, 20:19:48 »
If you prefer a standard layout, go for the RF or Novatouch (NT). IMO, the RF has better build quality and more features than the NT. If you prefer a 60% form factor and the HHKB layout, go for the HHKB. The Leopold FC660C is a solid Topre-switch board that includes aspects of the RF and HHKB.
I have not tried a variable-weight RF, but I anticipate that the 30g switches would be too light for me.
IMO, all the Topre-switch boards can benefit from some form of silencing to reduce the return-stroke "clack" and leave just the down-stroke "thock".
Offline bocahgundul
  • a seal
« Reply #11 on: Tue, 18 August 2015, 20:30:31 »
So its the novatouch or hhkb pro 2 what about the feel on novatouch compared to hhkb pro?. Btw thx for the reply bro
Offline saturnotaku
« Reply #12 on: Tue, 18 August 2015, 21:04:52 »
What features are those? 55g weighting option, which is certainly not to everyone's tastes, and a fairly dubious built-in numpad?
Offline Macsmasher
« Reply #13 on: Tue, 18 August 2015, 21:33:37 »
I've been favoring my HHKB lately over my 87Us because I'm really getting used to the function layer nav cluster. But if we're talking just build quality, I think the RF are better built than the HHKB. Never tried the Novatouch. Still great build quality in the HHKB, but the RF boards just feel better built. Maybe that's because of the plate mounted vs case mounted switches. Regardless, both will last long enough to justify the purchase.
Offline bocahgundul
  • a seal
« Reply #14 on: Wed, 19 August 2015, 02:21:50 »
i dont know what to choose HHKB pro 2 or the Novatouch are the feels different? and what about the build quality?
Offline bocahgundul
  • a seal
« Reply #15 on: Wed, 19 August 2015, 03:07:57 »
HHKB HERE I COME and my next topre board will be the realforce 55g when i go to singapore to get it TY Brother for the reply and love you guys all
Offline Hypersphere
« Reply #16 on: Wed, 19 August 2015, 08:55:23 »
Point well taken that some features will not be to everyone's taste. You've mentioned two. Others include DIP switches, beveled front-bottom of case with anti-skid pads so that the pads make good contact with the desk regardless of whether or not the flip-out feet are used, easy-open case w/o having to access hidden screws, and LEDs for CapsLock and NumLock. I also count the lack of a hard-wired Fn key as a plus, because (in my case) I like to use remapping software to set up my own Fn key. I remap Right Ctrl as Fn and Menu as Right Ctrl. I can't do this on the NT, and I end up having a dead key on the board.
One feature I wish the RF had is a detachable USB cable, preferably (in my case) micro-USB like the NT, or the new USB-C.
