Author Topic: Cherry MX Red vs Blue for School  (Read 4424 times)
Offline ThePurpleSandwich
« on: Fri, 21 August 2015, 06:23:09 »
Hey there!
I currently own a Steelseries 6gv2, and I am planning to buy a poker ii from qtan. I will probably be using this for schoolwork, and some gaming of CS:GO. Would you recommend me Red or Blue? Thanks. :D
Offline zars15
Re: Cherry MX Red vs Blue for School
« Reply #1 on: Fri, 21 August 2015, 06:26:18 »
If you plan to use it in class, then DEFINITELY red(unless you want to piss off everyone who is studying with you). Although, it might be bit clumsy to type a lot on reds, as they are soft to press, so typo chance increases greatly.
« Last Edit: Fri, 21 August 2015, 06:28:15 by zars15 »
Offline Oobly
« Reply #2 on: Fri, 21 August 2015, 06:35:13 »
Reds or Blues?
Clears. Tactility of Blues, silence of Reds.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline zars15
« Reply #3 on: Fri, 21 August 2015, 06:43:07 »
Reds or Blues?
Heh, I'd say reds aren't too silent in reality, unless you can avoid bottoming out such light switch.
@Op: Any reason why reds and blues? Blacks would be sneakiest and easier to type on.
Offline Zorox
  • Tactile FTW <3
« Reply #4 on: Fri, 21 August 2015, 07:04:37 »
I think red suits you better at school because of its silenceness, but typo is a problem while it is linear switch. Why not try brown or clear?
Offline clacktalk
  • circa 2015
« Reply #5 on: Fri, 21 August 2015, 07:07:48 »
between the two, i'd recommend reds with springs swapped to something heavier.
otherwise, blacks or clears with springs swapped to something lighter (and lubed) haha
diary of a clacktalk
radio_killah: too much frank
« Reply #6 on: Fri, 21 August 2015, 07:58:16 »
Reds or Blues?
I currently own a 6GV2 with blacks, not a big fan of it. I want to try something new as well!
Offline azhdar
  • Praise the AZERTY god
« Reply #7 on: Fri, 21 August 2015, 07:59:18 »
what makes you dislike mx blacks?
Azerty Propagandiste
« Reply #8 on: Fri, 21 August 2015, 07:59:42 »
Reds or Blues?
I want clears too, but qtan doesn't sell them. I tried clears once and I fell in love, but it's hard for me to get here in Hong Kong. Any other sites for the Poker II or Pok3r with clears?
« Reply #9 on: Fri, 21 August 2015, 08:00:17 »
Feels a bit too heavy I guess, I just wanna try something new. :)
Offline azhdar
« Reply #10 on: Fri, 21 August 2015, 08:01:38 »
Reds or Blues?
http://corus-kb.com/en/pok3r-/19-vortex-pok3r-poker-3-pbt-black-version-alu-casing-ansi-us-international.html
Clears will be as heavy if not slightly more than blacks.
« Reply #11 on: Fri, 21 August 2015, 08:01:52 »
I thought the Poker was plate mounted? And how would you buy clear springs?
« Reply #12 on: Fri, 21 August 2015, 08:03:06 »
« Last Edit: Fri, 21 August 2015, 08:04:56 by ThePurpleSandwich »
« Reply #13 on: Fri, 21 August 2015, 08:04:14 »
Reds or Blues?
And holy crap dude, thanks for the link! Exactly what I have been looking for. Is there any way to give you an upvote like on Reddit or something?
Offline bocahgundul
  • a seal
« Reply #14 on: Fri, 21 August 2015, 08:04:54 »
BLUES FOR LIFE AND **** ALL  :p
Offline Defect
« Reply #15 on: Fri, 21 August 2015, 08:44:43 »
If you're playing CS:GO, reds
If you are bringing your KB to class, reds
If you have roommates, reds
« Reply #16 on: Fri, 21 August 2015, 09:18:41 »
If you want linear just get a cheap rubberdome keyboard. Same experience for 1/3 the price.
If you go with blues, Amazon sell ear plugs for cheap. Hand them to people with weak sensitive ears and go on with your typing.
Offline azhdar
« Reply #17 on: Fri, 21 August 2015, 09:20:14 »
you realise people are kind of interested in listenning the teacher in classroom too right?
« Reply #18 on: Fri, 21 August 2015, 09:22:30 »
I don't know how you type but I don't summon a rock band when I type with blues.
Offline jamster
« Reply #19 on: Fri, 21 August 2015, 11:04:39 »
Blues in a classroom setting would be about as polite as continually scrunching a crinkly plastic bag. You're going to piss off the whole class, and the teacher.
Get reds or browns if you have to go MX. Though if you're really in a classroom setting, it might be better off to just stick with rubber domes or a laptop keyboard. Even non-clicky MX switches are fairly loud in a tightly packed space. If you do go MX, at least throw o-rings on.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #20 on: Sat, 22 August 2015, 21:00:00 »
Yeah to be honest, blue in a classroom would be too much.  Even red is boarderline risky.
As much as I love mechanical keyboard but using it in a place with such high density might be tricky.
If you really want a mechanical for school.  I'd say maybe try matias quiet switch or topre.
But out of the two choices you listed, go red.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #21 on: Sat, 22 August 2015, 21:06:02 »
*insert topre joke
Offline FoxWolf1
  • 154
« Reply #22 on: Sat, 22 August 2015, 21:53:18 »
Buy whatever keyboard you want, then leave it at home and bring a paper notebook to class.
Less potential distraction that way, both for yourself and others.
« Reply #23 on: Sun, 23 August 2015, 00:45:17 »
Depends on how and whee you are going to use it (the keyboard).
If you are actually going to use it in class to take notes while everyone else is trying to listen, then definitely not blues.  Reds, perhaps, with O-rings to dampen the bottom out sound.
Or a silenced HHKB, which I'm surprised demik didn't suggest.
