Author Topic: What keyboards feature 8u spacebars?  (Read 4228 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Fri, 21 August 2015, 10:41:40 »
Are there a lot or only a select few?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Re: What keyboards feature 8u spacebars?
« Reply #1 on: Fri, 21 August 2015, 11:22:37 »
There was some Cherry board that had an 8u spacebar, if I remember correctly. Not sure the model number.
But the TI-99/4A used an 8u spacebar! :D
Offline 00zeRO
« Reply #2 on: Fri, 21 August 2015, 11:26:13 »
Ah, makes sense.
Cherry had these available and so we bought a lot, and well, they don't fit what we need. Would these be good for those who would like to cut/bend their own custom sizes?
« Reply #3 on: Fri, 21 August 2015, 11:39:20 »
Ah, makes sense.
The GH60 150-layout plates support an 8u spacebar, if anyone were interested in building theirs like that. :)
Offline 00zeRO
« Reply #4 on: Fri, 21 August 2015, 11:45:56 »
Ah, makes sense.
Interesting...funny side note, my last Crap Bag from SP featured an 8u SA White/Trans Spacebar which fits...we just don't have any PCBs for it atm
« Reply #5 on: Fri, 21 August 2015, 13:02:37 »
The only one I know of is the Wyse PCE - a terminal keyboard with mostly IBM Enhanced layout. They have Cherry MX.
Those that are flat above the function keys are usually PS/2-compatible.
Some were branded something else, and there are some with rubber domes.
Offline PrinsPils
« Reply #6 on: Fri, 21 August 2015, 20:26:58 »
That's a huge spacebar, and those CTRL caps are also gigantic :D
« Reply #7 on: Fri, 21 August 2015, 20:31:55 »
I think that the Leading Edge 2014 has a 9u space bar.
- D Trump 2026-10-24
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8 on: Sat, 22 August 2015, 00:01:41 »
All the terminal WYSE boards I have picked up were 9.75unit.  But here is a mind blow, IvanIvanovich, had a 15 unit but used it as a paint stirrer.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Sat, 22 August 2015, 00:08:06 »
I acquired an NCR PCB recently with what appears to be 8u black wire
