Author Topic: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Complete)  (Read 927430 times)
Offline strict
  • TKL Zealot
Re: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Shipping)
« Reply #1150 on: Wed, 04 November 2015, 23:02:33 »
Thank you very much for the suggestion for fixing the chattering issue bro. Do you have a success rate for the mod?
100% of my chattering switches are now working as expected. 10 of the 12 worked perfect after the first tweak, and the remaining two only took one more light nudge and they started behaving properly as well.
« Last Edit: Thu, 05 November 2015, 19:54:26 by strict »
Offline ideus
  • Björkö.
« Reply #1151 on: Wed, 04 November 2015, 23:03:19 »
So I'm pretty confident I found a very painless fix for the key chattering issue. You need to take a flat jewelers screwdriver and ever-so-light bend the inner-most contact toward the center post of the housing. When you are tweaking the contact, you just need to give it 3 or 4 light pushes in the direction of the center post. You should NOT feel like you're bending anything and it should NOT look like you've bent it once you're done if you did it right. The tolerances here are incredibly tight so you just need a very fine adjustment and that should fix it. I was able to fix all 12 of the chattering switches on my Phantom doing this and I didn't have to solder/desolder a single thing. From my testing this does not alter the feel or performance of the switch in any way other than fixing the chattering and early actuation.
I drew a very crude diagram to try to help explain my technique. Basically you take the contact highlighted in blue and lightly nudge it a couple of times towards the center post of the housing in red.
I'd say 100%
Awesome, cannot appreciate enough your diligence in finding a solution for this issue.
Offline tofgerl
« Reply #1152 on: Thu, 05 November 2015, 01:05:54 »
Problem found, patched and hopefully we'll find a permanent fix for the next version.
I love open source hardware!
Offline Oobly
« Reply #1153 on: Thu, 05 November 2015, 01:50:03 »
Very good work!
This leads me to believe a possible way to prevent this issue is to solder them "from the inside". What I mean is that you press the soldering iron to the inside edge of the pin (the side towards the bottom of the switch) when soldering it instead of the outside (side towards the top) for that pin.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline 3K
« Reply #1154 on: Thu, 05 November 2015, 05:40:44 »
I just thought about choosing an other weight for the mods on my Zealio board. Then I noticed something... :-X
Offline swimmingbird
  • keyset hoarder
« Reply #1155 on: Thu, 05 November 2015, 07:33:56 »
Stabs?
Offline 3K
« Reply #1156 on: Thu, 05 November 2015, 08:05:06 »
Stabs?
Yep  :(
Offline ideus
  • Björkö.
« Reply #1157 on: Thu, 05 November 2015, 08:06:05 »
Stabs?
Yep  :(
What PCB is that?
Offline 3K
« Reply #1158 on: Thu, 05 November 2015, 08:13:32 »
Stabs?
Yep  :(
What PCB is that?
A SPRiT PCB that I got in Leandrens groupbuy some weeks ago. Pretty good quality I think!
Offline cjhard
  • Claudia the Magnificent
« Reply #1159 on: Thu, 05 November 2015, 08:27:33 »
Since you haven't put the switches in yet, you can still work most of them in there if you're careful. That Spacebar is going to get weird since it doesn't have the slot for the wire like a non-universal plate would have for plate-mount stabs. You could try sliding the wire into the stabs after they're attached, but since the FaceW has the Spacebar wire towards the Alphas, it may not be a piece of cake...
Offline KaminKevCrew
« Reply #1160 on: Thu, 05 November 2015, 08:38:06 »
I can confirm that getting the space bar stab in there after the plate is on is a complete pain in the butt. My stab wire kept coming out of the stabs when I took the space bar out, and I've had to get it back in there 5 or 6 times. It takes more pressure than I really want to put on that stuff, but my switches were already soldered after I thought I had fixed the problem or I would have pulled the pcb off again (already did that twice...)
To that end, there were some stab inserts that screw into the pcb, which I'm going to use with Mira and the gold bars. Hopefully that will completely eliminate the issue. (zealios are going into that board too!!!)
Edit: that's the same plate I used! So yeah... For pressing the space bar stab in, I used the ifixit pro toolkit's wide tipped straight tweezers, but the two sides had come apart, so it's basically a very very thin flathead screwdriver.
« Last Edit: Thu, 05 November 2015, 08:40:18 by KaminKevCrew »
Offline E3E
« Reply #1161 on: Thu, 05 November 2015, 08:53:58 »
Sorry to be the bearer of bad news here, but screw-in stabs won't help. :( I use them on my Octagon and Lightpad and Gateron blanks and cherry OG, both incredibly tight-fitting on the stabs, can indeed still force the stab dummies out of their positions and cause the wire to pop out. I feel your pain though, as I had to go through it a few times, even desoldering a switch or two to get it back in there (with SIP sockets that were recessed into the PCB holes! GOD IS IT TERRIBLE TO DESOLDER THOSE UNLESS YOU HAVE CHIPQUIK, even with a vacuum-powered desoldering gun).
I'd recommend using wax carving tools (they look like dental picks) to shimmy the wires back into the stab clips. It's how I've done it. The issue is not so much with how the stabs are mounted (PCB/Plate/PCB screw-in) to the board but with how the mx mount dummies can pop out of position. It sucks, but yeah.
« Last Edit: Thu, 05 November 2015, 08:57:03 by E3E »
Offline techmattr
« Reply #1162 on: Thu, 05 November 2015, 11:48:59 »
I had 28 chattering switches and was able to fix all 28 with this method. I'm curious to see if it lasts. I would guess over a bit of time it would return to original position. We'll have to wait and see.
« Reply #1163 on: Thu, 05 November 2015, 12:20:44 »
Dang. Well, maybe I just won't swap my space bar once I put it on (I got a titanium one, so I doubt that it will get switched out frequently, because it's pretty cool.)
Offline W_hinklebottom
« Reply #1164 on: Thu, 05 November 2015, 17:28:28 »
Whoo Hoo! These things look almost too good to put caps on! Thanks Zeal
Offline AdmiralSquid
« Reply #1165 on: Thu, 05 November 2015, 17:56:39 »
@W_hinklebottom.
That is a really cool board, what PCB/Plate are you using?
« Reply #1166 on: Thu, 05 November 2015, 17:58:53 »
@W_hinklebottom.
I'm pretty sure the plate is one of the ones that leandre had on his shop.
« Reply #1167 on: Thu, 05 November 2015, 19:50:01 »
@W_hinklebottom.
I got the Plate and the PCB from Leandre's last group buy (he is doing an IC for another one now) It is a universal 60% plate designed by JDcarpe and the pcb is a Sprit Face w. The next group buy is going with winkeyless b. pcb which supports RGB LED underlighting. The switches are of course Zealios 67g tactile, best group buy I decided to pull the trigger on.
« Reply #1168 on: Fri, 06 November 2015, 06:34:31 »
Just assembled another board with Zealios last night.
Re: Soldering temp concerns with the switches
There is definitely something going on with the soldering process, and I believe it has to be heat.  I tested all my switches with a multimeter before assembling and they were fine.  After assembly, four switches chattered.  I desoldered them and installed new switches, just barely "kissing" them with heat and solder, and it worked fine.  This is not ideal from a soldering-quality perspective, which kinda bums me out, but it's what I had to do to make the board work.  :-/
Just sharing my story to add to the list of feedback.  :thumb:
@Zeal, I personally don't care at all about the fact these switches are clear (I'm in it for the lack of annoying mods needed).  Do you have any thoughts on offering a more "true" Cherry approximation that uses the original materials?  I really like the way the switches feel, I just don't like how narrow the processing window is for soldering.
If this plate accepts plate-mount stabs and you haven't already desoldered, and you really don't want to desolder, I'd be happy to send you some plate-mount stabs.
Offline Oobly
« Reply #1169 on: Fri, 06 November 2015, 07:13:41 »
...  a possible way to prevent this issue is to solder them "from the inside". What I mean is that you press the soldering iron to the inside edge of the pin (the side towards the bottom of the switch) when soldering it instead of the outside (side towards the top) for that pin.
Worth a try? Could even try to "fix" a chattering switch by reflowing with a bit of pressure and holding it long enough to soften the plastic.
I'd suggest using Cherry switch bottoms, but they will add a little just a little scratchiness to the slider movement. Prevents the slightly rough bottom out and the melting issue, though.
« Reply #1170 on: Fri, 06 November 2015, 07:25:08 »
Oh wow, I missed that post of yours.  Thanks for re-quoting!  I think the logic is sound, and I'll give it a try with the next board.   :thumb:
Offline ideus
  • Björkö.
« Reply #1171 on: Fri, 06 November 2015, 07:38:04 »
Would someone try to find the relation between strict's fix and the melting theory? Someone has tested the switches before soldering and found some casualties after it, that still point to some issues with the melting point of the switch's bottom.
I could do that when I got my switches, but, I am not sure how long that may take.
« Reply #1172 on: Fri, 06 November 2015, 07:46:41 »
My theory is that putting a little lateral pressure on the switch contact while heating the solder/pin (and subsequently melting the bottom of the switch a bit with the solder that flows down into the hole) causes the leaf inside to shift a bit towards the top (away from the center of the switch).  Strict's fix pushes the leaf just that little bit back toward the center.
Offline ideus
  • Björkö.
« Reply #1173 on: Fri, 06 November 2015, 07:49:40 »
That makes sense, it seems then that strict's fix compensates the effect of the melting bottom on the leaf contacts alignment.
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #1174 on: Fri, 06 November 2015, 11:13:35 »
Speaking of bad technique I did something a little bit different but my goal was the same as yours.  I tinned my tip with excess solder hoping that the heat stored in the solder would transfer quickly once contact was made with the joint and adding a little bit of solder to essentially flood it.  The joint looked similar to the others but who knows on the other side of the pcb?  It's been used for the past two or three days now with no issues.
Offline cjhard
« Reply #1175 on: Fri, 06 November 2015, 11:49:04 »
You could probably make that easier by throwing some flux down in there before tip touching. I've seen this technique used for SMD soldering alongside tacky flux goop.
« Reply #1176 on: Fri, 06 November 2015, 12:05:18 »
Maybe that's why I didn't have any issues. I was using flux goop.
Offline jiexi
« Reply #1177 on: Sun, 08 November 2015, 11:35:45 »
Now we need purple stabilizers
Offline Skuloth
« Reply #1178 on: Sun, 08 November 2015, 12:03:43 »
yes please
Planck w/ Zealios
Offline njbair
    • nickbair.net
« Reply #1179 on: Sun, 08 November 2015, 12:57:28 »
Are people overdoing it with the solder? I can't imagine using enough heat to cause melting like this, although all my Zealios are still sitting in the bag. But I know my iron very well and always try to use as little heat as possible.
Matias switches are clear and I've never had problems but I'm not sure if it's the same kind of plastic.
My boards:
Offline strict
  • TKL Zealot
« Reply #1180 on: Sun, 08 November 2015, 13:55:05 »
I've been soldering since I was 12 including hundreds of Playstation and Xbox mod chips (DMS and Xecuter) very successfully. I've installed thousands of Cherry and Gaterons switches at this point and never had a bit of trouble with any of them until the Zealios. I soldered mine on a relatively low temp (575F) and didn't keep the iron on the legs for anything even approaching an exorbitant amount of time but still had 12 switches on my Phantom chattering.
« Last Edit: Sun, 08 November 2015, 13:56:59 by strict »
« Reply #1181 on: Sun, 08 November 2015, 14:00:44 »
I think I was close to 700F, and that let me solder quickly, which may have had less heat bleed, and made it so none of mine melted.
Offline njbair
    • nickbair.net
« Reply #1182 on: Sun, 08 November 2015, 14:01:10 »
I've been soldering since I was 12 including hundreds of Playstation and Xbox mod chips (DMS and Xecuter) very successfully. I've installed thousands of Cherry and Gaterons switches at this point and never had a bit of trouble with any of them until the Zealios. I soldered mine on a relatively low temp (575F) and didn't keep the iron on the legs for anything even approaching to an exorbitant amount of time but still had 12 switches on my Phantom chattering.
OK well then it's clearly not a matter of skill. I'm glad mine are still in the bag so I can learn from others' experiences.
My boards:
Offline tofgerl
« Reply #1183 on: Sun, 08 November 2015, 14:28:28 »
I still think it might actually be more pushing the pins than the amount of heat. Of course, if you heat it too high so the plastic melts, that would disturb the pins...
Offline myotherteeshirt
« Reply #1184 on: Sun, 08 November 2015, 20:57:10 »
Adding in my experience here for statistical purposes:
I just put 90-odd zealios in a quickfire TK over the weekend, and found no issues so far, though i didn't use the EK switch hitter which i will try when i get home.
I had to redo some switches because the first time i forgot to put in the cherry stabs before i soldered the switches in, and then i had to fix a broken trace (secondhand board) on the enter key with copper wire - so 3x solder, 2x desolder in total on that one switch.
I use a SEEED mini soldering iron set to 300C, which google tells me is just a hair off 575F. Haven't noticed any chattering at all so far, and this is my first time soldering since school. I did examine that one switch and found no deformation of the plastic housing.
What i did was similar to filphil in that i'd tin the iron a bit more than i needed to, and once i saw the pad get shiny (i don't know if that is the best way to describe it, but it there would be a sheen that originated from where my iron touched the pad that would run around the pad - i assumed this meant the pad was hot enough or that the solder was flowing to the pad), i added more solder to the pin. Spent no more than 5 seconds on each joint.
I think we need a few sacrificial zealios to test a few situations - iron against pin to see how long it takes to deform at different temps, and iron with pressure against the pin to see if the issue is independent of housing deformation.
Offline apolotary
  • Кто-нибудь купите мои клавиатуры ;__;
« Reply #1185 on: Mon, 09 November 2015, 04:11:42 »
Got my pack of 67g Zealios today! Modded my KBParadise v60 with TEX acrylic case and a plate from LeandreN.
It took me a while to realize what these switches were reminding me of though. I'm fairly certain that they are super-close in tactility to Matias Click switches, except they don't click (duh). I'm curious to try lighter versions, as I used to be a huge fan of Matias Quiet Click switches and as far as I remember those were slightly lighter in feel than their noisy counterparts.
Overall, huge props to Gateron and Zealio for putting this out! I'm fairly happy to finally have my favorite flavor of mechanical switches in Cherry MX format without having to worry about keychattering or a shoddy micro-usb connector :)
Made a crappy typing test and comparison video for anyone interested:
« Last Edit: Mon, 09 November 2015, 06:21:56 by apolotary »
Offline Tyr
« Reply #1186 on: Mon, 09 November 2015, 13:08:28 »
Been using my 67g purple Zealio build for a week now, I had no issues with chattering or actuating to high. When I read these comments I even went to test with Switch Hitter, but it confirmed that all is normal. I soldered my build with my Aoyue on 400C with a 1,6mm chisel tip and I had to desolder 2 keys to reseat the spacebar stabiliser wire which had come loose, but those keys are fine as well. All switches have had a sip sockets installed. Super happy with the switches, I was afraid they were going to be too light as I'm coming off of mx clears but they're really comfortable.
« Reply #1187 on: Mon, 09 November 2015, 14:32:16 »
I won't claim to never make mistakes (I wish :)) ), but I've been soldering for well over 10 years and never had this issue.  I've worked to get my soldering technique up to par and try to avoid cold joints, so I apply a bit of heat, but never to the point that I'd be concerned about applying too much.
I don't feel comfortable with the technique many are suggesting of applying "just enough heat to melt the solder", because that won't give the best transfer of heat to the pad, which is important for a good joint.
But I'm just a hobbyist, so if any professionals can weigh in that'd be nice.  Maybe I've been going about it wrong and didn't realize it.  :)
Offline UTEster750
« Reply #1188 on: Mon, 09 November 2015, 23:12:33 »
I'm no pro either but I've done a share of soldering and I think what you said has merit. I think having a good temperature then just only having heat contact for as long as needed instead of a long exposure to a colder iron.
Offline Zeal
    • Zeal Generation Inc.
« Reply #1189 on: Tue, 10 November 2015, 17:09:19 »
Hey guys, just a quick update:
The remaining geekhackers spring lube was shipped today. mkawa's very sorry about the lube delays -- he's been super busy with work and also has family matters to deal with.
I expect to receive the spring lube sometime next week, and will turn around the remaining 10% of orders that are left. After that, we can finally conclude the GB. Thanks everyone. :)
Offline Lepidus
« Reply #1190 on: Tue, 10 November 2015, 17:26:11 »
Got my zealios at the same day some SPRiT springs arrived. So why not post here? :))
Although they appear to have the same weight, their "construction" is indeed very different. Yet, couldnt feel any difference, even between the 62g and 65g. Maybe my fingers are broken. :D
By order: Cherry MX clear, Zeal 65g, Sprit 62g gold plated, Sprit 65g "regular"
116942-0.
« Last Edit: Tue, 10 November 2015, 17:40:25 by Lepidus »
Offline Zustiur
« Reply #1191 on: Wed, 11 November 2015, 01:38:35 »
Got home from work early to find switches waiting for me. Yay. Now if only I had a plate and PCB ready :(
Offline alex952
« Reply #1192 on: Wed, 11 November 2015, 06:50:17 »
For me it was my first time soldering, and I only got 4 out of 76 (Ergodox) chattering ones.
I haven't really tested thoroughly, but from my experience, there might me some kind of degree of chattering, as the first keys that I noticed always double-press when I hit them, at any force whatsoever, but the last two that I realized had the same issue, do not affect my typing at all if I press them normally.
I've got 4 spares, so I guess I will be desoldering the affected ones and using those as replacements because I cannot remove the switch with it sitting in the plate  :(
Offline breitling
« Reply #1193 on: Wed, 11 November 2015, 17:19:02 »
Noticing at least a couple of the keys chattering right now. Its a bit annoying but I will try that fix that was mentioned earlier. I only have 3 extra keys so hopefully this will work or I may have to order more.
Offline cjhard
« Reply #1194 on: Wed, 11 November 2015, 17:27:48 »
Order more anyway, otherwise you won't have any for when there exists a PCB with RGB LED support and some sort of software accessible interface to control the LEDs.
Imagine your entire keyboard switching colors based on which mode you're in in vim!
Offline Oobly
« Reply #1195 on: Thu, 12 November 2015, 00:46:39 »
That keyboard case is awesome!
And I agree with Hoff, best to use a high enough heat for just enough time. You want to heat the pad with the tip more than the pin, but it still needs some for the solder to "wet" it and not form a dry joint. Tinning them before insertion may help.
I'll be replacing the Gateron Browns in my Magicforce when it arrives, but that's gonna only be in January, so I may try install a few in the Ducky PCB I have lying around to test and share my findings.
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #1196 on: Thu, 12 November 2015, 16:15:26 »
Been using my Pok3r with Zealios for a few days now with no chattering issues. Probably did the worst soldering job in the history of the world using a really cheap $10 iron and solder from China. First time soldering though to be fair. The 65gs feel great and will report back if I run into some issues in the long run. Hopefully some of the problems people are having would be resolved in the later versions of the switch. Thanks again Zeal for the great switches  ;)
Offline yowaffle
« Reply #1197 on: Thu, 12 November 2015, 16:32:56 »
May I ask why you used to be a huge fan of Matias Quiet Click? I alternate between the 65g Zealios and MQCs at work and home and am curious!
V60 [MQC] | KC60 [Zealiostotles] | Leopold FC660c [Topre] |  Ducky Shine 4 [MX Brown] | MiniVan [Zealios]
Offline breitling
« Reply #1198 on: Thu, 12 November 2015, 17:49:48 »
Just fixed all my chattering keys using the method illustrated above. I noticed the keys that had the issue were ones that the key was engaging when you just tapped the key really lightly, so it occasionally resulted in a double-press when pushed a certain way. This made it easy to diagnose which keys were having the issue as I would tap the key really lightly a few times and see if it would register a click.
I also did not want to desolder my key switches and realized I could reach that contact without removing the key switch and just push the stem down all the way and insert a very thin jewelers screwdriver into the space between the stem and the case and it is just enough room to bend that contact back.. it definitely works 100% for me so far on about 4 switches. Some of the function and lock keys its harder to tell if its chattering.
Thanks guys for all the help in this thread, very useful.
For the record, I soldered at 450 degrees using a small chisel tip.. not sure the measurement.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #1199 on: Thu, 12 November 2015, 18:00:18 »
Zeal, quick question I saw your not above regarding orders with lube, what about the orders with cables? Will those be going out in a similar time frame?
