Author Topic: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Complete)  (Read 933259 times)
Offline wilarseny
Re: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Shipping)
« Reply #1250 on: Tue, 24 November 2015, 05:18:27 »
I've now done a second board with Zealios (65g this time, rather than the 67g of the first) and again have 0 problem keys. To be honest, the soldering is even worse this time - I somehow got worse at it, and I'd be ashamed if anyone else saw the bottom of this PCB.* It makes me really doubt that soldering is at issue unless people are jamming the iron all the way down under the pad and somehow touching the switch bottom, or at putting on so much solder that it's dripping through the hole and melting the area around the pin. Are the chattering keys showing up for people with PCB builds, or handwire? I could see a handwire build going a bit more awry heat-wise, but I've never done one so not sure.
Impressions - the 65g feel much closer to ergo clears than the 67g do. It's amazing that 2g of resistance can make this much difference. I think I overall prefer the 67g - they feel much snappier, there's a really nice bounceback after the keypress which is missing to some small degree in the 65g (though it's still present, just a bit less). I prefer heavier switches in general though so YMMV. The 67g are also a more "unique" switch to me - again, the 65g are pretty close to ergos to me, while the 67g don't feel like any other switch I've tried (including Topre, though I understand the comparison now). Hopefully the 62g tactile come back with round 2 so I can be financially irresponsible enough to build a 3rd Zealios board!
* A fully transparent case was a bad choice in this regard, as cool as it looks otherwise.
What type of soldering iron are you using? If you're using some cheapo without temp regulation that actually might be helping keep you from melting the base as it wouldn't be capable of holding a consistent temperature. The downside is sloppy soldering and cold joints.
Could be. It's a Weller WLC100, which runs about $40 on Amazon. It does have temp control but I've felt like anything below the highest setting is too low to melt the solder quick enough for my tastes. Does burn pretty hot especially after tinning - and I tin probably more than I need to given my noob-ness - but no idea to what extent the temps are dropping while on the pin. Why I say my soldering sucks is usually the opposite problem, really - I'm melting the solder pretty quickly and usually ending up with beading, but it doesn't look like a cold joint (from what I've seen). Most of my joints look like the furthest-to-the-right image in this pic: https://learn.adafruit.com/system/assets/assets/000/001/978/original/tools_Header_Joints.jpg?1396777967
Offline cjhard
  • Claudia the Magnificent
« Reply #1251 on: Tue, 24 November 2015, 08:03:40 »
Has anyone been able to get QMX clips to clip to Zealios? My first attempts are looking like these products are incompatible.
EDIT: Tested with a Cherry MX switch, Zealio is only slightly harder to attach these things, but they do go on!
« Last Edit: Tue, 24 November 2015, 16:57:48 by cjhard »
Offline dragon788
« Reply #1252 on: Tue, 24 November 2015, 08:12:05 »
Got my Zealios and lube, sadly no Binge cap. Now just waiting for the damn infinity Ergodox, or perhaps I'll build my own on the Dox PCB my friend ordered from Falbatech.
Offline techmattr
« Reply #1253 on: Tue, 24 November 2015, 10:52:50 »
Yeah the WLC100 has temp control but not regulated at the tip. Though from your description your probably melting the solder onto the pin rather than using heat to flow the solder onto both contact points. It may not look like it but that is creating a cold joint. If you gobbing a bunch of solder on there though it may never be an issue. Typically cold joints cause an issue by cracking and separating under pressure or stress. Since these parts shouldn't really endure any of that they could very well be fine.
I've found that any amount of heat required to flow the solder against the pins causes the base to start melting. The issues comes in when as others have mentioned... you apply pressure to the pin causing the leaf to move out of position. If you melt the base enough then it'll just move on it's own due to the pressure from the contact.
Offline Steezus
  • Keeper of Facts
« Reply #1254 on: Tue, 24 November 2015, 10:57:36 »
I used 290C on my Weller WESD51 and had absolutely no problems. I only ended up having one cold joint for my ESC LED but that was an easy fix. Other than that all my switches are no with no chattering or double register issues. Obviously since the switches are soldered on I can't really get a good look at them to see whether or not the base has melted but I highly doubt it. I was pretty quick with my soldering and have had quite a bit of practice over the years.
Offline ika
« Reply #1255 on: Tue, 24 November 2015, 15:58:12 »
I wonder if instead of the actual plastic melting, people are just pushing the middlemost contact towards the leaf as they solder (pushing the pin towards the center -> smaller gap in the contacts = earlier activation). I use a conical tip and when I solder my pins, I do add a little bit of leverage in order to apply heat to both the PCB trace and the pin at the same time. For those of you who have had a lot of chattering switches, do you push the pins when you solder?
Offline breitling
« Reply #1256 on: Tue, 24 November 2015, 16:45:23 »
Just fixed all my chattering keys using the method illustrated above. I noticed the keys that had the issue were ones that the key was engaging when you just tapped the key really lightly, so it occasionally resulted in a double-press when pushed a certain way. This made it easy to diagnose which keys were having the issue as I would tap the key really lightly a few times and see if it would register a click.
I also did not want to desolder my key switches and realized I could reach that contact without removing the key switch and just push the stem down all the way and insert a very thin jewelers screwdriver into the space between the stem and the case and it is just enough room to bend that contact back.. it definitely works 100% for me so far on about 4 switches. Some of the function and lock keys its harder to tell if its chattering.
Thanks guys for all the help in this thread, very useful.
For the record, I soldered at 450 degrees using a small chisel tip.. not sure the measurement.
Can you further detail exactly how you did it through the top? I attempted to do strict's fix using your instructions. From the stem hole I found I was only able to affect the front "half" of leaf bend (the bend facing towards the stem), and wasn't able to do what strict said he did. I tried both pulling and pushing that leaf and couldn't fix the chattering. I did, however, kill the bump a little bit :blank:. Are you levering the switch leaf from the back towards the middle/stem, or pushing it towards the back, away from the stem?
Sorry I missed this until now.. If you haven't solved the problem yet, here is how I did it, I don't really have photos though. If I understand what you're saying, you had trouble reaching the front of the switch leaf in order to pull it back towards the plastic stem, correct? You are only able to reach the back side of the switch leaf and push it away from the stem, which does not solve this problem.
If that's the case, you may need something thinner than what you are using.. I have a thin jewelers screwdriver which I used to get in there and get in front of the switch leaf and pull it back towards the plastic stem. Its quite deep in there but I have solved all my keys 100% and I am loving these switches now.
Offline ika
« Reply #1257 on: Tue, 24 November 2015, 16:52:00 »
Were you pulling the small contact (the one closer to the middle) or the bent leaf itself?
Offline breitling
« Reply #1258 on: Tue, 24 November 2015, 17:44:34 »
Yes - I was pulling the Blue circled contact towards the centre plastic stem which was circled in red, in essence nudging the two metal contacts further apart. This is the post pic I was referring to:
https://geekhack.org/index.php?topic=74807.msg1923515#msg1923515
Offline tofgerl
« Reply #1259 on: Wed, 25 November 2015, 14:34:58 »
You guys know you can solder without so much as touching copper, right? Put the solder between the tip and the contact.
« Reply #1260 on: Wed, 25 November 2015, 15:27:27 »
You can get it to stick, but it won't really be the best joint without giving it sufficient time to heat the contact anyway, at which point why bother?
Offline tofgerl
« Reply #1261 on: Wed, 25 November 2015, 15:33:37 »
Of course it will heat the contact, but I'm talking about the suggestion that people are bending it.
Offline ideus
  • Björkö.
Re: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Complete)
« Reply #1262 on: Sun, 29 November 2015, 00:20:52 »
My order for Zealios has arrived, they were soldered in my new GON and there was no chattering, at all. I had no special precautions, I just use the same basic procedure with the same cheapo soldering station.
They feel smooth and the sound is very silence.
Thank you Zeal.
Offline myotherteeshirt
« Reply #1263 on: Sun, 29 November 2015, 10:20:17 »
I'm snipping the legs off more Zealios to put in another keyboard and I noticed that the pin under the G in gate Ron when viewed from the top is wobbling. It would seem that there is too much clearance in the bottom casing for the contact.
I checked the green razers I just pulled out, and there's no give on either pin.
Could the actuation problems be from that?
Offline trenzafeeds
  • **** off
« Reply #1264 on: Sun, 29 November 2015, 10:40:50 »
There's always the chance that your soldering iron just couldn't get up to the temperature required to damage the zealios. Glad to hear you had no problems though! How are you enjoying the switches?
demik will never leave.
Unless he gets banned.
Offline asgeirtj
« Reply #1265 on: Sun, 29 November 2015, 15:22:07 »
Wish there was a 66g option :)
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Zeal
    • Zeal Generation Inc.
« Reply #1266 on: Sun, 29 November 2015, 15:52:12 »
I desoldered a Zealio to mount my Viper's capslock key off-centre for a photo shoot, and I did not notice any melting "rings" around the pin as seen from a few pictures. My iron stays at 650F/343C with 0.02" 63/37 Kester 44. Just throwing that figure out there cause to this day, I have not experienced any issues with the Zealios.
If you pull the coils apart ever so slightly, it'll become 66g. :P
Offline cjhard
« Reply #1267 on: Mon, 30 November 2015, 08:33:49 »
After swapping springs in my Alphas, my chattery T key is now my chattery G key. Maybe some of the plungers are a little extra roomy at that dip just before the tactile bump?
Offline E3E
« Reply #1268 on: Mon, 30 November 2015, 20:37:06 »
Just put in an order for some linear Zealios, the ones almost no one mentions! Mainly because I started on linears and still have a very dear affection for them, not to mention their quietness which is preferred for my daily driver. Secondly, because I wanted a fully clear switch that would diffuse light from bottom LEDs.
If I ever want to go tactile, I'll probably swap stems with vintage MX clear stems. :3 Happy to finally be part of the Zealio buy, even if it was more a Black Friday - Cyber Monday sale. :P
« Last Edit: Mon, 30 November 2015, 20:39:07 by E3E »
Offline ideus
  • Björkö.
« Reply #1269 on: Mon, 30 November 2015, 20:53:28 »
Did I get a good batch of switches? all of them worked well with no chattering at all. I am typing on them now, they feel great.
Offline ari
« Reply #1270 on: Tue, 01 December 2015, 03:43:25 »
Depending on how you soldered them in, not necessarily.  I need to get some better measurements made [under a microscope], but the physical difference between a chattering switch and a clean one is as little as 0.01mm, +/- 0.00025mm.
If this theory is right, this problem cannot be seen in linear switches; it will only present on tactiles, and even then, only on some tactiles.  The tolerences here are small enough that hamfisted soldering could introduce it - or just pressure at the right angle on the leg of the stationary contact.  But it can - and does - present these symptoms on never-soldered switches...
I gave Zeal a heads-up with the core details already, but I need some better measurements before I'm comfortable posting everything.  I'm hoping to have a full write-up late this weekend.
(Also, hi, finally got off my arse and registered an account instead of lurking.)
Offline kekstee
« Reply #1271 on: Tue, 01 December 2015, 04:39:03 »
Used the 67g Variant in an ISO GON 60. And I'm very happy with the result, no issues to report.
I don't have switches that are quite like it, and given lighter 45g HHKB Topres I can't follow that analogy either.
It's probably the heaviest switch I see myself using and enjoying to use. So I guess I'm happy I went with 67g instead of the more ErgoClear like variants. :)
Offline E3E
« Reply #1272 on: Tue, 01 December 2015, 05:15:46 »
Glad to hear that it won't affect linear versions, as that's what I recently picked up! I did put together two boards for customers who provided purple Zealios and I had little issue there. One had two chattering switches prior to soldering. There were no issues post-soldering with any switches.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #1273 on: Tue, 01 December 2015, 07:27:15 »
I need to order more 67g switches. Bought another keyboard I want expecting.
Offline E3E
« Reply #1274 on: Tue, 01 December 2015, 07:32:54 »
It's comforting to know I'm not the only one, hahaha.
Offline ideus
  • Björkö.
« Reply #1275 on: Tue, 01 December 2015, 07:44:22 »
I love the plate mounted Zealios, as much as I do love Ergo Clears PCB mounted. The sound of the last while plate mounted is high in pitch, while Zealios sound deeper.
    • WTB/WTTF Thread
« Reply #1276 on: Tue, 01 December 2015, 08:35:34 »
Leeku's 1800 buy got to me  :))
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #1277 on: Tue, 01 December 2015, 08:48:23 »
I soldered up my 67g Zealios on a GON 60 and didn't have any issues with chattering switches. I am not a soldering expert by any stretch of the imagination. I was expecting issues, but was happily surprised to find none.
Great switches. Thanks, Zeal!
Offline edel781
« Reply #1278 on: Tue, 01 December 2015, 17:12:13 »
I'm having no issues with my 62g linears. Thanks Zeal :D
Offline E3E
« Reply #1279 on: Tue, 01 December 2015, 17:41:24 »
Aww yeah, good to see another linear junkie!
Offline edel781
« Reply #1280 on: Tue, 01 December 2015, 17:56:48 »
#linears4life  :cool: :cool: :cool:
Offline ctm
  • Hello, world!
« Reply #1281 on: Thu, 03 December 2015, 21:24:56 »
Any chance I can get a sampler kit in US? I would like to get a few Zealio tactile switches to have a try, but 15 dollars shipping from ZealPC is too expensive for a 5 dollars purchase.
Coming:
Ellipse Model F F62.
Offline Zustiur
« Reply #1282 on: Sat, 05 December 2015, 02:49:46 »
So I'm pretty confident I found a very painless fix for the key chattering issue. You need to take a flat jewelers screwdriver and ever-so-lightly bend the inner-most contact toward the center post of the housing. When you are tweaking the contact, you just need to give it 3 or 4 light pushes in the direction of the center post. You should NOT feel like you're bending anything and it should NOT look like you've bent it once you're done if you did it right. The tolerances here are incredibly tight so you just need a very fine adjustment and that should fix it. I was able to fix all 12 of the chattering switches on my Phantom doing this and I didn't have to solder/desolder a single thing. From my testing this does not alter the feel or performance of the switch in any way other than fixing the chattering and early actuation.
I drew a very crude diagram to try to help explain my technique. Basically you take the contact highlighted in blue and lightly nudge it a couple of times towards the center post of the housing in red.
I have also fixed 9 keys this way. One was stubborn but it worked eventually.
To clarify, I'm using 'precision screwdrivers' such as you'd use on a watch or on the arms of your glasses. They're tiny and cheap. Push the stem down with one of the larger screwdrivers, then  using the smallest flat head you've got in the set, push the clear plastic under the word 'Gateron' forward. As you do this, the thicker of the two pieces of copper should become visible. Push the screwdriver down a bit further, inserting it between the plastic and the copper. Tweak the copper towards yourself (assuming the word Gateron is the right way up!). Some will require a bit more pushing than others.
I'm convinced that this does tie into the melting issue. I do not have a variable temperature iron, and I suspect my iron is a bit hotter than some. Having made a really stupid error in building my keyboard I had to do a lot of desoldering and ended up melting quite a few of the switches to one degree or another. It became really apparent that if you put any pressure on the thicker leg of the copper while heating that it can melt the plastic just enough to move. Thankfully I only destroyed one switch completely but I can see how it happens. So here's an extreme example of what I'm talking about.
This switch is dead, the stem wouldn't even go down at all, but the keys I've fixed had all moved that thicker leg in the same sort of way.
Offline swimmingbird
  • keyset hoarder
« Reply #1283 on: Sat, 05 December 2015, 20:56:40 »
Man that is painful to look at
« Reply #1284 on: Sun, 06 December 2015, 09:34:12 »
After weeks of attempts, I present: razer chroma feat: zealios!
119260-0
119262-1
119264-2
No problems with ek switch hitter so far!
Interestingly, it seems that some LEDs affect the others - some LEDs didn't display some colours until I had all the LEDs soldered in.
Offline E3E
« Reply #1285 on: Sun, 06 December 2015, 09:41:19 »
Wow, excellent use of the 4 pin RGB LEDs. It's a great way to really show what the Zealios were intended for.  So awesome. If you could put it in a more low key case, it'd be one of the neatest full-size boards ever. :D
Either way though, it looks fantastic. Kudos to your hard work. :)
Offline Zeal
« Reply #1286 on: Sun, 06 December 2015, 14:31:58 »
This may be the first Razer Chroma board with Zealios :P
Great job, kudos on you desoldering 522 through whole joints...and then soldering them back!
Offline trenzafeeds
  • **** off
« Reply #1287 on: Sun, 06 December 2015, 17:39:10 »
Ugh, I hate desoldering. You are right in saying that is quite an achievement.
« Reply #1288 on: Mon, 07 December 2015, 02:14:20 »
Thanks! It was definitely an interesting experience.
I feel like the keyboard was built like a bloody tank - Getting to the pcb itself was an ordeal, and i think it had plated-through holes on a double sided pcb, which made it that much more of a pain! Looks like razer really doesn't want people getting into their keyboards.
Luckily, with advice from Zeal and you other guys on geekhack, i managed it!  :D :D So props to everyone!  ;D ;D
Anyway, now i'm feeling a bit sad that the light effect from the clear switches are hidden by stock razer keycaps - so any suggestions? I like the idea of jelly white POMs for diffusion but they seem hard to find.
P.S. I had two chattery keys this time - fixed them with strict's method, although now one seems to have less of a bump. The less-bumpy one has been relegated to the FN key.
« Last Edit: Mon, 07 December 2015, 02:24:35 by myotherteeshirt »
Offline dragon788
« Reply #1289 on: Tue, 15 December 2015, 07:44:09 »
I think Max keyboards has some clear caps, or at least mostly transparent.
Offline PrinsPils
« Reply #1290 on: Thu, 17 December 2015, 20:13:01 »
Zeal, any plans for a second run?  :cool:
Offline Zeal
« Reply #1291 on: Thu, 17 December 2015, 20:49:44 »
Very soon^tm
Offline PrinsPils
« Reply #1292 on: Fri, 18 December 2015, 05:52:15 »
Very soon^tm
Awesome! do you have maybe 1 or 2 switches left over of the clicky switches. I checked your website but they are out of stock and would like to try some switches before i purchase 200.
Offline Zeal
« Reply #1293 on: Fri, 18 December 2015, 11:18:15 »
Very soon^tm
The clicky switch moulds haven't been made yet, it's still a concept phase.
Offline tofgerl
« Reply #1294 on: Fri, 18 December 2015, 12:22:52 »
I assume he meant tactile.
If you do mean tactile, PM me, I have a couple extras if you pay postage. But note that I live in Norway, so the postage fees will be steep, and the speed slow.
Offline Tuntematon
« Reply #1295 on: Sat, 19 December 2015, 15:32:10 »
What's the design plan for the clicky switch? 65g ultra-smooth, lower-pitched (than MX blue) blue Alps imitation?  :)
Offline asgeirtj
« Reply #1296 on: Wed, 23 December 2015, 13:59:49 »
For anyone wanting to change their 62/65's to 67 originative does offer 67 springs.  I did this.  As far I can tell the spring weight is the same even though the springs look very different.  It might be that originative's ones are a tad lighter but I can't be sure really, would be awesome if someone would be able to confirm or deny this though
Offline tofgerl
« Reply #1297 on: Wed, 23 December 2015, 14:49:13 »
So will the Original(tm) tactile Purple(tm) Zealios(tm) be getting a new order alongside the new ones?
I ordered 100, which was a weird choice, since I knew I would be using them for 60% keyboards... So now I have 30-ish left and nothing to do with them...
Offline potatowire
« Reply #1298 on: Wed, 23 December 2015, 22:23:43 »
It took me a while to gather everything, but here is my first Zealio build.
I love them.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #1299 on: Thu, 24 December 2015, 08:27:37 »
I love them.
Looks great! Love the Nerd60 peeking out. What plate and case is that?
