Author Topic: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Complete)  (Read 933352 times)
Offline Ngt
Re: [GB] PURPLE/CLEAR ZEALIO SWITCHES (Shipping)
« Reply #1100 on: Tue, 03 November 2015, 02:31:53 »
Thanks Zeal for the switches. I just received them this morning. They look really nice. I just need a case to put them into now! :D
Offline gadzkun
« Reply #1101 on: Tue, 03 November 2015, 02:41:40 »
aw, im new at GH and im just now realize this awesome switch...
i want to ask is there a plan for this round 2 GB? hhe..
Offline UTEster750
« Reply #1102 on: Tue, 03 November 2015, 03:16:11 »
Pretty sure Zeal is taking feedback, improving the switches and then possibly having a round two with improved switches.
That's the impression I got from previous comments from him, feel free to correct me :)
Offline icyskyz
« Reply #1103 on: Tue, 03 November 2015, 03:33:08 »
There are plenty of 65g and 67g switches in stock as far as I know. Unless 62g are the only ones you want.
My collections - flickr | HWS Keyng Collector |
Offline gadzkun
« Reply #1104 on: Tue, 03 November 2015, 03:41:05 »
wow this is a great..
improved an improved switch. how much it will improved :cool:
i hope for clicky switch next round :p
Offline zhihuichan
  • Click,click,click
« Reply #1105 on: Tue, 03 November 2015, 03:43:35 »
Used purple switches for a week. It's very fantastic!
Offline UTEster750
« Reply #1106 on: Tue, 03 November 2015, 04:17:07 »
Might have to talk to Zeal nicely for that one  ;)
Offline gadzkun
« Reply #1107 on: Tue, 03 November 2015, 04:26:54 »
hahaha zeal will probably see it. my dreammmmssss xD
but im sure i will get a purple ones when my wallet ready.
this november too much good stuff my wallet already hacked too much xD
Offline UTEster750
« Reply #1108 on: Tue, 03 November 2015, 04:28:39 »
I have schoolies at the end of the month so I need to stop spending money  :-X
Offline braidn
« Reply #1109 on: Tue, 03 November 2015, 07:01:19 »
Contemplating a gaming build with some liners next month. Anyone have some opinions of the Zealio liners over clear Gaterons with spring mods?
Offline Malicium
« Reply #1110 on: Tue, 03 November 2015, 08:57:23 »
Now I need to buy a new iron, I don't want to mess up my zealios switch with my first price iron  :-[
Offline ideus
  • Björkö.
« Reply #1111 on: Tue, 03 November 2015, 09:05:43 »
I would replace the bottoms with translucent ones before soldering, instead.
« Reply #1112 on: Tue, 03 November 2015, 09:07:35 »
The clear housing was a huge selling point of the switches.
Offline ideus
  • Björkö.
« Reply #1113 on: Tue, 03 November 2015, 09:09:24 »
But it appears to require some re-thinking in the plastics blend to be functional, even if the look suffers a little.
Offline baldgye
  • Will Smith Disciple
« Reply #1114 on: Tue, 03 November 2015, 11:01:47 »
Just got my package in the mail today and god damn these switches are so nice, really can't wait to get them on my board. Thanks so much Zeal!
Offline ika
« Reply #1115 on: Tue, 03 November 2015, 11:05:41 »
I had a 1% failure rate in my switches. Plently of others have had none. It's a function of soldering skill as well.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #1116 on: Tue, 03 November 2015, 11:07:23 »
All 60 switches I used worked fine, and it was my first time ever soldering so I would think I would have screwed them up if a level of skill was required. Anyway, I really like the switches, they feel great  :thumb:
Offline ideus
  • Björkö.
« Reply #1117 on: Tue, 03 November 2015, 11:07:37 »
Soldering procedure helps; however, it does not happen with Cherry or other Gateron, at all.
Offline RoastPotatoes
    • RoastPotatoes Keyboard Blog
« Reply #1118 on: Tue, 03 November 2015, 11:53:57 »
I currently have 8 out of the 48 I have used for my planck. The handwiring aspect does not help with overheating of the pins. There is one switch where I went right through. There is also one which I haven't bothered to replace as it is intermittently chattering.
Offline cjhard
  • Claudia the Magnificent
« Reply #1119 on: Tue, 03 November 2015, 12:29:50 »
If you are hand wiring, would it be impossible to use a heat sink?
Offline chromatically
« Reply #1120 on: Tue, 03 November 2015, 12:33:55 »
Waiting on zealios 67g and they're going on an infinity ergodox.
Looking like I'm going to drop my Hakko down to 550f or so?
Using kester 60/40 .8mm
Offline Zeal
    • Zeal Generation Inc.
« Reply #1121 on: Tue, 03 November 2015, 12:40:36 »
I used 650F on my 951sxe with a medium fat (around 4mm) chisel tip. Kester 44 63/37 0.021"/0.53mm solder. Did not have any issues with my Viper. You need to find the sweet spot where your iron is hot enough to melt the solder effectively, but not on the pins/traces for too long enough to spread the heat too far. Too low of a temp and you're heating pads/pins for too long, too hot and the pad isn't fully heated.
Offline GhostofHarry
« Reply #1122 on: Tue, 03 November 2015, 12:53:59 »
WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW
THIS IS ONE REVOLUTIONARY PRODUCT
gold plated spring, clear case, smoother switch stem, is this dream?
finally have free time to browse around GH and im immediately attracted to this thread!
GJ Zeal!
I am more interested about the part of the 4 pin RGB LED option for the switch.
As I recently planned to build a board for one of my friend, and I am kind of out of touch...
Are the any current PCBs which are capable to handle these LED?
I'm definitely gonna use them for my projects!
« Last Edit: Tue, 03 November 2015, 13:07:20 by GhostofHarry »
Offline Zeal
« Reply #1123 on: Tue, 03 November 2015, 13:03:41 »
GJ Zeal!
I'm definitely gonna use them as highest level parts for my projects!
Only Kailh/Razer (and a few domestic mainland China) keyboards support the 4pin RGB LEDs. Aftermarket DIY PCBs that support 4 pin RGB LEDs are still being developed.
Offline Zeal
« Reply #1124 on: Tue, 03 November 2015, 13:06:10 »
BTW, here's a crosspost of my Viper built with 65g lubed Zealios.
Typing video @~100wpm (lower sound until no white noise -- that's how it sounds irl, super quiet:
Sound only (more accurate, camera in front of spacebar)
« Reply #1125 on: Tue, 03 November 2015, 14:04:21 »
holy &%AWD%&^%@#$(@$
beautiful.
cool, thanks for the tip. I'm experienced with an iron but want to make sure I don't melt any of the housings heh... I'd be very sad :P I did get 90 just in case I screw up so I'll have extras.
Offline ideus
  • Björkö.
« Reply #1126 on: Tue, 03 November 2015, 14:29:06 »
It is a very nice board. The silver case goes well with those HFs.
Offline skaloola
« Reply #1127 on: Tue, 03 November 2015, 14:37:13 »
Suggestion for round 2, don't know if it's feasible, but ..
preinstalled SIP sockets as an option would be spectacular.
also, is every recommended part of the switch lubed or just the springs?  specifically the slider or bottom of switch housing?
I've got some stickered ergoclears that feel much smoother on bottom out.
anyone try stickering these to see if it helps with the switch wobble?
Offline cjhard
« Reply #1128 on: Tue, 03 November 2015, 20:27:30 »
I would suggest arranging for a proxy to do switch customizations instead if you're into that.
Some people bought lube with their switches for a reason.
Stickers won't really help with the switch wobble, it's not a problem with the housing moving around, it's all in the size of slider vs the hole it's encased in. I think this was done to prevent catching, but Zeal can correct me if I'm spreading lies. If you want to decrease wobble, you'd use something to fill that space such as copper tape, as has been suggested in this thread.
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #1129 on: Tue, 03 November 2015, 20:40:24 »
Finished up soldering my zealios.  I alloted 90 switches for my 86-key orion v2 with three having a chattering issue/actuating above the tactile bump after soldering and one switch top breaking as I mentioned earlier in the thread.  Glad I just made it!
My next 90 will be reserved for the MIRA whenever it decides to happen.
Offline slushi
« Reply #1130 on: Tue, 03 November 2015, 20:45:02 »
Sorry if this was already mentioned, but which version of the purple zealios did you use?
 HHKB Pro 2
Offline filphil
« Reply #1131 on: Tue, 03 November 2015, 20:47:05 »
Straight 62g zealios
Offline ideus
  • Björkö.
« Reply #1132 on: Tue, 03 November 2015, 21:00:56 »
You got a lower percentage of chattering units than others, did you have some special care while soldering?
Offline filphil
« Reply #1133 on: Tue, 03 November 2015, 21:14:29 »
Yep.  I kept up with the thread and was hoping that by keeping the time my soldering iron made contact with the pin and joint to an absolute minimum it would cut down on the chances of any "melting".  The switches that did have issues had some deformation at the base where the pins protrude.  Obviously with the switches that didn't have any issues I can't say because those weren't pulled.
Offline wilarseny
« Reply #1134 on: Tue, 03 November 2015, 21:29:13 »
I also finished soldering my switches tonight. Had only 1 switch that just didn't work, but it wasn't the activation above bump issue or the chattering issue that folks have been talking about. It just didn't register anything at all.
No special care taken on the soldering, mostly out of inexperience - I learned to solder literally this morning so I don't think it was probably especially well done. I also had to desolder about 6 switches because of my messups, and none of those switches ended up having issues either. I used a Weller WTS100 at max heat. Probably just got lucky with an especially problem-free batch!
My first impressions on the 67g tactile switches is generally very positive. I didn't like their feel with SA caps, but swapping over to a GMK set made the clickiness come alive. Very nice bounce to the keys - feels really crisp and enjoyable to type on. Like em even more than the ergo-clears on my GON, and that's saying something.
Offline ideus
  • Björkö.
« Reply #1135 on: Tue, 03 November 2015, 21:35:32 »
This is very interesting, that makes the melting theory a little bit weaker.
Could this may be related with the weight of the caps?
Do you have pictures of the deformations you reported? Could those be seen at simple sight?
« Last Edit: Tue, 03 November 2015, 21:52:52 by ideus »
Offline Uhmkevinkev
« Reply #1136 on: Tue, 03 November 2015, 21:45:18 »
I am using 6 Zealio linear in my fight stick and i love it compared to the reds.
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #1137 on: Tue, 03 November 2015, 22:46:40 »
Finally got my bface assembled with my 67g Zealios and WOW  :thumb: GREAT job Zeal!
All the kustom 60s
Offline filphil
« Reply #1138 on: Tue, 03 November 2015, 22:47:46 »
You can see the deformation very easily. I'll have pictures when I get back home.
Offline wilarseny
« Reply #1139 on: Wed, 04 November 2015, 02:30:51 »
Re: the heat thing: sounds right. I mean, I don't know if my iron was that hot, even at max heat - it's one of the lower-end Weller and the less-than-max settings were barely melting the solder (standard 60/40 rosin). I dunno, maybe the solder job is better than I think, but I doubt it. It does seem weird to me that something like heat transfer / melting point of the switch case bottom would be inconsistent set-to-set - since it's a property of the material seems like that wouldn't change much. But I'm far from an expert on the materials side of things.
Re: the feel of SA: I think it's partly the key weight and partly the fact that these seem to have just a bit more side-to-side travel than standard Cherry MX. I haven't had Gateron before so not sure how they compare. But I felt like keys were traveling in not-purely-up-and-down directions a bit more often than I'm used to, and that's a lot more noticeable / unpleasant with the taller SA keys.
I will say that after slightly more extended use tonight, I'm really starting to love the clear housing, especially w/ having these on a WKL board with RGB bottom LEDs. It's a nice subtle glow around the key bottoms that almost completely eliminates the urge for in-switch LEDs for me, at least in this build. I do hope we eventually see some custom PCBs allowing for in-switch RGB to take advantage of that neat future-proofing of the Zealios.
Offline UTEster750
« Reply #1140 on: Wed, 04 November 2015, 03:26:13 »
I really do hope that when I get my SA keycaps that my 67g switches feel ok  :-X
I also need to order a pcb for my ergodox already so I can test these switches  :thumb:
Offline trenzafeeds
  • **** off
« Reply #1141 on: Wed, 04 November 2015, 05:17:26 »
It sounds like the issue is the side-to-side travel, I'd try out Oobly's copper tape mod if I were you.
demik will never leave.
Unless he gets banned.
« Reply #1142 on: Wed, 04 November 2015, 14:55:01 »
I got mine today. Really smooth. Smoother than my lubed Cherry Clear sliders in Gateron housings. :)
Offline UTEster750
« Reply #1143 on: Wed, 04 November 2015, 16:20:29 »
This will be my first mech, so I doubt I'll even notice a problem, but I'll try that if I do have a problem  :thumb:
Offline derpingit
« Reply #1144 on: Wed, 04 November 2015, 16:29:39 »
got my set in. thanks, zeal :D
Offline asgeirtj
« Reply #1145 on: Wed, 04 November 2015, 16:35:23 »
Just to chime in I've soldered 2x 104 key boards already with 65g zealios and 1 switch do a double entry 50% of the time.  I use a entry level soldering gun and it even leaves burn marks on the pcb, I think it runs too hot (but I can't configure it).
Btw just finished my doing my Leopold fc900 with 65g lubed zealios with latex & trampoline mod, it is silent as ****.  Maybe the quietest mech in the galaxy? (it also has noise dampening foam on the inside).
65g seems perfect for a work board, I'm going to put 62g into my starcraft ii board (octagon) and I'm pretty sure 67g is too heavy for me.
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline VentureG
« Reply #1146 on: Wed, 04 November 2015, 17:04:46 »
I tried my hand at key hitter for about 10 minutes and I only had one non-reproducible issue with a single switch.
Any whoozle, to echo Zeal's sound test these switches are super quiet. Even though I type way harder than Zeal (from what I can tell, in the video), I got similar results in my sound test:
Fantastic.
Offline strict
  • TKL Zealot
« Reply #1147 on: Wed, 04 November 2015, 22:53:13 »
So I'm pretty confident I found a very painless fix for the key chattering issue. You need to take a flat jewelers screwdriver and ever-so-lightly bend the inner-most contact toward the center post of the housing. When you are tweaking the contact, you just need to give it 3 or 4 light pushes in the direction of the center post. You should NOT feel like you're bending anything and it should NOT look like you've bent it once you're done if you did it right. The tolerances here are incredibly tight so you just need a very fine adjustment and that should fix it. I was able to fix all 12 of the chattering switches on my Phantom doing this and I didn't have to solder/desolder a single thing. From my testing this does not alter the feel or performance of the switch in any way other than fixing the chattering and early actuation.
I drew a very crude diagram to try to help explain my technique. Basically you take the contact highlighted in blue and lightly nudge it a couple of times towards the center post of the housing in red.
« Last Edit: Thu, 05 November 2015, 19:54:47 by strict »
Offline ideus
  • Björkö.
« Reply #1148 on: Wed, 04 November 2015, 23:00:19 »
So I'm pretty confident I found a very painless fix for the key chattering issue. You need to take a flat jewelers screwdriver and ever-so-light bend the inner-most contact toward the center post of the housing. When you are tweaking the contact, you just need to give it 3 or 4 light pushes in the direction of the center post. You should NOT feel like you're bending anything and it should NOT look like you've bent it once you're done if you did it right. The tolerances here are incredibly tight so you just need a very fine adjustment and that should fix it. I was able to fix all 12 of the chattering switches on my Phantom doing this and I didn't have to solder/desolder a single thing. From my testing this does not alter the feel or performance of the switch in any way other than fixing the chattering and early actuation.
Thank you very much for the suggestion for fixing the chattering issue bro. Do you have a success rate for the mod?
Offline Steezus
  • Keeper of Facts
« Reply #1149 on: Wed, 04 November 2015, 23:02:02 »
I'd say 100%
