Author Topic: Will I die...  (Read 3099 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Will I die...
« on: Tue, 01 September 2015, 20:21:25 »
If I fill my tank tomorrow while the car is running?
Starter is dying and can't miss school tomorrow. It barely started today after practice, already ordered new one...
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Will I die...
« Reply #1 on: Tue, 01 September 2015, 20:22:24 »
I feel like that's a thing you are definitely not supposed to do
Offline fknraiden
Re: Will I die...
« Reply #2 on: Tue, 01 September 2015, 20:28:49 »
Friend did it once without realizing. Almost had a heart attack. I'm alive
Offline C5Allroad
Re: Will I die...
« Reply #3 on: Tue, 01 September 2015, 20:30:59 »
Supposedly, nothing will happen. But really don't wanna be stuck there when I'm trying to change my schedule tomorrow, that'd suck if I was stuck there... It'd be interesting to see a tow truck maneuvering there to pick it up and tow it to the shop so I can put the new one in, I think oil is leaking on to it from the filter. Not too sure.
Mother did it once too... I ran out of that car as if I was gonna die. She told me to turn it off if I felt like it, felt like I was defusing a bomb.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Will I die...
« Reply #4 on: Tue, 01 September 2015, 20:33:23 »
I see people do this all the time, and it drives me crazy. I know that the car isn't going to blow up, but all I can think is that if it does, we are all going to die, not just the person that is doing it.
So, you aren't going to die, but on the off chance you do, you are going to take everyone else with you.
Offline njbair
    • nickbair.net
Re: Will I die...
« Reply #5 on: Tue, 01 September 2015, 20:46:02 »
It's not going to blow anything up. Worst case scenario, your check engine light will come on due to minor air bubbles in the fuel lines.
If you're really worried about it, pump the gas slowly to avoid too much splashing around in the tank.
My boards:
Re: Will I die...
« Reply #6 on: Tue, 01 September 2015, 20:49:06 »
You mean your supposed to shut your car off? I fill up all the time with the vehicle running while talking on my cell phone. Gas must not be as flammable as they say.
Offline beehatch
  • baehatch
Re: Will I die...
« Reply #7 on: Tue, 01 September 2015, 20:51:38 »
I'm confused. You're going to have to start it in the morning anyway right?
Well... why can't someone just fill up a gas can for you right now, you fill-up your car, and that way you don't have to start it twice?
edit:
I mean, if it's such a ***** to get it to run... Or you can do the fill-up while the car is on.
**** if I know, I don't even have a car
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Will I die...
« Reply #8 on: Tue, 01 September 2015, 20:52:54 »
TIL you dont even have to turn your car off
Re: Will I die...
« Reply #9 on: Tue, 01 September 2015, 20:58:15 »
you're the reason we have warning signs
Offline C5Allroad
Re: Will I die...
« Reply #10 on: Tue, 01 September 2015, 21:42:45 »
I choose to blame gm for the warning signs. The starter is dying. My allroads starter was still good after 123k miles
njbair, I guess I'll slowly pump...
I just want to get to school tomorrow.
Offline invisuu
Re: Will I die...
« Reply #11 on: Wed, 02 September 2015, 02:35:51 »
 Why would anything blow up? Gas (as in the liquid that runs your car) doesn't even explode in liquid form, it just burns.
Offline C5Allroad
Re: Will I die...
« Reply #12 on: Wed, 02 September 2015, 19:56:49 »
I have survived!
Re: Will I die...
« Reply #13 on: Wed, 02 September 2015, 20:07:45 »
Haha, yeah I don't know what the big deal is. I mean, the gas in the tank isn't exploding, so why would the gas you're pumping into the tank explode? I guess if you created a spark while you were filling the tank it could blow, but it could do that with the engine off.
Offline njbair
    • nickbair.net
Re: Will I die...
« Reply #14 on: Wed, 02 September 2015, 21:28:01 »
The concern is that the sloshing of fuel into the tank will introduce air bubbles into the fuel system, which is only an issue if the fuel lines are pumping in new fuel while the new fuel is splashing down into the tank and making bubbles. The extra air throws off the air-fuel ratio, which could cause larger explosions than the engine was designed to handle. But modern cars have so many sensors and safeguards that it's not really a big deal if you do it once in a situation like this one.
My boards:
Offline mattbox
Re: Will I die...
« Reply #15 on: Wed, 02 September 2015, 21:37:45 »
You'll be fine, but maybe don't add too much gas
