Poll
Which option are you most interested in?
PCB only
16 (11.3%)
PCB + Eagle Plate
26 (18.4%)
PCB + Viper Plate
57 (40.4%)
PCB + both plates
42 (29.8%)
Total Members Voted: 141
Author Topic: [IC] Leeku Eagle/Viper PCB (ISO+ANSI) + plate [PROJECT CANCELLED]  (Read 142938 times)
Offline apaskal
    • Pro et Contra gadget reviews
Re: [IC] Leeku Eagle/Viper PCB (ISO+ANSI) + plate
« Reply #100 on: Fri, 25 December 2015, 11:35:47 »
I guess I have to go with this layout :)
121552-0
BTW I missed PCB programming/controller info. Is it teensy based?
« Last Edit: Fri, 25 December 2015, 11:40:07 by apaskal »
My personal blog —  Pro et Contra gadget reviews!
Offline Hypersphere
« Reply #101 on: Fri, 25 December 2015, 12:31:31 »
Still interested, especially if Alps is an option.
More interested in Viper than Eagle, but only if it is possible to source a Viper case for the true HHKB look.
Offline WhitePlate
  • First Grader of Nobody
« Reply #102 on: Wed, 06 January 2016, 14:27:28 »
I'm interested in a PCB and Plate for a viper!
Offline swimmingbird
  • keyset hoarder
« Reply #103 on: Thu, 21 January 2016, 17:53:07 »
Late but interested
Offline amharris
« Reply #104 on: Sun, 24 January 2016, 18:27:36 »
For the folks - such as myself - who weren't a part of the community at the time of the original Viper and Eagle GBs (or would just like another opportunity to get the board again), I wonder if you'd be able to combine this venture with Duck to get a relaunch but with Leeku's PCB?
I wonder if anyone else has similar thoughts.
Offline azhdar
  • Praise the AZERTY god
« Reply #105 on: Sun, 24 January 2016, 18:35:35 »
I don't think that will be possible to have Viper case remade.
Pcb will be happening for sure, when is still uncertain.
Azerty Propagandiste
Offline alexjd99
  • oozing through the cells of one's own construction
« Reply #106 on: Sun, 24 January 2016, 19:03:39 »
I'm sure it's possible to have the case remade in some way. Not the exact same case, but at least something aluminum with the bottom keys, wouldn't it be? I, along with probably quite a few other people, would be more willing to join if an HHKB case would be possible.
Either way, still going to join because of the PCB  :))
  • keyset hoarder
« Reply #107 on: Sun, 24 January 2016, 19:30:19 »
Probably so much effort to remake the base that its just better to wait for v2 next year if the Hubble MIRA project is any sign of how hard it is to get a non sandwich style board made domestically
« Last Edit: Mon, 25 January 2016, 05:10:05 by swimmingbird »
Offline bocahgundul
  • a seal
« Reply #108 on: Sun, 24 January 2016, 19:44:06 »
This could be used with hammer case right? Just like e3e board right?
I'm interested
Offline amharris
« Reply #109 on: Mon, 25 January 2016, 02:07:13 »
Indeed; and if everything was Libre,  this would be infinitely easier.
Well, one could always aim to make an improvement on the originals. :)
Offline db268
« Reply #110 on: Wed, 27 January 2016, 13:47:03 »
I would be interested in 2 PCBs if it supports Alps switches. Is it confirmed yet?
Offline azhdar
« Reply #111 on: Wed, 27 January 2016, 13:55:09 »
as of now mx only.
Offline livingspeedbump
    • KeyChatter
« Reply #112 on: Sat, 30 January 2016, 22:42:58 »
Would buy a viper set for sure.
<- My Collection (so far)
Offline lootbag
« Reply #113 on: Sun, 14 February 2016, 05:14:58 »
Bump for Viper PCB and plate!
I want extras for my Viper and am looking for a more intuitive keymapping software.
Using TMK with my HHKB and then going to Duck software for the Viper... not the best experience.
Offline FreeChemicals
« Reply #114 on: Fri, 19 February 2016, 06:54:29 »
hey azhdar, could you give a short update?
Offline azhdar
« Reply #115 on: Fri, 19 February 2016, 08:18:22 »
leeku very very very busy, we're looking at spring now to start this again.
Plan is still :
- make a 60% pcb (name vulture ) with regular 60% standoffs + Duck Eagle specifics standoff so that the pcb fits nicely both type of cases,
- make a cut corner 60% pcb (named cobra) with Duck Viper standoffs,
- Stainless steel plates for both ok those pcb (no removable switch top)
 Layout we had last time we worked on it :
(green ones are for cobra).
This will happen 200%, I have a Viper at home, and it's unusable (because ANSI). One of my first keyboard dream was an Azerty Viper, and I'll make it happen.
Offline KaLam1ty
« Reply #116 on: Fri, 19 February 2016, 13:00:36 »
Something like..
R4: [1][1.5][---2.75---][1.5][---2.75---][1.5][1]
would be so baller. Need so many SHIFT keys though  :-X
Offline alienman82
« Reply #117 on: Fri, 19 February 2016, 13:14:34 »
removed.
« Last Edit: Thu, 01 March 2018, 16:06:02 by alienman82 »
Offline apaskal
« Reply #118 on: Fri, 08 April 2016, 08:04:02 »
Any good news?   :)
« Reply #119 on: Fri, 08 April 2016, 08:18:28 »
No it wouldn't. The difficult part isn't the design; it's finding a good manufacturer.
Offline azhdar
« Reply #120 on: Sat, 23 April 2016, 03:22:05 »
Things have changed, this won't happen.
  • keyset hoarder
« Reply #121 on: Sat, 23 April 2016, 03:32:47 »
Offline jorgenslee
« Reply #122 on: Sat, 23 April 2016, 08:55:01 »
So sad to hear that.
I hope at least we could fork a tmk firmware for viper
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #123 on: Sat, 23 April 2016, 08:58:18 »
Rip viper dreams  :(
Offline StormyMonday
« Reply #124 on: Sat, 23 April 2016, 10:24:31 »
Damn the things ... all of them!    :mad:
