Poll
Which option are you most interested in?
PCB only
16 (11.3%)
PCB + Eagle Plate
26 (18.4%)
PCB + Viper Plate
57 (40.4%)
PCB + both plates
42 (29.8%)
Total Members Voted: 141
Author Topic: [IC] Leeku Eagle/Viper PCB (ISO+ANSI) + plate [PROJECT CANCELLED]  (Read 142940 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
Re: [IC] Leeku Eagle/Viper PCB (ISO+ANSI) + plate
« Reply #50 on: Wed, 16 September 2015, 05:17:50 »
This is kinda side-tracking the GB, but just wanted to mention that if possible, I would love to see some coordination/support for the Viper PCB/plate and the SkiDatum60% case.
It would be really cool to have them be compatible, and build our very own Skidata HHKB ;)
https://geekhack.org/index.php?topic=74248.0
Just thought I'd mention it. I'm sure it's just a matter of making sure the holes on the case line up with the plate/PCB holes of the PCB, and making sure the PCB dimensions fit the case.
Either way, I'm quite excited about the entire GB :thumb: Will get an extra plate/PCB for my Eagle, as well as a Viper set, if the case compatibility can be ensured.
Offline azhdar
  • Praise the AZERTY god
« Reply #51 on: Wed, 16 September 2015, 07:32:36 »
An eagle/viper pcb doesn't share all the standoffs of a "regular 60%" but enough that the pcb should hold tight. I have a viper sitting in my living room at, I'll verify but I'm pretty sure it's the same 7 standoffs that on eagle.
If Njbair design the case with standard standoffs I don't see how it wouldn't fit in his case.
Regarding the split spacebar I'll see what I can do, but case mounting holes aren't the only problem, various holes for switch positions and switch stabilizers make the pcb look like gruyere, some holes might override some others so not everything is possible.
« Last Edit: Wed, 16 September 2015, 07:50:49 by azhdar »
Azerty Propagandiste
Offline azhdar
« Reply #52 on: Thu, 17 September 2015, 01:34:59 »
Bottom sides RGB will be available.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #53 on: Thu, 17 September 2015, 01:39:25 »
Greatting !
Offline themagicat
« Reply #54 on: Sun, 20 September 2015, 18:05:23 »
I'm interested in a viper PCB and plate
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #55 on: Sun, 20 September 2015, 18:24:41 »
Will either pcb fit a standard 60% case?
Sorry if this was asked before.
Offline Karura
  • SKidata life.
« Reply #56 on: Sun, 20 September 2015, 19:24:33 »
It is unconfirmed, but I have requested it with the PCB designer, and it is being considered.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #57 on: Sun, 20 September 2015, 19:25:45 »
Thanks for the reply. I hope at least a couple of screws/standoff will fit.
I'll definitely keep an eye on this thread for the response then!
Offline jorgenslee
« Reply #58 on: Sun, 20 September 2015, 20:18:18 »
See this post by quochung,
I checked with my Viper PCB with FMJ housing.
This is some pics:
You can just mount 4 holes, no more. I think it's enough reliable to use.
This is only personal idea. You should thinking to give decision.
Offline azhdar
« Reply #59 on: Mon, 21 September 2015, 04:04:29 »
See this answer also :
https://geekhack.org/index.php?topic=74953.msg1866578#msg1866578
We should be able to add the center hole of standard 60% case on our design.
The bottom one will not.
We're still working on the design of pcb & plate the layouts offered can be validated.
Offline themagicat
« Reply #60 on: Mon, 21 September 2015, 07:49:22 »
Sorry, new to this forum... How do I vote?
Offline DanielT
« Reply #61 on: Tue, 22 September 2015, 06:50:21 »
This is interesting, in this case I would be interested in one PCB too. I don't have a Eagle/Viper case and getting one is close to impossible, so compatibility with a standard case is something really cool. I can live without the bottom mounting hole  :thumb:
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #62 on: Tue, 22 September 2015, 09:51:27 »
Me too! I've got a vortex case lying around... unused..  ;D
Offline Lurch
« Reply #63 on: Tue, 22 September 2015, 10:02:11 »
this is exciting. really hope this comes to fruition soon. :thumb:
Quote from: Flyersfan1
Offline potatowire
« Reply #64 on: Tue, 22 September 2015, 16:23:27 »
I would insta-buy a Poker-compatible Eagle PCB and plate.
Offline StormyMonday
« Reply #65 on: Tue, 22 September 2015, 18:52:55 »
That's a given. The real question, is whether to buy one set, or two!  :-*
Offline potatowire
« Reply #66 on: Tue, 22 September 2015, 18:55:39 »
I'm leaning towards two...
Offline azhdar
« Reply #67 on: Wed, 23 September 2015, 02:42:10 »
Thanks for the support guys, it is still being worked.
Making a plate to support all the various layouts and yet include duck standoffs + regular 60% standoffs is tricky.
Can't launch before we figure this out.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #68 on: Wed, 23 September 2015, 05:02:02 »
Yeah, no worries. Cheers man for doing this.
Take your time.  :)
Offline potatowire
« Reply #69 on: Wed, 23 September 2015, 10:25:41 »
Take your time.  :)
Agreed!
Offline themagicat
« Reply #70 on: Wed, 23 September 2015, 16:48:42 »
When do you anticipate this to be shipped?
Offline azhdar
« Reply #71 on: Thu, 24 September 2015, 01:24:12 »
Considering the 2-3months of design/production that will be done as soon as the GB is launched I think early 2016 is the most realistic ETA (since december will probably a hard time to ship/work).
Offline azhdar
« Reply #72 on: Fri, 16 October 2015, 10:53:44 »
This is still worked on, sadly Leeku is very busy lately and has no time to work on it at the moment.
So yeah more delays  :-[
Anyway it's something that will happen, I have a viper on the way, and may I be damned if I ever use it in ANSI  :))
Layout that SHOULD be available (changes may occur, we want to offer a way to split the 7u spacebar too) :
Green ones are for the viper.
The pcbs will be named Vulture for the Eagle Replica and Cobra for the Viper Replica.
  • Frenzy Classic.
« Reply #73 on: Fri, 16 October 2015, 11:15:36 »
I like name "Cobra"  ^-^
Offline alienman82
« Reply #74 on: Fri, 16 October 2015, 12:41:28 »
removed.
« Last Edit: Thu, 01 March 2018, 17:11:17 by alienman82 »
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #75 on: Sat, 17 October 2015, 08:25:26 »
Nicely done!
I'll most prob get the Vulture. I don't have a proper case for the Cobra and I'm afraid it might look weird having gaps at the corner.  :-\
Offline ideus
  • Björkö.
« Reply #76 on: Sat, 17 October 2015, 08:30:46 »
It does not make sense to offer the "Cobra" with no case; because, there is no HHKB style cases available, but GON's and Sprit's, the first is very expensive, and the second is not available now, and both works with their own PCBs, they do not required an special one. Some may want to install it in regular 60% cases, but the corners should be filled with addons that will not look good, defeating the overall purpose of a HHKB style PCB that is mainly to look like an actual HHKB.
Maybe as an spare part for those that already owned a Viper, but that's it.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #77 on: Sat, 17 October 2015, 08:31:50 »
It does not make sense to offer the "Cobra" with no case; because, there is no HHKB style cases available, but GON's and Sprit's, the first is very expensive, and the second is not available now. Some may want to install it in regular 60% cases, but the corners should be filled with addons that will not look good, defeating the overall purpose of a HHKB style PCB that is mainly to look like an actual HHKB.
Yeah, that was my main concern. Oh wells, the "Eagle" isn't that bad either tbh.  :)
Offline azhdar
« Reply #78 on: Sat, 17 October 2015, 11:18:42 »
The Cobra is made to get into a duck Viper case, we don't plan to have standard 60% standoffs on the Cobra.
For HHKB style that are offered by GON and Winkeyless.kr AFAIK it's a standard 60% without corners removed, so the Vulture would work for it.
I don't know how the Srit's one is designed.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #79 on: Sun, 18 October 2015, 07:55:07 »
So if I were to get the hhkb layout case from winkeyless, it would fit this pcb then? I'm talking bout the Cobra  :)
  • Frenzy Classic.
« Reply #80 on: Sun, 18 October 2015, 09:00:17 »
I think it's good to use. Except some holes you can't use.
I only guess when I compare between Eagle & Viper PCB.
Offline azhdar
« Reply #81 on: Sun, 18 October 2015, 09:43:39 »
I just explained above that winkeyless.kr use regular 60% for his HHKB style cases. I'm not even sure a non winkeyless.kr pcb would work (I'm not certain on how it's mounted).
Offline ideus
  • Björkö.
« Reply #82 on: Sun, 18 October 2015, 09:46:36 »
I wrote winkeless guys some weeks ago, about the use of a GON with their sixty case and they say no. I even ask them to sell me one to try the GON Nerd60 by myself and they say no.
Offline zhihuichan
  • Click,click,click
« Reply #83 on: Mon, 19 October 2015, 22:39:46 »
The viper case is also wanted !!
Offline alienman82
« Reply #84 on: Sun, 08 November 2015, 10:04:24 »
removed.
« Last Edit: Thu, 01 March 2018, 17:02:05 by alienman82 »
Offline azhdar
« Reply #85 on: Sun, 08 November 2015, 10:41:37 »
want so bad!
So do I, leeku is very busy with this project : https://geekhack.org/index.php?topic=76617.0
As soon as his schedule get better, we'll work on this.
Offline alienman82
« Reply #86 on: Sun, 08 November 2015, 11:14:46 »
removed.
« Last Edit: Thu, 01 March 2018, 17:02:01 by alienman82 »
Offline KaLam1ty
« Reply #87 on: Mon, 09 November 2015, 07:58:57 »
Thanks for keeping up with this project anyhow. I'm very interested in a Cobra.
I don't have a Viper case, but I plan to get a custom woodcase build to spec-wise to support it.
Probably laser cut will be the easiest. I assume you will be posting the final PCB/measurement plans when this all goes through?
Offline tern21
« Reply #88 on: Mon, 09 November 2015, 23:26:12 »
So will there be any option for having the 1u keys on the right hand side of the spacebar or is that completely out of the design?
Offline skaloola
« Reply #89 on: Tue, 10 November 2015, 09:48:39 »
Count me in
Offline azhdar
« Reply #90 on: Tue, 10 November 2015, 13:08:16 »
Sadly this is out of the design since it gets in the way of the duck mouting positions.
As of today, there is no plan to make case, and it would have to go through Duck approval anyway.
But I will be able to give measurment in the end.
Offline tern21
« Reply #91 on: Tue, 10 November 2015, 19:36:23 »
:( that makes me so sad, would have bought it otherwise. It is only one screw though...  :'( Is there any other PCBs that have 1u spacing there?
Offline alienman82
« Reply #92 on: Sat, 14 November 2015, 13:21:48 »
removed.
« Last Edit: Thu, 01 March 2018, 16:59:06 by alienman82 »
Offline Frigid
« Reply #93 on: Sat, 14 November 2015, 19:58:31 »
Do you know what the price point will be?
Offline azhdar
« Reply #94 on: Sat, 14 November 2015, 20:09:38 »
Chatted with leeku the other day, he's still very busy with his compact SQ GB and other keyboard projects.
Anyway my viper is on the way and will gather dust until I can ISO it so you can be sure this is happening.
Expect it to be around 100-110$ shipped to you for a pcb+plate.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #95 on: Fri, 04 December 2015, 14:08:53 »
On the Cobra PCB/Plate, that will have a full bottom row? Not like the actual Viper? Just trying to understand how a case would work. If one does get the Cobra, would you simply be able to trim the plate/PCB to remove the unwanted area, or are those traces needed for other connectivity?
I'm interested in the Cobra, but not if I can't get a case in the style I'm after. Also, for full disclosure, there was talk about making cases in this style (and others) in my thread. In thinking about this, a drop in style case would be ideal, but of course would only work if the PCB/Plate supports it. Having a case with a top and bottom shell is not quite as simple to make happen - at least not for me.
Offline trenzafeeds
  • **** off
« Reply #96 on: Mon, 07 December 2015, 02:09:16 »
I think that was rather the point, seeing as the viper was the same way. Not sure though, I wouldn't be snapping mine anyways.
****ing awesome. I would totally buy one of these, no question at all.
demik will never leave.
Unless he gets banned.
Offline azhdar
« Reply #97 on: Tue, 08 December 2015, 08:13:36 »
This got discussed with leeku, there will be 2 differents pcb.
Viper & eagle was a single pcb because there wasn't so many bottom rows so it didn't get on the way.
For you case project it's totally doable to use a "non-cut" 60% pcb to achieve hhkb layout. The winkeyless.kr hhkb case are done like that . ( check my collection in my signature, I have one if you have never seen it).
Regarding this project no work as been put into it lately as leeku is still busy, I still plan to realise it. No timeframe sadly :x
Offline Hypersphere
« Reply #98 on: Sun, 13 December 2015, 12:39:06 »
I just now discovered the Duck Viper. I posted an IC for someone (other than myself) starting a new GB for the kit, and I was referred to your IC for just the PCB and Plate. You option appears to be the viable one, and I am interested.
My motivation is that my favorite form factor is 60% and my favorite layout is HHKB, but I am looking for a way to accommodate switches other than just Topre into such a keyboard. In particular, I am interested in Alps (and clones, such as Matias) and the relatively new mx clone, the Purple Zealio switches.
To summarize:
Layout: HHKB with split Right Shift (1.75 + 1.00) OR Eagle/Standard 60%, but with split Right Shift (1.75 + 1.00). However, I could live with a completely standard layout with the conventional 2.75 Right Shift and 1.25 mods on the bottom row.
Switches: Alps/Matias and/or Cherry mx (Zealio)
Stabilizers: Prefer plate-mounted Costar-type, but I could work with whatever goes with the Viper/Eagle plates and PCBs.
Plate Finish: Matte black preferred, but open to other finish types.
Case Compatibility: Standard, such as TEX 60% CNC case. Would want the Alps and Cherry Plates/PCBs to be compatible.
LEDs: I would prefer not to have LEDs.
Thanks for organizing this.
« Last Edit: Sun, 13 December 2015, 12:42:57 by Hypersphere »
Offline azhdar
« Reply #99 on: Sun, 13 December 2015, 13:01:25 »
To summarize:
Hey I read your thread about Duck Viper kit, I'm not sure what you want to achieve with this since it has been run already and Duck isn't known for his reruns.
Anyway to answers your question:
Layout : https://geekhack.org/index.php?topic=74953.msg1897609#msg1897609
Switches: never though of Alps, I'll check with leeku if it possible I know he had mx+ALps on his 3000 pcb so it should be possible.
Stabilizers: will be cherry pcb mounted, no discussion on this point.
Plate finish: will be stainless steel plate, up to you to paint it or w/e
Case compatibily: it's being designed to have duck standoffs + standard 60% standoff to fit both type of case.
You'll find more information in the topic.
And to update people that are looking forward for this: I should have a Viper in my hands in about a week or so, I'll try my best to speed this up. And I'll repeat, this will happen.
