Author Topic: [GB] ComPact SQ - 1800 Inspired [COMPLETE]  (Read 432512 times)
Offline meiosis
  • Time
« on: Sun, 01 November 2015, 20:42:29 »
Posting this up for my friend Leeku, he is a well known PCB designer in Korea who works with many keyboard makers.
He will be posting in this thread if there are any questions you might like to ask, and this is most likely just the start of a long line of group buys.
This is the same PCB used in the LZ-CP, but this time in an acrylic based case.
CPSQ
Compact SQ:
Black Acrylic:
Icy Acrylic:
More pictures here:
http://imgur.com/a/Ti6iK
http://imgur.com/a/N5k07
Required:
L3 PCB: $50
+ $10 for soldering diodes/resistors
Acrylic Case +Plate: $55
Add on:
Additional Acrylic Plate: $10
Additional Acrylic Top (Icy/Black): $10
Steel Plate: $30
Aluminum Skin (Top/Bottom): $60
-Order options:
Required : PCB + SQ Acrylic case + Plate
Optional : Alu Skin , Translucent top
Shipping : 25$
Order Form:
Deadline 11/21/2015
http://goo.gl/forms/DApgwji7LL
« Last Edit: Wed, 22 June 2016, 21:02:02 by Meiosis »
Keyboards:
Aripeko TKL
Offline meiosis
  • Time
Re: [GB] Compact SQ - 1800 Inspired [Taking orders]
« Reply #1 on: Fri, 06 November 2015, 19:18:28 »
-reserved-
« Last Edit: Sat, 07 November 2015, 16:10:30 by Meiosis »
Keyboards:
Aripeko TKL
Offline Våtdräktsman
« Reply #2 on: Sat, 07 November 2015, 16:03:24 »
ISO compatible?
Offline meiosis
  • Time
« Reply #3 on: Sat, 07 November 2015, 16:13:50 »
ISO compatible?
Yes, just look at the plates :).
Keyboards:
Aripeko TKL
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #4 on: Sat, 07 November 2015, 16:14:37 »
That price is killer.  Must resist.    :'(
Offline tuantruong
« Reply #5 on: Sat, 07 November 2015, 16:22:21 »
Order submitted. Now the waiting game begins. ^-^
Any estimate on shipping?
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #6 on: Sat, 07 November 2015, 16:23:42 »
Are there any pictures of the Alu skin set?
Offline meiosis
  • Time
« Reply #7 on: Sat, 07 November 2015, 16:29:22 »
lifezone is making the alu skin (will be similar to his 1800 kit)
As well as the steel plates
Keyboards:
Aripeko TKL
Offline ika
« Reply #8 on: Sat, 07 November 2015, 16:48:25 »
alu skin should look simila toe this:
https://geekhack.org/index.php?topic=74357.0
Offline breitling
« Reply #9 on: Sat, 07 November 2015, 17:21:46 »
On the Google form when I put 0 for the acrylic top and bottoms it says the number has to be greater than 0... do we have to buy all of the acrylic tops as well? Or am I doing it wrong? I want the aluminum skins.
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« Reply #10 on: Sat, 07 November 2015, 17:25:07 »
Pretty sure you can just leave it blank if you don't want any.
Offline breitling
« Reply #11 on: Sat, 07 November 2015, 17:37:44 »
Ah okay thanks.
Offline captvizcenzo
« Reply #12 on: Sat, 07 November 2015, 18:24:03 »
When would this shipping out?
Can I include a set of stabilizers in my order? How much would it costs?
Thinking of getting one basic set.  :)
Offline clochette
« Reply #13 on: Sat, 07 November 2015, 18:34:12 »
based on the reply from leeku himself on reddit, stabs would cost $10
just write what your require in the last box for assembly
Offline yicaoyimu
« Reply #14 on: Sat, 07 November 2015, 18:51:02 »
I wonder how the bottom looks. Does it come with layered acrylic feet like those B series acrylic case?
Offline meiosis
  • Time
« Reply #15 on: Sat, 07 November 2015, 18:58:43 »
This is a picture of mine but it was a prototype the spacing has been changed
Keyboards:
Aripeko TKL
Offline clochette
« Reply #16 on: Sat, 07 November 2015, 19:44:58 »
When is the actual dead line?
30th or 21st?
Offline ccc24
  • HHKB , Ergodox
« Reply #17 on: Sat, 07 November 2015, 19:53:21 »
along with the diodes and resistors can we have stabs and led backlighting installed as well?
« Reply #18 on: Sat, 07 November 2015, 20:01:44 »
Saw this on reddit. Must have.
The acrylic case can be used without the aluminum akin if I ordered the skin, right?
« Last Edit: Sat, 07 November 2015, 20:06:33 by romevi »
Offline Butter
« Reply #19 on: Sat, 07 November 2015, 20:05:11 »
Do I have to solder on the RGB case led?
Offline elton5354
« Reply #20 on: Sat, 07 November 2015, 20:07:17 »
Any more colour options for the top acrylic piece?
« Reply #21 on: Sat, 07 November 2015, 21:16:27 »
nice
Offline gadzkun
« Reply #22 on: Sat, 07 November 2015, 21:35:14 »
what is "middle (30)" in the form means? the case is only 2 layer from what i see (top and bottom) or am i wrong?
« Reply #23 on: Sat, 07 November 2015, 21:42:08 »
I think that's the layer that holds the plate, PCB, etc.
Offline Dreamre
    • kbdlife
« Reply #24 on: Sat, 07 November 2015, 21:42:26 »
Who will be shipping out these when the GB is done?
Offline whmeltonjr
« Reply #25 on: Sat, 07 November 2015, 21:46:54 »
Any plans for any other styles, or just 1800?
Offline leeku
« Reply #26 on: Sat, 07 November 2015, 22:19:27 »
In this year hopefully. Thanks.
Offline leeku
« Reply #27 on: Sat, 07 November 2015, 22:21:08 »
Not prototyoed yes. It would look like LZ's Aluskin. I will update as soon as I got the proto. Thanks
Offline leeku
« Reply #28 on: Sat, 07 November 2015, 22:22:27 »
I will ask to a friend in US, otherwise I can ship directly.
Offline umeboshi
« Reply #29 on: Sun, 08 November 2015, 00:14:25 »
Will the PCB fit a G8x-1800, and if so, will PCB's and plates be offered separately?
Offline meiosis
  • Time
« Reply #30 on: Sun, 08 November 2015, 01:56:06 »
No but he does have 1800 PCB's designed already I believe kbdhub is stocking some.
Keyboards:
Aripeko TKL
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #31 on: Sun, 08 November 2015, 11:40:17 »
So let me do a quick calculation:
Required:
- L3 PCB: $50 + $10 for soldering diodes/resistors
- Acrylic Case +Plate: $55
- Steel Plate: $30
- Aluminum Skin (Top/Bottom): $60
- Shipping : 25$
Total: $230
Minus $90 if you don't need a steel plate nor alu top: $140
That is almost a steal. Any chance of ordering additional PCBs?
I have an 1800 case that was for another project that never went through.
|||My other keyboards :
x
Offline ccc24
  • HHKB , Ergodox
« Reply #32 on: Sun, 08 November 2015, 12:56:26 »
do the smd leds or whatever leds used for backlighting come pre-installed as well?
Offline jaffers
« Reply #33 on: Sun, 08 November 2015, 13:06:53 »
I was in on this drop within the hour of it hitting reddit, ohhhhh yea
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #34 on: Sun, 08 November 2015, 16:00:03 »
Congrats to Meiosis and Leeku for finally getting the thread approved. :thumb:
I've already posted in the SKIDATA+ thread, but just wanted to reiterate that the Compact SQ and SKIDATA+ will go perfectly together due to the 1800 support. :)
This is by far the best price I've seen for a custom Korean keyboard, and I highly recommend not missing out on this.
Offline clochette
« Reply #35 on: Sun, 08 November 2015, 16:56:54 »
have you received your invoice?
Offline ccc24
  • HHKB , Ergodox
« Reply #36 on: Sun, 08 November 2015, 18:26:18 »
any guides on the firmware or how to program it? And are the back lighting leds come installed as well?
Offline leeku
« Reply #37 on: Sun, 08 November 2015, 19:06:36 »
There is a GUI for key mapping and setting the preference, JigOn. http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=2702787
Sorry for Korean thread. I will updates a guide in English soon.
And yes back lighting LEDs installed as well. All need to do is solder the SWITCH and switch LEDs in case you want.
Offline leeku
« Reply #38 on: Sun, 08 November 2015, 19:11:55 »
Required:
- Steel Plate: $30
- Shipping : 25$
Total: $230
This PCB is slightly different with original 1800 layout. The 1st row is stick to 2nd row. :o.  You can buy 1800 compatible PCB on kbdhub.com.
Offline leeku
« Reply #39 on: Sun, 08 November 2015, 19:12:39 »
Offline daviswalkers
  • HHKB Amature 2
    • Graphic Design Portfolio
« Reply #40 on: Sun, 08 November 2015, 21:13:43 »
If I bought a 1800 PCB and Plate on KBDHub will this case work then or would I need to order a whole new pcb/plate?
Compact-SQ |          VE.A
 65g Zealios    |      78g Zealios
Offline yicaoyimu
« Reply #41 on: Sun, 08 November 2015, 21:27:38 »
Look at the space between F row and number row. This GB has compact 1800 layout in that there is no space between F and number row while there is in normal 1800 layout. So 1800 PCB and plate won't work with this case.
  • HHKB Amature 2
« Reply #42 on: Sun, 08 November 2015, 21:33:18 »
Damnit I only got that from them because it was said they would have this case for sale with it and now it seems the case won't even work with it :/ guess I'll have a 1800 pcb/plate for sale once I get them which hopefully can happen before this is over
Compact-SQ |          VE.A
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #43 on: Sun, 08 November 2015, 22:33:28 »
Just trying to decided between the black acrlyic or the full Alu.... Such a nice layout and awesome pricing.
Also, very nice to see you positing, leeku  :thumb:  I've seen lot's of your creations on GH, it would be nice to own one!
Offline Kempher
« Reply #44 on: Sun, 08 November 2015, 22:44:39 »
A quick question, and forgive me if it comes off as noobish. Regarding the plate, will the acrylic plates allow for the switches to be customized without doing any additional soldering, or will that only be possible with the steel plate? Also will the steel plate be visible in a top/bottom translucent acrylic setup?
SQ-1800 /w Gateron Blacks
« Reply #45 on: Sun, 08 November 2015, 22:58:40 »
Hi Leeku. I would really want to know when this would ship out. ;)
I assume the basic kit will go out sooner than the aluminum skin? But still, when?
Offline umeboshi
« Reply #46 on: Sun, 08 November 2015, 23:46:07 »
Thanks, although seems like kbdhub is out of business...
Offline kiwi99
  • that's a gnarly dookie
« Reply #47 on: Mon, 09 November 2015, 00:14:10 »
How thick will the alu top/bottom layers be? will there be silver screws to match the top?
Offline leeku
« Reply #48 on: Mon, 09 November 2015, 02:49:22 »
It is 2mm Alu on top of 3mm Acrylic transparent. and yes the screw will be the same color with each top(translucent for translucent, black for black, silver for silver)
Offline leeku
« Reply #49 on: Mon, 09 November 2015, 02:53:12 »
Technically? Possible. For GB cost, however, I should gather 50 set at least. You can get the boards by this year but it will be sooner hopefully.
