Author Topic: [GB] ComPact SQ - 1800 Inspired [COMPLETE]  (Read 433506 times)
Offline hatran87
Re: [GB] Compact SQ - 1800 Inspired [Taking orders]
« Reply #200 on: Tue, 17 November 2015, 21:49:28 »
Phirr,
you can do that with Acrylic plate. You need to break up the thin part for 2x stabilizer. You would know easily once you got it.
Hantran,
It's just a transparent acrylic bar. It looks plain. Haha
This alu feet awesome, can you add some pictures with:
- Transparent acrylic bottom + alu feet
- Black acrylic bottom + alu feet
- Transparent acrylic bottom + acrylic feed
I want a comparision then change my order hahaha
just get them all :p
any chance that you will be doing another round for the aluminum top and bottom?
As leeku said before the best for LED is transparent bottom + feet, but this alu feet is very cool so i want to see some pictures then decide to order this alu feet  :D
Compact SQ by Leeku
Offline clochette
« Reply #201 on: Tue, 17 November 2015, 23:04:54 »
Phirr,
Hantran,
he is referring to the alu feet with transparent bottom
Offline ccc24
  • HHKB , Ergodox
« Reply #202 on: Wed, 18 November 2015, 12:10:49 »
Can't decide to get this or the 75%...Will you do a GB for the 75% after this one and will it have the same options and duck feet?
Offline leeku
« Reply #203 on: Wed, 18 November 2015, 20:17:43 »
Yes, that's my plan. but why don't you get both of them. It's family look :) haha
Offline leeku
« Reply #204 on: Wed, 18 November 2015, 20:18:58 »
Phirr,
Hantran,
I don't have the feet yet. I would get it these weekend. I'll post some pictures.
Offline QuickDelat
« Reply #205 on: Thu, 19 November 2015, 02:56:18 »
Hi Leeku, do you have any idea when you will be doing the 75% group buy?
Offline captvizcenzo
« Reply #206 on: Thu, 19 November 2015, 03:13:28 »
I don't know what to choose... Thinking of alu top + acrylic plate + feet, or just take the basic kit for budget...
Leeku, the plate is clear acrylic? Or is it actually polycarbonate plate?
Offline leeku
« Reply #207 on: Thu, 19 November 2015, 05:06:27 »
The acrylic plate is literally acrylic 5mm thick plate.
I would say.... Black acrylic or Alu top and translucent bottom... hmmm it's hard for me either sorry.
Feet is do look fancy. You would like any combination of those. good luck :)
Offline leeku
« Reply #208 on: Thu, 19 November 2015, 05:07:33 »
After this GB finished? maybe ..
Offline Dansor
« Reply #209 on: Thu, 19 November 2015, 08:04:14 »
This board is almost a full keyboard crammed into the space of a 75%.
In terms of keys per area, compact 1800 may be one of the densest keyboard around.  Density is good.
Get the Compact SQ.  It's your density... I mean, your destiny...
Offline QuickDelat
« Reply #210 on: Thu, 19 November 2015, 08:16:13 »
I'm trying to save some money first! :( + I don't really need the numpad.
But I agree it's an amazing looking board and I had to constrain myself multiple times to not order this one and wait for the 75%...
Offline Blackhawk
« Reply #211 on: Thu, 19 November 2015, 11:27:05 »
Great price! :D I have a couple of quick questions.
If I order a black acrylic bottom, will the acrylic feet be black as well?
Is it possible to order both 6.25x and 7x stabilizer wire? I'm not sure which layout I will end up going with yet.
Offline ccc24
  • HHKB , Ergodox
« Reply #212 on: Thu, 19 November 2015, 12:25:16 »
anyone have any picture of the pcb? I'm curious what the bottom row looks like.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #213 on: Thu, 19 November 2015, 12:56:51 »
There is a picture on the order form.
Offline drewba
« Reply #214 on: Thu, 19 November 2015, 17:10:07 »
Hi Leeku, this looks great and I'm very interested. This would be my first custom so I have questions:
-Which Gateron switches are included with the assembly service? It says Linear 60g...are these the Gateron 50g blacks or something else? Sorry if that is a dumb question, I haven't heard of a 60g linear Gateron.
-Other than LED indicators, you are not offering any LEDs on the assembly even at an increased assembly price, correct?
-Can I leave a comment in the assembly box to see if you have other options for switches? I would prefer MX/Gateron Brown but that is not a dealbreaker for me. Nevermind you already answered this earlier in the thread.
-Will choosing the assembly service create a delay in receiving the keyboard?
« Last Edit: Thu, 19 November 2015, 17:29:11 by drewba »
Offline leeku
« Reply #215 on: Thu, 19 November 2015, 17:34:43 »
No feets are silver only.
Yes stabilizer includes wires for every possible combinations. 10USD btw. Just comment on the assembly section. Thanks
Offline leeku
« Reply #216 on: Thu, 19 November 2015, 17:44:47 »
1. Yes its Gatron 60g linear(black stemmed, black bottom&clear top)
2. cause I don't have enough LEDs on hand. If you are ok with white&pink just comment on the form. I will see if I can do and send you proper invoice.
3. Not sure but it needs one or two weeks. I won't take so long though.
Offline drewba
« Reply #217 on: Thu, 19 November 2015, 17:46:49 »
Thanks a lot, I will submit the form soon!
Offline kiwi24x
« Reply #218 on: Thu, 19 November 2015, 18:48:04 »
Pronounced gateron not gatron I believe.
Offline HekusuTekusu
« Reply #219 on: Thu, 19 November 2015, 19:03:55 »
Some people may be pronouncing it as 'Gatron' with the e a bit silent. But yeah it is spelled Gateron.
| Das 3 Ult MX BRW | PokerII MX BLK | KUL-ES87 MX CLR | Planck MX GRE | HHKB Pro JP |  CPSQ-1800 GAT BLK | HHKB Pro 2 | NYM96 GAT RED |
Offline leeku
« Reply #220 on: Thu, 19 November 2015, 19:12:11 »
Yes it's typo Gateron it is.
« Reply #221 on: Thu, 19 November 2015, 19:38:44 »
Nice! I already have old gateron black in my inventory. This version indeed looks much nicer.
Offline tuantruong
« Reply #222 on: Thu, 19 November 2015, 19:42:55 »
Do you offer other Gateron switches? I'm interested in blue one. :thumb:
Offline leeku
« Reply #223 on: Thu, 19 November 2015, 20:03:57 »
I don't have any of OTHERS but only that kind of black.
Offline McPwned
« Reply #224 on: Thu, 19 November 2015, 20:26:17 »
Apologies, I just learnt about this GB today.  For the split spacebar, are the key sizes 2.25 and 2.75?  For the short right shift, is the key size 1.75?
Offline Cameron
« Reply #225 on: Thu, 19 November 2015, 21:22:46 »
@Leeku or @Meiosis what happened to the FingerSK group buy? Is there still a case in development for that? Can we expect that to be next in production after this group buy with the FingerSK pcb?
Offline leeku
« Reply #226 on: Thu, 19 November 2015, 21:54:55 »
Correct!!
Offline leeku
« Reply #227 on: Thu, 19 November 2015, 21:58:09 »
That's my plan. 1800 -75% -65%-60%-standard. Haha
Offline Cameron
« Reply #228 on: Thu, 19 November 2015, 23:07:19 »
You have just made my day sir. I've been waiting for that thing since the early interest check.
Offline meiosis
  • Time
« Reply #229 on: Thu, 19 November 2015, 23:16:09 »
My apologies for not updating you sooner! Leeku told me to hold off the GB until the case was done, so that everyone could have a case to use (if they wanted)
Keyboards:
Aripeko TKL
« Reply #230 on: Thu, 19 November 2015, 23:42:36 »
In for a full Alu build with feet  :thumb:
Offline ccc24
  • HHKB , Ergodox
« Reply #231 on: Thu, 19 November 2015, 23:51:03 »
are the cases the same as this GB? Or is it a kmac style case?
Offline building_an_ergo
« Reply #232 on: Fri, 20 November 2015, 01:18:32 »
Are there any images of the case with the steel switchplate but translucent top plate?
Trying to decide if I want that or a black top plate, but kinda need an iamge to decide.
« Reply #233 on: Sat, 21 November 2015, 09:02:48 »
Are invoices supposed to be immediate or are they checked first (if so I assume there is a backlog)?
Have yet to receive mine and it has been about a day.
Offline meiosis
  • Time
« Reply #234 on: Sat, 21 November 2015, 10:47:40 »
Leeku sends them out himself.
Just a reminder everyone, today is the last day he is accepting orderss
Keyboards:
Aripeko TKL
Offline hatran87
Re: [GB] Compact SQ - 1800 Inspired [Last day of taking orders]
« Reply #235 on: Sat, 21 November 2015, 11:00:04 »
Hi leeku, pls check my PM'ed (add alu feet in my order) and send me new invoice.
Compact SQ by Leeku
Offline meiosis
  • Time
« Reply #236 on: Sat, 21 November 2015, 20:42:52 »
Ahh sorry missed this question,
Same style cases I believe, he wants to make it a family of boards :).
Keyboards:
Aripeko TKL
Offline hatran87
« Reply #237 on: Sun, 22 November 2015, 02:52:09 »
Paid!
Pls remember my assembly options in PM'ed  :thumb:
Compact SQ by Leeku
« Reply #238 on: Sun, 22 November 2015, 03:45:16 »
I already payed my invoice, but would it be too late to change the top plate from black acrylic to translucent acrylic?
Offline leeku
« Reply #239 on: Sun, 22 November 2015, 06:37:01 »
As you want. Just PM me with your email(just to confirm)
Offline leeku
« Reply #240 on: Sun, 22 November 2015, 06:37:44 »
Paid!
Received. All PINK SEXY haha
Offline leeku
« Reply #241 on: Sun, 22 November 2015, 06:38:23 »
Yes I really want to run that :)
Offline hatran87
« Reply #242 on: Sun, 22 November 2015, 08:18:24 »
Paid!
And the other gateron switch too.
Im SEXY and i know it hahaha  :cool:
Compact SQ by Leeku
Offline leeku
« Reply #243 on: Sun, 22 November 2015, 19:40:55 »
This is final order.
PM me if there is any difference from your order.
Thanks.
« Reply #244 on: Sun, 22 November 2015, 20:52:05 »
Thanks.
Looks good for mine  ;)
Offline getf
  • In Rod We Trust
« Reply #245 on: Sun, 22 November 2015, 20:57:04 »
Any photos of what of what I'm envisioning an "Oreo" type configuration.  Black acrylic on top and bottom with the translucent acrylic in the middle?
« Reply #246 on: Sun, 22 November 2015, 21:15:28 »
Thanks.
Looks good to me!
Offline clochette
« Reply #247 on: Mon, 23 November 2015, 02:52:03 »
Thanks.
[/quote
can't waiiiiit
I only hope I don't regret not getting the aluminum
Offline hatran87
« Reply #248 on: Mon, 23 November 2015, 02:57:53 »
Thanks.
Note: 55g gateron yellow switch :)
Thanks
« Last Edit: Mon, 23 November 2015, 12:08:57 by hatran87 »
Compact SQ by Leeku
« Reply #249 on: Mon, 23 November 2015, 04:46:30 »
That would probably be pretty neat, you would have a line all around that glows while the rest is pretty subdued.
I really wonder if I should have ordered every case variation just in case.
