Author Topic: [GB] ComPact SQ - 1800 Inspired [COMPLETE]  (Read 432524 times)
Re: [GB] Compact SQ - 1800 Inspired [Last day of taking orders]
« Reply #250 on: Mon, 23 November 2015, 07:08:58 »
If anyone got the black top and bottom, steel plate and aluminum feet decides they don't want it I'd be interested. I never got a PayPal invoice, guess I was a few hours too late. Tried sending a PM got no response. Or maybe I should just keep my money.
Offline Phirr
  • If you don't work you die.
« Reply #251 on: Mon, 23 November 2015, 08:39:56 »
I haven't got my invoice either so I wouldn't be sure you are too late
edit: my order is on the list though, and correct, thanks leeku
« Last Edit: Mon, 23 November 2015, 11:25:12 by Phirr »
Offline roadkill54
« Reply #252 on: Mon, 23 November 2015, 09:19:35 »
Looks good
Offline gadzkun
« Reply #253 on: Mon, 23 November 2015, 09:24:32 »
hope this will go smoothly, im waiting for leeku 75% :p
Offline Dee1
« Reply #254 on: Mon, 23 November 2015, 10:56:42 »
This is final order.
PM me if there is any difference from your order.
Thanks.
Looks good! Thanks! :)
Offline Kempher
« Reply #255 on: Mon, 23 November 2015, 14:00:19 »
List, what list? Did I miss something?
Edit: Nevermind I see what I missed
SQ-1800 /w Gateron Blacks
Offline drewba
Re: [GB] Compact SQ - 1800 Inspired [Taking orders]
« Reply #256 on: Mon, 23 November 2015, 14:52:16 »
I wonder how the bottom looks. Does it come with layered acrylic feet like those B series acrylic case?
This is a picture of mine but it was a prototype the spacing has been changed
I know you mentioned this is a prototype, but will the "feet" be the same as pictured? I did not get the aluminum feet.
Very excited for this!
Offline meiosis
  • Time
« Reply #257 on: Mon, 23 November 2015, 15:18:27 »
Yes :)
As for everyone who ordered last minute I'll ask leeku, I believe it should be okay
Keyboards:
Aripeko TKL
Offline drewba
« Reply #258 on: Mon, 23 November 2015, 15:25:02 »
Yes :)
Ok thanks! That was the hardest choice for me considering the feet look so good but ultimately decided that all acrylic would look cleaner than acrylic + aluminum feet.
Offline meiosis
  • Time
« Reply #259 on: Mon, 23 November 2015, 17:44:26 »
He was extremely busy yesterday (Monday) he said he will get to everyone remaining on the list in an hour or so
Keyboards:
Aripeko TKL
« Reply #260 on: Mon, 23 November 2015, 18:20:32 »
Awesome. Thanks!
Offline Phirr
Re: [GB] Compact SQ - 1800 Inspired [Check Orders]
« Reply #261 on: Tue, 24 November 2015, 14:04:56 »
Hey leeku, didn't see the paypal request til just now, I know it is 2 days late but hopefully that's fine.
Offline redbanshee
  • actually Dade Murphy
« Reply #262 on: Tue, 24 November 2015, 14:14:36 »
Now I have to make a hard decision: cherry or centered capslock....
What do you guys run usually? Do Signature Plastics SA stepped capslock have the stem in the right spot for cherry?
« Reply #263 on: Tue, 24 November 2015, 14:16:39 »
Stepped all the way!  :cool:
(Even if Troubled Minds may not come with it.  :'()
From the SP sets I've had, all stepped Caps Lock are off-center. I'm pretty sure that, unless otherwise stated, all stepped Caps Lock caps are off-center.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #264 on: Tue, 24 November 2015, 15:11:17 »
The answer is: Control  :thumb:
Offline clochette
« Reply #265 on: Tue, 24 November 2015, 17:15:37 »
what USB connection does the PCB use?
Offline kiwi24x
« Reply #266 on: Tue, 24 November 2015, 17:26:54 »
Uhhh mini USB but I can't say for sure
Offline McPwned
« Reply #267 on: Tue, 24 November 2015, 17:35:15 »
I don't use caps lock as caps lock, so I don't like stepped caps.
Offline leeku
« Reply #268 on: Tue, 24 November 2015, 20:30:06 »
Yes. you said for sure :)
Offline kiwi24x
« Reply #269 on: Tue, 24 November 2015, 20:59:15 »
Ohhh sooo it's not?!?! Guess I need a new cable.
Offline kiwi24x
« Reply #270 on: Tue, 24 November 2015, 21:03:55 »
Ya know u/90nine over at reddit makes some good cables for US buyers.
Offline clochette
« Reply #271 on: Tue, 24 November 2015, 22:03:58 »
ok, mini usb, gonna make an order for cables soon  :cool:
Offline roadkill54
« Reply #272 on: Wed, 25 November 2015, 10:47:44 »
Anyone know what size shift key u need for this layout?
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #273 on: Wed, 25 November 2015, 11:24:16 »
1.75 if I'm not mistaken.
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
Offline kiwi99
  • that's a gnarly dookie
« Reply #274 on: Wed, 25 November 2015, 12:41:02 »
This is correct, another thing I'll add on one thing you don't notice is you'll need a 1u "0" key for the numpad which isn't often standard.
Offline drewba
« Reply #275 on: Wed, 25 November 2015, 17:17:51 »
Which cables are you going to get?
Offline clochette
« Reply #276 on: Wed, 25 November 2015, 21:51:19 »
made an order with mimic
seems like they have the widest range of colors
USB A to mini usb
Offline building_an_ergo
« Reply #277 on: Thu, 26 November 2015, 01:26:59 »
Probably gonna place an order with p3xon since they will do the double sleevings.  Just need to decide on keycaps...
Offline leeku
« Reply #278 on: Thu, 26 November 2015, 06:19:19 »
I like LINDY best and secondly Zeal's custom cable.:)
Offline Kempher
« Reply #279 on: Thu, 26 November 2015, 12:58:33 »
SKIDATA+ is running right now until the end of november, believe that's what I'll be putting on this, it looks pretty sweet.
Offline leeku
« Reply #280 on: Thu, 26 November 2015, 17:47:00 »
Anyone who ordered steel plate needs ISO layout?
Cause I ordered the plate supporting ANSI only.
Please PM me if anyone want ISO steel plate instead of ANSI steel plate.
Nevermind, I re-ordered all .
« Last Edit: Thu, 26 November 2015, 18:06:39 by leeku »
« Reply #281 on: Fri, 27 November 2015, 03:00:28 »
I think I am gonna try to get my hands on the JTK keyset.
The purple and white would look great with the translucent/white plastic casin I think.
« Reply #282 on: Fri, 27 November 2015, 09:43:29 »
I think it would look exactly like Leeku's that he already posted  ;) Which I agree, is pretty great  :thumb:
Translucent + JT purple, yes, it's mine :)
« Reply #283 on: Fri, 27 November 2015, 10:27:13 »
Oh wow, I missed that, it looks fantastic.
I wonder if I can still do the split spacebar and still get it covered by properly colored keys?
« Reply #284 on: Fri, 27 November 2015, 10:54:30 »
If you run ISO I think it will be possible.
Not possible with an ANSI layout, as you would need two full size (2.25u) left shifts - unless you buy two kits or find someone who can sell you the key  :D
« Reply #285 on: Sun, 29 November 2015, 04:35:53 »
I was hoping for blank keys.
Wonder If I can find something the proper size and the same (or similar) color from somewhere else?
« Reply #286 on: Sun, 29 November 2015, 13:24:22 »
Ah sorry, I totally misunderstood the 'colored' part. If I was to do a split space bar build I would go with two sets of the blank Gateron PBT. I don't know of any set with legends that you can also get matching blank shift keys - but that would look amazing!
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: [GB] Compact SQ - 1800 Inspired [Production]
« Reply #287 on: Sun, 29 November 2015, 15:57:05 »
Damn, wish I knew I was going to buy an 1800 board, I would have bought one of these PCB/plates.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #288 on: Sun, 29 November 2015, 16:18:37 »
Is this still open? I know the deadline is passed but the order form is still open.
Offline leeku
« Reply #289 on: Sun, 29 November 2015, 19:11:18 »
I made some extras of course. If you really want to be in, you are in . just write an order. :) thanks.
katushkin, you too. :)
« Reply #290 on: Sun, 29 November 2015, 19:38:10 »
Thought I'd missed this thanks to debating blanks for a split spacebar build, but hopefully there's room for one more - order submitted :-X
Offline katushkin
  • Just the guy
« Reply #291 on: Sun, 29 November 2015, 19:38:19 »
I only want a PCB/plate though, is that OK?
    • WTB/WTTF Thread
« Reply #292 on: Sun, 29 November 2015, 19:54:05 »
Submitted an order. Hope it is not too late.
Offline kiwi99
« Reply #293 on: Sun, 29 November 2015, 20:21:51 »
Just a shot in the dark, but does the steel plate allow for switch modding?
    • WTB/WTTF Thread
« Reply #294 on: Sun, 29 November 2015, 20:45:48 »
Sent you both a PM and email Leeku. One mess up on my part on my order that I would like to adjust.
Offline gadzkun
« Reply #295 on: Sun, 29 November 2015, 21:20:13 »
owh so we still can order. ok order form sent.
i was waiting for your 75% cause my wallet not ready at that time.
b-b-but when i still can order now, ok im in :thumb:
Offline leeku
« Reply #296 on: Sun, 29 November 2015, 23:50:29 »
Yes it is OK of course.
Offline leeku
« Reply #297 on: Sun, 29 November 2015, 23:59:08 »
Done. Thanks.
Offline katushkin
  • Just the guy
« Reply #298 on: Mon, 30 November 2015, 00:02:06 »
OK. I've sent an order through. Don't know if I've done the totals right, but hopefully I have. Thanks for being so flexible.
Offline gadzkun
« Reply #299 on: Mon, 30 November 2015, 00:59:57 »
wow that was fast, thanks leeku :thumb:
:cool:
