Author Topic: [GB] ComPact SQ - 1800 Inspired [COMPLETE]  (Read 421952 times)
Offline FranksNewLiver
Re: [GB] ComPact SQ - 1800 Inspired [Shipping]
« Reply #450 on: Sat, 02 January 2016, 01:22:36 »
...And I am still on the fence about that split spacebar.  I want it, but getting keycaps for it will be hell.
I've been waiting on some PCB mount stabs for the spacebar on a board I finished about a month ago and have been using a 2u blank for a while, and I definitely like the solid feel of a smaller spacebar. Glad you said something, now I know what to spend my excess funds on for my round 6 order   :p
Offline building_an_ergo
« Reply #451 on: Sat, 02 January 2016, 01:25:20 »
Aw man, I just realized I have no LEDs for the notification lights.
Would starting the board up without them hurt it?  Otherwise I have to wait awhile to actually get my hands on some.
Offline Steezus
  • Keeper of Facts
« Reply #452 on: Sat, 02 January 2016, 01:26:58 »
It won't do any damage at all to the PCB, you should be just fine to turn it on.
« Reply #453 on: Sat, 02 January 2016, 01:34:47 »
Would any 3mm LED work?  Such as this: http://www.amazon.co.jp/dp/B00E4F9N5A/
Offline Steezus
  • Keeper of Facts
« Reply #454 on: Sat, 02 January 2016, 01:38:45 »
Yes those should work fine, however if you ever wish to put any in your switches they need to be flangeless(minus the protruding rim at the bottom). I personally like 2x3x4mm LEDs since they tend to be brighter but that won't matter too much for just the indicators.
« Reply #455 on: Sat, 02 January 2016, 01:47:34 »
Yea I made that mistake on my ergodox.
Actually cut them down to fit with a dremel though.  But I only needed 3, not 98.
Offline Steezus
  • Keeper of Facts
« Reply #456 on: Sat, 02 January 2016, 01:50:55 »
Yeah I made the same mistake as well when adding LEDs to my Pok3rs. I was actually able to clip them off with a pair of small wire cutters but I suggest wearing eye protection, I got a piece of plastic stuck in my and I thought I was going blind.
« Reply #457 on: Sat, 02 January 2016, 02:43:00 »
That sounds absolutely terrifying.
I ordered a pack like that 100 count one.  I figure I will do the notification LED and the ESC key for now.  Will leave the rest for another day.
Thanks for all the help.  Will post completed pictures tomorrow hopefully.
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #458 on: Sat, 02 January 2016, 13:26:48 »
Can't wait and good luck with your build. Once you figure out the software let us know what this puppy can do!
« Last Edit: Sat, 02 January 2016, 17:08:43 by Rodgaroon »
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
« Reply #459 on: Sat, 02 January 2016, 22:15:44 »
So here it is
Didn't put all the screws in (CAUTION:Those plastic ones strip easy as ****, be careful) because I have to open it up in a few days (for LEDs), but it all seems to work.
No clue how to work the JigOn software.  Tinkered for a minute or two but couldn't figure it out.  Will give it another shot when I finally close it up. Thinking Deep Space caps...
Offline kiwi99
  • that's a gnarly dookie
« Reply #460 on: Sat, 02 January 2016, 22:20:51 »
So here it is
Beautiful ! Can't wait to get mine
Offline Rodgaroon
« Reply #461 on: Sat, 02 January 2016, 23:03:23 »
So here it is
Sexy
Offline Steezus
  • Keeper of Facts
« Reply #462 on: Sat, 02 January 2016, 23:05:30 »
So here it is
Very nice man, glad to see you didn't run into any problems. MX Greens are some manly switches! :p
Offline Rodgaroon
« Reply #463 on: Sat, 02 January 2016, 23:08:41 »
So here it is
I'm waiting for Steezus to build his board, if there is anyone who can figure out the software it's him.
Offline Steezus
  • Keeper of Facts
« Reply #464 on: Sat, 02 January 2016, 23:14:52 »
So here it is
Haha I hate to say this, since I'm very regretful about it but I did pass on this group buy. However I do have a board that uses the same firmware(TX87). I haven't messed around with it too much but have got the hang of it a bit. My favorite thing about the software is once you get the board connected(simply by clicking Keyboard -> Connect) then any switch you press is then highlighted on the layout display. So I just press through each switch and then assign each key to whatever I like. I am waiting for leeku to to give an update allowing in-switch brightness control and MX Lock compatibility, then I'll be in complete love with the software. It's probably the easiest software that I have used.
« Last Edit: Sat, 02 January 2016, 23:45:52 by Steezus »
« Reply #465 on: Sat, 02 January 2016, 23:38:11 »
My favorite thing about the software is once you get the board connected(simply by clicking Keyboard -> Connect) then any switch you press is then highlighted on the layout display. So I just press just go through pressing each switch and then assigning each key to whatever I like.
Oh....I missed the whole keyboard connect thing...
I will give it another shot when I get back home, running to yodobashi to pick up some LEDs.
These actually:
http://www.yodobashi.com/EK%E3%82%B8%E3%83%A3%E3%83%91%E3%83%B3-%E3%82%A4%E3%83%BC%E3%82%B1%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%91%E3%83%B3-LK-3WH-3mmLED-%E7%99%BD-%E9%9B%BB%E6%B0%97%E5%B7%A5%E4%BD%9C/pd/100000001000814981/
A little pricey, but Amazon wants me to wait a month, and I am dieing to use this thing.
Offline Steezus
  • Keeper of Facts
« Reply #466 on: Sat, 02 January 2016, 23:46:57 »
These actually:
Holy **** did I have a seizure when writing that haha, I fixed it in my post but I obviously had two different sentences in mind and tried to combine them. Yeah those LEDs are pretty pricey but if it saves you a month then I can definitely understand.
Offline Rodgaroon
« Reply #467 on: Sun, 03 January 2016, 00:34:02 »
So I didn't edit my post (#436), and yet the text disappeared. Steezus magic again  :eek:
Offline meiosis
  • Time
« Reply #468 on: Sun, 03 January 2016, 01:52:48 »
So here it is
For the most part,
1. Connect the Keyboard
2. Press the Key you want mapped (highlights the key, don't mind if it doesn't look like it is the correct position)
3. Press the key you want it mapped to (will overwrite the old one)
4. Update All
Keyboards:
Aripeko TKL
« Reply #469 on: Sun, 03 January 2016, 02:03:12 »
For the most part,
4. Update All
Yea, I got it now, thanks. Missed out on the connect part.
I'd take a picture, but it just has the qwerty keys and 1u blanks for the rest right now.  Got about a week before the rest of the keyset comes in.
« Reply #470 on: Sun, 03 January 2016, 04:45:38 »
So here are some more pictures, please excuse the half blank/half grab bag keyset I have on it.
To start, here are my JigOn settings.  Set to solid white (5 minute timeout) with default layout except for the removal of the FN key (only using one layer at this time):
First is the bottom.
Side view (not a lot of light coming out, but a strong underglow):
Top View:
Notification LEDs(actually two lit here, but some brightness issues with camera.  Glow is considerably brighter than rest of baord):
« Reply #471 on: Sun, 03 January 2016, 05:27:09 »
Looks great and the keymapper sounds much easier to use once you actually have a board :))
Hopefully mine will be sorted soon so I can get it built!
Offline leeku
« Reply #472 on: Sun, 03 January 2016, 20:14:54 »
Top View:
Awesome! Did you got already?
Try http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=2702787
Offline daviswalkers
  • HHKB Amature 2
    • Graphic Design Portfolio
« Reply #473 on: Sun, 03 January 2016, 22:14:02 »
Just to kind of ease some of the concerns with the keymapper, as others have stated above it's extremely easy to use and I have had no issues with it at all. I've been using it with my TX-1800 and it was super simple.
Compact-SQ |          VE.A
 65g Zealios    |      78g Zealios
Offline Rodgaroon
« Reply #474 on: Sun, 03 January 2016, 22:23:58 »
May i ask where u got your TX-1800 From?
Offline Steezus
  • Keeper of Facts
« Reply #475 on: Sun, 03 January 2016, 22:27:10 »
Yeah the keymapper is really easy to use, just wish it had more features to ti.
« Reply #476 on: Sun, 03 January 2016, 22:34:28 »
Yea, received and assembled.  Thank you, Loving this layout.
And yea, still tinkering with JingOn, a lot easier to use than tmk_keyboard.
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #477 on: Sun, 03 January 2016, 22:48:13 »
I wish I had joined this. :(
Offline Rodgaroon
« Reply #478 on: Mon, 04 January 2016, 00:31:13 »
Leeku is doing a 60%, TKL, and a full sided board back-to-back-to-back. you will get your turn.
Offline meiosis
  • Time
« Reply #479 on: Mon, 04 January 2016, 00:54:46 »
Next is 75SQ which will be limited to 70 or so (I think).
Then 60 then possibly TKL.
:P priority for the some of the 75's will go to those who are in this buy
Keyboards:
Aripeko TKL
Offline LXXXIX
« Reply #480 on: Mon, 04 January 2016, 00:55:23 »
But those are not an 1800...
Offline alienman82
« Reply #481 on: Mon, 04 January 2016, 00:58:04 »
awesome!
Offline hatran87
« Reply #482 on: Mon, 04 January 2016, 01:01:56 »
Awesome  :thumb:
Hope to see some pictures of 75SQ  :cool:
Compact SQ by Leeku
Offline gadzkun
« Reply #483 on: Mon, 04 January 2016, 02:18:14 »
still waiting my CP-SQ to come, hope it will come soon since im in SEA.
so 75-SQ is ready? :eek: :eek: :eek: :eek: :eek:
im better prepare my wallet then. :cool: hope it will not run at the same time with octagon.
100% prefer leeku fast GB indeed :thumb: !! coz leeku is a magician :p
  • HHKB Amature 2
« Reply #484 on: Mon, 04 January 2016, 09:04:33 »
I bought it off of a user who got it from Leeku who I assume got it from Kin25 (seeing as he fulfilled KR orders and Leeku is part of that community)
Compact-SQ |          VE.A
Offline Rodgaroon
« Reply #485 on: Mon, 04 January 2016, 12:00:41 »
Oh ok cool, thought you might of been the only non-Korean to get an order from kin. if that was the case i'd tell you to go buy a lottery ticket.
  • HHKB Amature 2
« Reply #486 on: Mon, 04 January 2016, 14:57:38 »
Yeah unfortunately I lost my deposit like the rest of you and ended up paying a bit more than I would have (although this was fully assembled and has a acrylic diffuser between the aluminum bodies so it was worth it for how amazing the keyboard is) so it hurt my wallet a lot but I really really wanted one so I'm so happy to have it.
« Last Edit: Mon, 04 January 2016, 15:10:43 by suicidal_orange »
Compact-SQ |          VE.A
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #487 on: Mon, 04 January 2016, 15:07:23 »
I just got mine in today!
Can't wait to get it built!
« Reply #488 on: Mon, 04 January 2016, 22:32:15 »
If anyone can figure out JigOn RGB effects, let me know.  I can only seem to get it to do a slow pulse, and I can't change it.
Offline alienman82
« Reply #489 on: Mon, 04 January 2016, 22:33:01 »
pics or it didn't happen.  LOL I got a missed delivery slip
    • WTB/WTTF Thread
« Reply #490 on: Mon, 04 January 2016, 22:33:20 »
Hey Leeku,
Any chance I can get an extra PCB and possibly an acrylic plate?
    • WTB/WTTF Thread
« Reply #491 on: Mon, 04 January 2016, 22:58:32 »
I'll get some pictures tomorrow morning.
Offline alienman82
« Reply #492 on: Mon, 04 January 2016, 22:59:49 »
What options did you get?
    • WTB/WTTF Thread
« Reply #493 on: Mon, 04 January 2016, 23:06:00 »
Black acrylic top, acrylic plate, clear acrylic bottom. Also added the aluminum feet option.
Need to see if I can get an extra plate and PCB though.  Hoping I can.
« Reply #494 on: Tue, 05 January 2016, 00:39:27 »
Agreed.  I like mine a lot more than I expected.
If I could I would get all three of the tops and another board.
Offline alienman82
« Reply #495 on: Tue, 05 January 2016, 00:40:41 »
I can't decide on led color.  White, pink or cyan?  Will be using OG cherry beige or OG dolch
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #496 on: Tue, 05 January 2016, 00:43:42 »
I think white always looks nice, even if it is a bit more plain.
Offline ccarlitos2
« Reply #497 on: Tue, 05 January 2016, 00:44:02 »
I think cyan would look good, but what do I know I'm a dirty cat lover :(
Offline alienman82
« Reply #498 on: Tue, 05 January 2016, 00:44:30 »
Yeah white is nice.  Maybe I'll just get the sip sockets
« Reply #499 on: Tue, 05 January 2016, 00:44:40 »
I didn't put LEDs in except for my ESC key which is white.
I mean, worst comes to worst, aren't there lots of colored covers you can put on to change the color?
Or you could try SIP sockets.
