Author Topic: [GB] ComPact SQ - 1800 Inspired [COMPLETE]  (Read 433504 times)
Offline leeku
Re: [GB] Compact SQ - 1800 Inspired [Taking orders]
« Reply #50 on: Mon, 09 November 2015, 03:02:10 »
A quick question, and forgive me if it comes off as noobish. Regarding the plate, will the acrylic plates allow for the switches to be customized without doing any additional soldering, or will that only be possible with the steel plate? Also will the steel plate be visible in a top/bottom translucent acrylic setup?
As you can see on the form, there are 4 types of acrylic plate and 1 universal(all combos of layout is possible) steel plate. Sorry I don't get "allow for the switches to be customized without doing any additional soldering" But you can solder switches as you want as long as the plate allows. The steel plate is might be semitransparently(?) visible through the translucent TOP :)
Offline leeku
« Reply #51 on: Mon, 09 November 2015, 03:03:57 »
Any more colour options for the top acrylic piece?
Sorry but no options.
When is the actual dead line?
30th or 21st?
21th.
Offline leeku
« Reply #52 on: Mon, 09 November 2015, 03:08:27 »
Do I have to solder on the RGB case led?
No, you don't have to. RGB will be soldered. All you need to solder is switches & switch side LEDs(only if you want to)
« Last Edit: Mon, 09 November 2015, 03:37:13 by leeku »
Offline captvizcenzo
« Reply #53 on: Mon, 09 November 2015, 03:13:10 »
Hi Leeku. I would really want to know when this would ship out. ;)
I assume the basic kit will go out sooner than the aluminum skin? But still, when?
Technically? Possible. For GB cost, however, I should gather 50 set at least. You can get the boards by this year but it will be sooner hopefully.
Sooner hopefully!  ;D
If I'm in, I will get the basic kit, because I have TX1800 coming 'soon'...
Offline Giorgio
« Reply #54 on: Mon, 09 November 2015, 05:19:59 »
Is it usable without a plate? Is the pcb supported enough? thanks
Offline hatran87
« Reply #55 on: Mon, 09 November 2015, 06:01:25 »
Hi Leeku. How about Assembly Service in google form, can you explain more?
Compact SQ by Leeku
Offline alienman82
« Reply #56 on: Mon, 09 November 2015, 06:23:38 »
submitted thanks!
Offline ccc24
  • HHKB , Ergodox
« Reply #57 on: Mon, 09 November 2015, 10:30:24 »
do the acrylic and steel plate feel different  to type on?
Offline leeku
« Reply #58 on: Mon, 09 November 2015, 10:34:15 »
Yes it's different for sure. I can not describe with my poor english though.
Offline ccc24
  • HHKB , Ergodox
« Reply #59 on: Mon, 09 November 2015, 10:37:05 »
which do you like better?
Offline leeku
« Reply #60 on: Mon, 09 November 2015, 10:40:44 »
It 's like basic assembly with gatron black(60g linear) switch. I can tell the the gatron feels good enough only with the factory lube.I will tune the stabilzer of course. So, you will receive a keyboard without LED(on the switch) and cpas. The bottom RGB will be glow and you can use immediatly. It cost 80$ totall including all the matirials.
If you need any other special option like lube or LED jobs on the switch please comment on the form. I will send proper invoice if I can do that.
« Last Edit: Mon, 09 November 2015, 10:42:41 by leeku »
Offline leeku
« Reply #61 on: Mon, 09 November 2015, 10:44:40 »
No there is not nonplate consideration on the PCB. Plate is required.sorry.
Offline o3okevin
« Reply #62 on: Mon, 09 November 2015, 10:54:42 »
Invoice paid! Just wanted to make sure, can we use only aluminum top? e.g. Layer 1: Alu, Layer 2: Acrylic, Layer 3: Arylic
Also how hard is it to swap top layers?
Offline trees
  • I like bagels.
« Reply #63 on: Mon, 09 November 2015, 11:05:22 »
Do you have a general idea of a time line for this to be made/sent out?
B.Face HHKB - B.mini - Black/Purple Custom
Offline tuantruong
« Reply #64 on: Mon, 09 November 2015, 11:53:10 »
I haven't received any invoice yet, leeku, may you check if my order went through?  :thumb:
Offline leeku
« Reply #65 on: Mon, 09 November 2015, 12:28:09 »
Tops are easily switchable. Just un screw and change.
Offline leeku
« Reply #66 on: Mon, 09 November 2015, 12:30:31 »
21/11 order close
12 /12 complete manufacturing
12/19 ship
is the plan.
Offline popkorn62
  • No keyboards for old men
    • Mekibo
« Reply #67 on: Mon, 09 November 2015, 13:12:14 »
If only there's a TKL version of this!
https://mekibo.com/
Offline Steezus
  • Keeper of Facts
« Reply #68 on: Mon, 09 November 2015, 13:22:44 »
That makes no sense...
1800 is a specific layout, same as TKL. This keyboard would look extremely odd with the numpad just missing and the arrow cluster sticking out.
Offline yicaoyimu
« Reply #69 on: Mon, 09 November 2015, 13:24:42 »
You are basically saying Leopold FC660 looks extremely odd.  :))
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #70 on: Mon, 09 November 2015, 13:27:01 »
Question about the assembly service. Is there any way we can get a different type of switch and pay the difference? Not a fan of liner switches.
If you say yes than I'm 100% in.
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
Offline Steezus
  • Keeper of Facts
« Reply #71 on: Mon, 09 November 2015, 13:27:44 »
I'm not a fan of the FC660 either but I was just trying to say that the whole purpose of this group buy is specifically for the 1800 layout.
Offline Dansor
« Reply #72 on: Mon, 09 November 2015, 13:34:09 »
With the TX1800 delay, I cannot express how psyched I am about this buy.
Had to get one of each top and bottom so I can obsessively swap them around to compare which looks coolest.
That makes me thing of one question I have.
Does this come with black screws or silver screws?  I can see both in the pictures.
Does it vary by which top you buy?  What if you are insane and buy them all?
EDIT: OK, I somehow missed a post on the previous page that said the screws match the top you get, so I'm assuming if you get all the tops, you get a set of screws for each.
Also, if I forgot to add stabs to me order, can I still do so?  I've not been billed yet, but I didn't want to confuse things by submitting the order again.
Thanks for the great buy!
« Last Edit: Mon, 09 November 2015, 13:44:10 by Dansor »
Offline ccc24
  • HHKB , Ergodox
« Reply #73 on: Mon, 09 November 2015, 14:29:10 »
you mind providing the diameter of the through holes for the switches as well as thickness of the pcb?
And say this is my order I would pay, Total 60 + 10 + 30 + 10 + 10 + 25  = 145 USD correct? And are there options to include the stabilizers and indicator led separately without assembly?
1. PCB (60)
2. TOP - b. black Acrylic (10)
3. MIDDLE (30)
4. BOTTOM - a. translucent Acrylic (10)
5. b. Acrylic (ANSI+6.25/7x) : 10
Shipping 25
« Last Edit: Mon, 09 November 2015, 14:48:00 by ccc24 »
Offline Kempher
« Reply #74 on: Mon, 09 November 2015, 14:54:48 »
Also, since I don't think it was mentioned, how thick will the Acrylic plate be?
SQ-1800 /w Gateron Blacks
Offline meiosis
  • Time
« Reply #75 on: Mon, 09 November 2015, 16:48:20 »
You would have to send him the switches, he ordered a lot of the linear gaterons from a gb which is why it's offered, if there is any switch save vintage Browns I can help you find them
Keyboards:
Aripeko TKL
Offline meiosis
  • Time
« Reply #76 on: Mon, 09 November 2015, 16:49:37 »
1. PCB (60)
3. MIDDLE (30)
Shipping 25
I believe he is charging $10 for stabilizers because he isn't like completely stocked on them, indicator leds can be left out, do you mean he includes the leds without assembling them?
Keyboards:
Aripeko TKL
Offline meiosis
  • Time
« Reply #77 on: Mon, 09 November 2015, 16:51:04 »
Tkl isn't a priority as he wants to showcase a new design, the tx87 we are seeing in the recent tgr gbs came from leeku :) that said he might eventually get around to it
Keyboards:
Aripeko TKL
Offline leeku
« Reply #78 on: Mon, 09 November 2015, 17:24:29 »
Just comment any extra request on the form I will send you a proper inboice. Thanks
Offline leeku
« Reply #79 on: Mon, 09 November 2015, 17:25:43 »
5mm as usual.
Offline leeku
« Reply #80 on: Mon, 09 November 2015, 17:29:10 »
I got your order. I will update and send you an invoice considering a stabs you asked.thanks
Offline Kempher
« Reply #81 on: Mon, 09 November 2015, 17:29:28 »
5mm as usual.
Ordered, thanks for the great work you're doing here!
« Reply #82 on: Mon, 09 November 2015, 17:38:58 »
This looks awesome and the price is right, but I'm struggling to get my head round a usable layout while compressing the 9 nav keys into 5.
Is the firmware compatible with spaceFN?  Putting PgUp/Down and Home/End on the arrows could make it perfect.  That or I could use an ANSI enter and a right shift to make an ISO+Split, but the profile and legends wouldn't be perfect...
Offline leeku
« Reply #83 on: Mon, 09 November 2015, 17:41:31 »
1. PCB (60)
3. MIDDLE (30)
Shipping 25
I don't have enough LEDs and stabilizers. I can buy some stabs then send you guys just for your convinience. But LEDs are too bothering to sort each colors. Sorry about that.
For the through hole and PCB, it follows cherry recommendation. 1.6mm thickness and 4mm diameter. Thanks
Offline leeku
« Reply #84 on: Mon, 09 November 2015, 17:48:49 »
You can mod(remap) the key layout whatever you want.
Currently, I use the 1.25x key in the bottom middle as a FN then map "f v" for home end "g b" for pageup and down. It's extremely comfortable but yes the three keys instead of space bar might look odd
Offline leeku
« Reply #85 on: Mon, 09 November 2015, 17:54:04 »
There are lots of gorgeous TKL keyboards out there!
I like those cool keyboards rather than this. Haha
For me? I love my Orion v2 with ALPS linear.
Sorry I don't have any plan for TKL but do have75% 65% 60% version of this.
Offline azhdar
  • Praise the AZERTY god
« Reply #86 on: Mon, 09 November 2015, 18:05:00 »
<3 leeku
Azerty Propagandiste
« Reply #87 on: Mon, 09 November 2015, 18:09:17 »
And I'm going to get boards for all those PCBs.
I was so excited when I heard the Jane will be using the TX87. Can't wait to try it out.
Offline ideus
  • Björkö.
« Reply #88 on: Mon, 09 November 2015, 18:12:10 »
The price is awesome, if I'd use a TKL, I'd be in for sure.
This GB is gonna be a success.
Offline leeku
« Reply #89 on: Mon, 09 November 2015, 18:15:07 »
Oh I love Dr. House haha
Offline ideus
  • Björkö.
« Reply #90 on: Mon, 09 November 2015, 18:17:13 »
You should have a very good sense of humor then.
Offline clochette
« Reply #91 on: Mon, 09 November 2015, 21:41:02 »
paid!
can't wait!!
Offline ccc24
  • HHKB , Ergodox
« Reply #92 on: Mon, 09 November 2015, 23:08:05 »
1. PCB (60)
3. MIDDLE (30)
Shipping 25
okay thanks, where on the form do we indicate that we want a set of stabs?
Offline Rodgaroon
« Reply #93 on: Mon, 09 November 2015, 23:25:44 »
Its just for work. I used blacks for a year and now type on browns. I find MX blacks a bit heavy. Honestly the MX blacks in my Steel Series feel more like 80g and my fingers get tired.
I have read that the 60g stock Gateron switchers are a lot lighter than MX so I'm OK with that. Also could I pay extra to get the switches lubed and have in-switch LEDs? does the board even support in-switch leds?
So for all the questions.  ;D
Offline leeku
« Reply #94 on: Mon, 09 November 2015, 23:25:58 »
1. PCB (60)
3. MIDDLE (30)
Shipping 25
Just command on "(Optional) Assembly Service 80"
Offline leeku
« Reply #95 on: Mon, 09 November 2015, 23:33:02 »
Translucent + JT purple, yes, it's mine :)
« Last Edit: Mon, 09 November 2015, 23:35:54 by leeku »
Offline jaffers
« Reply #96 on: Mon, 09 November 2015, 23:33:31 »
Offline ccc24
  • HHKB , Ergodox
« Reply #97 on: Mon, 09 November 2015, 23:46:11 »
1. PCB (60)
3. MIDDLE (30)
Shipping 25
okay, will do thanks.  Do you think something like this will fit in the switch through hole http://www.digikey.ca/product-detail/en/8134-HC-8P3/A114359-ND/1151726?
I'm looking for a build to test hot swapable switches on.
« Reply #98 on: Mon, 09 November 2015, 23:58:23 »
That split spacebar is so interesting. I hope you make a full alu case of this!
Offline leeku
« Reply #99 on: Tue, 10 November 2015, 00:04:40 »
There is LZ-CP already !!!
