Author Topic: Help! My PCB enter key hole got ruined on my pok3r  (Read 2208 times)
Offline burn1nsun
    • My stupid YouTube Channel
« on: Wed, 16 September 2015, 13:06:24 »
I was soldering in new switches, but while desoldering this must have happened, when I soldered in a new switch there, it doesn't work, but all other switches work.
Pictures: https://gyazo.com/2fd65827d4b557ac180476deb75e28fe After that I tried to solder a led pole on the pcb to connect it, maybe it would give connection, but it didn't, probably because it didn't connect the right way, does anybody know what to do or where I would have to solder something for it to connect? https://gyazo.com/401558341ddb4a9a704f4a1ae6d5d35e
HHKB Pro 2 l Pok3r Gateron Blacks
Re: Help! My PCB enter key hole got ruined on my pok3r
« Reply #1 on: Wed, 16 September 2015, 13:13:40 »
Offline Oobly
« Reply #2 on: Wed, 16 September 2015, 13:49:06 »
Remove the wire and all the solder youäve put on there and then use a short wire and solder it from the switch pin to the side of the diode, like in this picture:
111157-0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline burn1nsun
« Reply #3 on: Wed, 16 September 2015, 14:25:52 »
Yeah that didn't work, it activated like 4 different keys, but its okay, I fixed it, the PCB had an ISO enter key as well, so I just conencted that with a wire :)
