Author Topic: So this happened when soldering...  (Read 10361 times)
Offline frosty
  • jukebox hero
« on: Tue, 08 July 2014, 07:51:01 »
the ring came out. does this mean that my keyboard pcb is screwed and it won't work anymore?
this is a blackwidow tourney cherry edition pcb.
prepare for a white widow build log!
Offline frosty
  • jukebox hero
Re: So this happened when soldering...
« Reply #1 on: Tue, 08 July 2014, 07:51:30 »
need advise on this particular problem :$
« Reply #2 on: Tue, 08 July 2014, 07:56:46 »
Jump it. You can see an example of how to do this in my Kingsaver review. Intelli78 has a picture as an example. Just keep in mind the picture is alps. You'll have to figure out where the traces lead to.
Offline phoenix1234
« Reply #3 on: Tue, 08 July 2014, 07:56:56 »
Don't worry too much, you can bridge the trace back by using copper wire or small tin wire.
Try to use as small wire as possible (24-28 swg)
I like linear switches
Offline frosty
  • jukebox hero
« Reply #4 on: Tue, 08 July 2014, 08:28:23 »
would it work if i just soldered a switch on it?
i browsed your review but there wasn't anything on this (( on mobile )). :(
could you link me to intelli's photo?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5 on: Tue, 08 July 2014, 08:38:18 »
No because the solder will only flow onto metal, so it won't flow onto the PCB anymore.
You will want to add a little wire to the next hole that trace goes to (called jumping). Follow the trace to find the next hole it goes to.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #6 on: Tue, 08 July 2014, 08:41:47 »
Here is a better description of your options.
http://geekhack.org/index.php?topic=58919.msg1390132.msg#1390132
« Reply #7 on: Tue, 08 July 2014, 08:44:54 »
That's because it's not in the review but in the replies in the thread. Try this link.
Like swill said, no.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #8 on: Tue, 08 July 2014, 08:45:28 »
Bummer. This happened to me with an LED on my Poker. It's a real drag.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #9 on: Tue, 08 July 2014, 08:56:40 »
So you pulled a pad off.  It happens.  FYI, you probably left the soldering iron in one place for too long.  And no, you cannot just solder a switch there -- there is nothing to solder the switch TO without the pad. :(  But if you could actually do that, it would be fine for as long as the solder joint lasted.
Here is what they are saying about a jumper.
The "ring" that is missing has a trace going somewhere, I can't see it in your photo because it starts on the other side of the PCB, and then jumps between the top and bottom layer through the little dots (called "vias").  But the thing to do is to figure out where the trace from that hole eventually leads, and then to solder a small wire from the connector ("pin") on the switch TO the next component or pad where that trace leads.
The little wire will then "jump" from the switch to the place the trace led.  Thus, a "jumper wire".
Wire from an Ethernet cable is a good size for this purpose.
Your next step is to very carefully figure out where that trace leads.  Look in both directions, because everywhere along a trace is electrically identical.  If you are lucky, that switch pin connects to an identical pin above or below.  If so, you can easily solder a jumper between the two pins.  It may also lead to a tiny diode, in which case you will have to solder the jumper to the correct end of the diode -- without lifting the diode either.
Good luck!
 - Ron | samwisekoi
Offline frosty
  • jukebox hero
« Reply #10 on: Tue, 08 July 2014, 08:57:12 »
snip
where do i get these jumper wires? i don't get the picture either
Offline frosty
  • jukebox hero
« Reply #11 on: Tue, 08 July 2014, 09:04:24 »
Good luck!
 - Ron | samwisekoi
ugh. i shall take one with a full view.
the lifted pad is the lower pad of the two on page down.
Offline frosty
  • jukebox hero
« Reply #12 on: Tue, 08 July 2014, 09:04:39 »
looks like it connects to "end" key.
« Reply #13 on: Tue, 08 July 2014, 09:07:15 »
snip
I have 28 AWG wire that I bought at an electronics store. And see samwisekoi's explanation for more info. Essentially you messed up the connection of the circuit to the pad so you need the jumper wire to put the switch back into that circuit.
And your pictures should show the lifted pad. That way we can follow the traces or the little lines on the PCB that make up the circuit I was referring to before.
Offline frosty
  • jukebox hero
« Reply #14 on: Tue, 08 July 2014, 09:09:14 »
i can't see any visible connecting "dots" near the lifted pad.
Offline frosty
  • jukebox hero
« Reply #15 on: Tue, 08 July 2014, 09:10:23 »
is it safe to assume the lower pad of page down is connected to the lower pad of end from my pictures?
« Reply #16 on: Tue, 08 July 2014, 09:10:51 »
So you want to solder a wire like this, when you install the switch back into place...
Offline frosty
  • jukebox hero
« Reply #17 on: Tue, 08 July 2014, 09:12:37 »
all right! thanks for the info. so i guess the lower pad of pgdn leads to the lower pad of end then :-)
« Reply #18 on: Tue, 08 July 2014, 09:14:29 »
Guess so. When I tried to jump a QFR, it didn't work out that way. But maybe that's why it wasn't working either...
Offline frosty
  • jukebox hero
« Reply #19 on: Tue, 08 July 2014, 09:17:15 »
usually, the next pad you're supposed to jump to is one switch diagonal/to the top/bottom/left/right?
« Reply #20 on: Tue, 08 July 2014, 09:20:24 »
The way I understood it, you followed the trace in the PCB until you found the next switch then add a jumper wire from the switch with the lifted pad to that next switch.
Offline jorgenslee
« Reply #21 on: Tue, 08 July 2014, 09:38:36 »
I think it would be safe to just solder the switch back and make sure there is enough solder in the center of the hole to act as connector to the other side of the pcb. If that fails, you can always jump it to the point where you have illustrated.
Offline frosty
  • jukebox hero
« Reply #22 on: Tue, 08 July 2014, 09:41:57 »
will try jorgens's method. sounds legit. i will get some jumper wires ready in the mean time. razer y u sux at qc
Offline jorgenslee
« Reply #23 on: Tue, 08 July 2014, 09:46:59 »
This actually happens to me when I try to fix wife's qfr. The ring came out at first try. What I did is trace the pcb and scrape a part of it to reveal the bronze connector, add a solder and connect it to the switch using solder only.
Picture explains it better. lol
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #24 on: Tue, 08 July 2014, 10:22:41 »
No, don't.  Even if this works (and it might) you wouldn't ever be able to de-solder it.  You'd have to get the tip of an iron between the switch and the PCB, and that would be a PITA and possibly damage things more.
No, this is the easiest jumper you can ever do.  First solder the good pin on PgDn and both pins on End.  Then, get a 1" piece of wire, strip both ends a bit, and solder it straight between the two pins shown:
70144-0
Jumper between PgDn and End switches.
Those two switches are on the end of the PCB, have free space below, and are just 0.750" apart.  It doesn't get any simpler than that.
Again, a piece of wire from an old Ethernet cable, or really any kind of wire that isn't from a phone cord will do.  As long as you don't let bare wire touch the other terminal on the End switch, you are going to be golden.
Don't cheat.  It will actually be harder, and won't be a good thing to do to your keyboard.  Just do the jumper wire.
 - Ron | samwisekoi
Offline jorgenslee
« Reply #25 on: Tue, 08 July 2014, 10:50:06 »
 - Ron | samwisekoi
Ohh, my bad. I hope OP sees this before deciding what to do. In my opinion, there is still conductor left in the inner ring of the hole since it is a double sided pcb, can that still be use and place the solder there? A good amount of solder to secure contact, not that excessive though to avoid spilling the solder on the other side of the pcb.
Offline frosty
  • jukebox hero
« Reply #26 on: Tue, 08 July 2014, 10:50:42 »
i'll find a old cable, then pm you or post in this thread. thanks sam!
« Reply #27 on: Tue, 08 July 2014, 11:21:10 »
before you go soldering in jumpers and all that....
There's one possibility you may want to try. As you said originally, just solder the switch back on there. it could work.
See, those are plated through-holes (very nice!) which means that there's some metal in a ring in the inside of the PCB, and more metal on the opposite PCB side. It's possible to solder to the inner ring of metal, even if the pad is lifted.
I haven't seen this mentioned yet in the topic, and it's one of the major bonuses of having such a PCB.
If that doesn't work (and there's a good chance it doesn't) then I recommend getting the jumper wire as has been said. It's more of a "better safe than sorry" that is very reliable.
« Last Edit: Tue, 08 July 2014, 11:22:46 by dorkvader »
« Reply #28 on: Tue, 08 July 2014, 11:25:39 »
I just tried to force the switch back into the padless joint on the QFR I was working on and not only did it not work, I couldn't get all the solder out and it became a huge mess. I'd really advise you not to do that and try jumping it first.
If you want to try scraping it to reveal the copper that might work, I've never tried it myself. But I've had bad experiences with just soldering it back in.
« Reply #29 on: Tue, 08 July 2014, 11:26:23 »
Man I've lifted so many pads in my learning experience. I only recently learner about jump wiring and it's saved a lot of my personal work. I've had someone tell me to try those conductive writing pens but I have actually tried it yet. Also yeah with certain doubled sided pcb you aren't fully screwed since there's still a connection on the other side. good luck
« Reply #30 on: Tue, 08 July 2014, 11:27:32 »
Is the razer pcb double sided Sifo?
« Reply #31 on: Tue, 08 July 2014, 11:28:05 »
Can't confirm, I wouldn't expect it to be, it's razer
But I mean he can check :p
Offline Quardah
    • DeliTech
« Reply #32 on: Tue, 08 July 2014, 11:29:45 »
I think it is, please someone confirm this, but i believe the boards has a common ground or a common input or output.
If it's that way you can simply identify where it goes and join it to that common knot.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
« Reply #33 on: Tue, 08 July 2014, 11:40:07 »
Confirmed twice, by myself and samwisekoi. :)
And the second set of pictures he posted shows the front of the PCB, so yes, it's definitely double sided.
« Reply #34 on: Tue, 08 July 2014, 11:45:56 »
yellow brick road mother fker... yellow brick road...
Offline frosty
  • jukebox hero
« Reply #35 on: Tue, 08 July 2014, 12:14:11 »
will post pictures of the full pcb and plate later in the morning. it's 1.13am here. yellow brick(?)
« Reply #36 on: Tue, 08 July 2014, 12:31:59 »
copper get it?  yellow red-ish
Offline frosty
  • jukebox hero
« Reply #37 on: Tue, 08 July 2014, 12:49:21 »
oh my god i cant believe i didnt get it omalskfowocowckkf
« Reply #38 on: Tue, 08 July 2014, 16:52:25 »
note that the QFR has a one sided PCB, so my idea is not relevant there.
I recently lifted a pad on an ergodox, but was able to solder it just fine because of the plated through hole.
Offline frosty
  • jukebox hero
« Reply #39 on: Tue, 08 July 2014, 17:00:55 »
pictures as promised. i can't take them under these lighting conditions but if anyone wants a clearer picture please request one :)
Offline pasph
« Reply #40 on: Tue, 08 July 2014, 18:37:18 »
Has someone tried those conductive silver pens?
« Reply #41 on: Tue, 08 July 2014, 19:48:36 »
they work.. but they get scratched off easily, and over time the paint cracks if the pcb bends a little. WHICH IT WILL , because between summer and winter/ any other temperature change, the pcb flexes..
Offline mouse.the.lucky.dog
« Reply #42 on: Wed, 09 July 2014, 00:58:13 »
I'm wondering how the strength of the connection is affected?
Considering that part of the strength comes from the trace being attached.
I would use a laquered wire rather then some with plastic insulation.
In the future use flux on the parts that will be soldered desoldered. WHen the flux starts smoking be ready to pull the iron away in a couple of seconds.
Offline frosty
  • jukebox hero
« Reply #43 on: Wed, 09 July 2014, 01:16:11 »
Edit: double post
« Last Edit: Wed, 09 July 2014, 02:25:34 by frosty »
Offline frosty
  • jukebox hero
« Reply #44 on: Wed, 09 July 2014, 02:25:00 »
the area where i live basically is subjected to minimal temperature change, from 24-27 daily. so i guess i won't be experiencing melting (duh who does) or freezing temperatures any time soon. yay and nay for equatorial climates
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #45 on: Wed, 09 July 2014, 10:02:03 »
In the future use flux on the parts that will be soldered desoldered. When the flux starts smoking be ready to pull the iron away in a couple of seconds.
Multi-core rosin in deadly lead/tin solder FTW.
Also, ventilation!
 - Ron | samwisekoi
« Reply #46 on: Wed, 09 July 2014, 10:03:23 »
Oooo, good call on the single sided vs double sided PCBs.
Offline frosty
  • jukebox hero
« Reply #47 on: Wed, 09 July 2014, 10:25:16 »
i'll solder and see if it works, if not, i'll find a old cable of sorts
Offline frosty
  • jukebox hero
« Reply #48 on: Sat, 19 July 2014, 04:48:00 »
soldered it, works. fyi the solder DOES NOT go into the area where the pad was! so, double sided pcb users, fret not!
