Author Topic: MX brown tkl recommendations  (Read 3359 times)
Offline Harms
« on: Mon, 21 September 2015, 18:39:25 »
Hey everyone, I'm looking looking buy a new board with mx browns.
However, I have special criteria it has to be tkl with arrow keys and cherry stabs. I already have a cm qfr i and a kul so those are not options.
The board can be back-lit or not doesn't matter. So far I'm looking at Leopold on eBay since ducky shine 3 aren't being sold anymore. What do you guys recommend? Thank you.
« Last Edit: Mon, 21 September 2015, 18:43:38 by Harms »
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: MX brown tkl recommendations
« Reply #1 on: Mon, 21 September 2015, 18:49:10 »
I'd recommend a Filco but that uses costar stabs. It's a real solid board though.
I really have no idea what other board that uses cherry stabs other than those you've listed.
Maybe assembling one would fit your criteria? It's tons of fun too.  :)
Offline Harms
« Reply #2 on: Mon, 21 September 2015, 18:56:16 »
Ahah that's why I considering just buy a Leopold on eBay, I just hope eBay is reliable and thank you.
Offline njbair
    • nickbair.net
« Reply #3 on: Mon, 21 September 2015, 18:58:53 »
May I ask why you insist on Cherry stabilizers?
My boards:
Offline Harms
« Reply #4 on: Mon, 21 September 2015, 19:09:11 »
Easy to change/mod key caps did it on a costar before and it was hell lol
« Last Edit: Mon, 21 September 2015, 19:16:08 by Harms »
Offline njbair
    • nickbair.net
« Reply #5 on: Mon, 21 September 2015, 19:19:56 »
Fair enough. But don't limit yourself for that reason. Costar stabs are generally thought to be less stiff/better feeling, and that pays dividends more often than the relatively few times you change keycaps.
My boards:
Offline Harms
« Reply #6 on: Mon, 21 September 2015, 19:25:53 »
Yea you make a good point I guess I can practice on my old board and look into it, thanks.
Offline user 18
« Reply #7 on: Mon, 21 September 2015, 19:27:51 »
When changing caps on a board with Costar stabs, I place the inserts in proper alignment into the board, and press the cap onto the stabs + stem just like I would with Cherry stabs. Works at least 3/4 of the time, and it's really easy to tell if you've done it wrong.
Avatar by ashdenej
Offline Harms
« Reply #8 on: Mon, 21 September 2015, 19:41:41 »
Thanks for the advice boyzzz. So now there's so many options any really sick tkl boards out there with costar stabs mx browns? Backlit and non backlit options thanks bros.
Offline njbair
    • nickbair.net
« Reply #9 on: Mon, 21 September 2015, 19:50:28 »
I put the stab inserts into the cap first, then slip one side on, push it over to the side, and use pliers or something to bend the other bar out of the way enough to get the cap down into place.
My boards:
Offline njbair
    • nickbair.net
« Reply #10 on: Mon, 21 September 2015, 19:52:24 »
Filco makes a solid board. Can't go wrong with a Filco.
My boards:
Offline saturnotaku
« Reply #11 on: Mon, 21 September 2015, 19:58:49 »
Unless they changed the design, I thought KUL had Cherry stabs?
But if you're looking for something else, there are lots to choose from. KBParadise V80, Leopold FC750R, WASD v2 and the backlit CODE keyboard, Varmilo VA87MR, Ducky Shine, and Filco, among others.
Offline trrc
« Reply #12 on: Mon, 21 September 2015, 23:57:20 »
Can always look @ QF Rapid-I, to my knowledge all the LED issues have been worked out.
Offline Oobly
« Reply #13 on: Tue, 22 September 2015, 03:18:53 »
You already have a KUL... if you need another TKL why not just get another one?
Or better yet, if you want a new experience and can afford it, go straight for a GON NerD TKL. I'd suggest going with modded Clear switches, 62g springs + lube. Or ask him if he can put Zealios in it for you. A billion times better than current Browns. Vintage or well worn in Browns can be okay, but the current crop of stock Browns have very rough sliders, not to mention the wobbly switch tops.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Charizard
« Reply #14 on: Sun, 27 September 2015, 23:15:30 »
If you do decide you don't need the cherry stabs I would also recommenced the Filco MJ2, it's a well built board.
