Author Topic: If cases for 60% keyboards cost over $100, can't I just buy the Pok3r and tak...  (Read 2787 times)
Offline Vozella
If cases for 60% keyboards cost over $100, can't I just buy the Pok3r and take the case from that? Or is it not a good case?
Offline ideus
  • Björkö.
I thought that myself some days ago. It seems like a good die casted case, but the milled ones are better, or in the worst case heavier.
Offline Steezus
  • Keeper of Facts
The case for the Pok3r is bad at all and has a nice weight to it, downside though is that any milled case would be a better option.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
My Pok3r case is not bad considering it came with the board. However, the case is VERY roomy compared to other aluminum case options. I think this is because they have very loose tolerances on what is considered an acceptable plate length - mine was quite a bit longer on one side. I question some of the QC they are doing on these...my case has a screw stuck in one of the mounting holes; the screw head was sheared off. It came like that, I didn't break the screw.
Offline Steezus
  • Keeper of Facts
Pok3r case also has a plastic cover between the PCB and the case for insulation since it's cast aluminum.
Offline Connly33
I really wanted to go with a tex case, but i couldn't put $120 of my budget into the case. So i looked at the pok3r cases, they acctually sell them new on https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1002
But i found someone selling a pok3r case on the mech market subreddit for $40 when i made a post looking for a cheaper option, so i took that offer as fast as i could.
( was just going through this part of the forum for tips on first time builds and didn't realize i was commenting on a nearly dead thread)
« Last Edit: Sun, 20 December 2015, 08:16:45 by Connly33 »
Custom 60% with Cherry MX Clear
Offline Hypersphere
The case on my Pok3r does not sit flat -- it wobbles. However, if you don't mind having a cast aluminum case, you can buy them separately for less than the cost of a CNC aluminum case.
Offline absyrd
  • CPT HYPE PADAWAN
Offline lolpes
Is it possible to sand the pok3r case and anodise it again with a different color?
Offline VinnyCordeiro
I don't know, but I think it isn't desirable because of the way anodization works.
