Author Topic: [Solved] Inkspace isn't opening on my computer.  (Read 2146 times)
Offline Vozella
« on: Thu, 01 October 2015, 12:48:34 »
So, following this thread: https://geekhack.org/index.php?topic=75641.0
I downloaded Inkspace to put the designs in one file, but Inkspace isn't opening on my computer. Well, it does open, but I only see it in the task manager. What am I doing wrong?
Edit: Apperently it just takes a really long time to load. It works now.
« Last Edit: Thu, 01 October 2015, 13:19:45 by Vozella »
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Inkspace isn't opening on my computer.
« Reply #1 on: Thu, 01 October 2015, 13:07:47 »
Seriously, reboot fixes 90% of issues.
Offline Vozella
« Reply #2 on: Thu, 01 October 2015, 13:14:47 »
It was worth a try, but the problem still occurs.
I guess I'll just go for a different software.
