Author Topic: What kind of switch type boards can you throw in the dishwasher?  (Read 2710 times)
Offline snarfarlarkus
« on: Fri, 02 October 2015, 20:32:30 »
A couple of a my keyboard need a good clean so I figured the dish washer would be a good idea if the keyboard can handle it?
I have the following keyboards that need cleaning:
Model F XT
Model F AT
Model M 1391301
Northgate Omnikey 102 (blue alps)
Cheers!
Re: What kind of switch type boards can you throw in the dishwasher?
« Reply #1 on: Fri, 02 October 2015, 20:47:14 »
No
Offline FrostyToast
  • Litshoard
« Reply #2 on: Fri, 02 October 2015, 20:52:25 »
You're going to throw blue alps in the washer?
Might as well give it to someone who will think to respect the board .-.
Quote from: elton5354
Offline fanpeople
« Reply #3 on: Fri, 02 October 2015, 21:02:01 »
The fully assembled keyboard? or parts of said keyboard.
If fully assembled, you psychopath. I would recommend washing your mobile phone in the dishwasher also (those things get pretty dirty).
If parts I would wash by hand with warm soapy water for example the outter shell of the model M AFTER it has been dismantled. The last lot of keys I washed from a Model M I just put in a tub of warm soapy water and didn't bother actually scrubbing and they came out quite nicely.
« Reply #4 on: Fri, 02 October 2015, 21:14:04 »
No
This.
If you have *completely disassembled* the keyboard, many of the individual parts can be subjected to soapy water if rinsed very well and allowed to dry.
- D Trump 2026-10-24
« Reply #5 on: Fri, 02 October 2015, 21:23:52 »
Don't worry! I wasn't going to throw the whole assembled keyboard into the dish washer... It would have just been parts after disassembling the keyboard.
Offline tararais
  • Forum Justice Warrior
« Reply #6 on: Fri, 02 October 2015, 22:15:46 »
That's crazy, treat the electronics gently. Soap and switches don't mix, you can use some water but soap.. probably best to avoid.
Offline fanpeople
« Reply #7 on: Fri, 02 October 2015, 23:05:36 »
You wash parts like frame with soap, you then rinse it and dry you don't physically wash the internals. How else do you remove 20 years of scum build-up?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8 on: Fri, 02 October 2015, 23:13:40 »
With 90%+ isopropyl alcohol.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #9 on: Sat, 03 October 2015, 04:10:35 »
Don't use a dishwasher. Take off the caps, take the boards apart, and clean all the parts separately. Caps and cases with warm soapy water, the rest carefully with iPrOH. Restoring old boards takes time and care :) .
Offline Bucake
« Reply #10 on: Sat, 03 October 2015, 07:18:37 »
this..!
i just don't trust the dishwasher enough. the risk is damaging something irreplaceable.. no thanks!
well, maybe you could put the case in there, but it (usually) takes little time and effort to clean something like the case. so yeah.. i just wouldn't bother.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #11 on: Sat, 03 October 2015, 10:37:02 »
It's a great way to ruin it.  I won't even explain the damage a dishwasher can do.
I bought a Trackpoint II off eBay that was run through one.  Even after cleaning up the already damaged-beyond-repair mess, replacing cables, and getting it to "work", it was AWFUL.
I nearly threw it in the trash.  Instead, I had Maxx from Phosphorglow.net restore it.  I'm glad he did.
http://imgur.com/a/b4Q7Q
Offline jonathanyu
« Reply #12 on: Sat, 03 October 2015, 11:29:45 »
the only keyboard you should throw in dishwasher
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #13 on: Sat, 03 October 2015, 12:03:44 »
Blender is always the better solution. Microwave really cleans well, too.
