Author Topic: Made some switch tools. Just sharing the information.  (Read 2507 times)
Offline MrRooks
  • Always be knolling
« on: Fri, 09 October 2015, 15:05:10 »
I remember seeing the TI switch tools TheBeast made a while ago and wanted a pair of my own. I had some scrap aluminum laying around so I made some tools! The aluminum was some angle aluminum I picked up at Lowes and just hack sawed these chunks out of it.
It was pretty simple. I took some basic measurements of a switch using a caliper and went from there. The tools are 11mm wide(roughly, I used a hack saw). A 1/4" drill bit was used to drill out the rounded part then sawed out the extra bits to make the legs. I used some hand files to taper the tips and a pair of pliers to give the handles a slight bend. They aren't the prettiest but they work perfectly!
« Last Edit: Fri, 09 October 2015, 15:07:43 by MrRooks »
Offline trenzafeeds
  • **** off
Re: Made some switch tools. Just sharing the information.
« Reply #1 on: Fri, 09 October 2015, 15:17:10 »
Awesome! Those look nice.
demik will never leave.
Unless he gets banned.
« Reply #2 on: Fri, 09 October 2015, 17:51:40 »
They're tools, they aren't supposed to be pretty :))
Good work!
Offline VinnyCordeiro
« Reply #3 on: Fri, 09 October 2015, 20:48:37 »
Did I heard "group buy"? :p
Offline ideus
  • Björkö.
« Reply #4 on: Fri, 09 October 2015, 21:18:58 »
Good work!
They look pretty as in tool-pretty, which is functional. Good job, and thank you very much for sharing. I am using simple jewelry screw-drivers to remove my switche's tops now; but, I'd love to get some like yours if available.
Offline sz42
« Reply #5 on: Tue, 13 October 2015, 15:27:05 »
For the impatient...
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1363
Thanks a lot for sharing how you made yours though.  I'd rather make up my own sets than pay horrendous shipping charges.
Offline ideus
  • Björkö.
« Reply #6 on: Tue, 13 October 2015, 15:28:49 »
Just for your information, I wrote the GM and he made a nice discount to the shipping cost, so I got them. They are now in the mail.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Tue, 13 October 2015, 16:24:18 »
Nice job.
And stop stealing my location.
