Author Topic: Silicone cap keys  (Read 6154 times)
Offline awb555
Silicone cap keys
« on: Thu, 22 October 2015, 18:18:30 »
I have this keyboard:
http://flash.newegg.com/product/9SIA11P0C88197
It has a rubber dome membrane.
I really like the way the "AWSD" feel but It's weird how the other keys feel.
I want the same texture on all of the keys. (just the letters, numbers and punctuation)
I can't tell if it's a silicone on top of the key it's self or the whole entire key.
Can someone please point me in a direction where to find what I'm looking for?
Thank you!
Ps. Obviously not the "G" keys
Offline Kad
  • Δ E S T H E T I C S
Re: Silicone cap keys
« Reply #1 on: Thu, 22 October 2015, 18:31:47 »
Hmm, looking at the photo it appears they are an entirely different key, but let's do some poking around first. Can you try and take off one of those caps you like and see if it's like a silicone sleeve on top of a regular black key?
[WASD v2 w/ MX Blues]
Offline awb555
« Reply #2 on: Thu, 22 October 2015, 19:01:14 »
If it is a "silicone sleeve" its glued on and not coming off.
I can see black under the orange and I can feel a lip.
Why would that matter? I like those keys.
Offline Kad
« Reply #3 on: Thu, 22 October 2015, 20:13:52 »
Well that helps answer your question  ;D
Not too sure how easy it would be to get more of them to "sleeve" your other caps with since it's such a specific thing, one suggestion would be to contact the manufacturer directly using this link and ask them if they'd be willing to sell you more. Another thing you could do if you already have the resources is attempt to 3D print some sleeves but it will probably feel a little different and not color match exactly.
Good luck!
Offline awb555
« Reply #4 on: Fri, 23 October 2015, 16:39:59 »
I called manufacturer and they said the keys are silicone cap not just sleeves.
Where can I find silicone cap keys? Preferably green or black but I'm not picky.
Offline SamirD
« Reply #5 on: Fri, 23 October 2015, 21:04:46 »
Ummm...call them back and ask them how much they'll sell you them for.
Offline awb555
« Reply #6 on: Fri, 23 October 2015, 23:45:41 »
A: they only make (ASWD) keys.
B: the letters on those keys are SUPER TINY!
Offline SamirD
« Reply #7 on: Sat, 24 October 2015, 08:44:57 »
But I think that's going to be your only source unless you can find the manufacturer of the keys and contact them for a custom order.
Offline awb555
« Reply #8 on: Sat, 24 October 2015, 10:06:11 »
Are you saying no one makes silicone keys?
Or they just won't match the feel of the ASWD keys if I go elsewhere?
Offline Kad
« Reply #9 on: Sat, 24 October 2015, 22:25:23 »
Likely if you get the caps from someone other than the supplier you won't get caps that feel the same just simply because they're not from the same source.
I'd try phoning up the manufacturers again and seeing if they'll sell you a bag of 'em.
Offline awb555
« Reply #10 on: Sat, 24 October 2015, 23:55:01 »
I don't care if they feel the same. If all else fails I'll buy new "ASWD" keys.
I just need to know of a store who sells silicone cap keys..
Offline SamirD
« Reply #11 on: Sun, 25 October 2015, 07:31:14 »
There doesn't seem to be a store who does because the knowledge here on keycaps is impressive and no one has pointed you to a source. :(
I'm afraid those aswd keys may be the old ones that you can easily get.
Offline awb555
« Reply #12 on: Sun, 25 October 2015, 13:35:51 »
Just hard to believe that the only keys that you can find in silicone/rubber is the ASWD keys.
I mean you can find a liver, but yet no silicone/rubber keys on the internet!
Offline SamirD
« Reply #13 on: Sun, 25 October 2015, 19:05:23 »
Yep, and it makes sense because more people need livers than silicone aswd keys, lol.
Offline awb555
« Reply #14 on: Sun, 25 October 2015, 21:17:19 »
Ok...lets change my question up... Instead of me asking who makes keys OTHER THAN "ASWD"keys.
Who makes silicone ASWD keys?
Offline Kad
« Reply #15 on: Sun, 25 October 2015, 21:21:36 »
Alright. After doing a little research I found this old GH thread that has a similar question.
There was a newegg link in there that seems to have what you want but unfortunately it's out of stock.
I think you'll find this is a fairly uncommon request and it may be very challenging to track down more of these type of keys.
Offline awb555
« Reply #16 on: Tue, 27 October 2015, 21:33:39 »
Finally a real answer (kinda) lol!
I called the manufacture again...Apparently even if I found keys with silicone they wouldn't work because they use infrared to detect key strokes. They said it's there own technology??? Does this sound right??
Offline SamirD
« Reply #17 on: Wed, 28 October 2015, 11:11:24 »
Wha?  Infrared?  Doesn't sound right to me if it's a mechanical keyboard.  I think someone was just messing with you.
Offline meevilsheep
« Reply #18 on: Wed, 28 October 2015, 15:23:09 »
That`s the thing.. that keyboard is a A4Tech G800V. Not mechanical
Offline SamirD
« Reply #19 on: Wed, 28 October 2015, 18:12:21 »
Hmmm...at that price point I don't think it's using anything exotic like that, but I could be wrong.  :-\
Offline neverused
« Reply #20 on: Wed, 28 October 2015, 18:32:47 »
Personal opinion: those keys look gross to type on and like they will soil easily.
You should be able to harvest stems from another set and silicone mold your own keys.
Or you could try plastidip, not the same but it may be close enough.
Offline awb555
« Reply #21 on: Thu, 29 October 2015, 21:12:59 »
They said "
I apologize to inform you but, I have received word that it would take a lot of tooling to get these keycaps, so we regret to inform you that we are unable to help you find a solution for these keycaps.  I will keep an eye out for similar style of keycap to help you find your solution for this matter.
I hope you have a wonderful rest of the day.  Than you!"
Offline SamirD
« Reply #22 on: Thu, 29 October 2015, 23:08:52 »
Yeah, I figured it would be like that.  But you had to try!  I'm sure there's other ways to get the caps you want, so keep searching.  :thumb:
Offline mszy52
« Reply #23 on: Fri, 30 October 2015, 18:47:45 »
how much did this board cost origionally? It doesnt look mech
Offline awb555
« Reply #24 on: Sat, 31 October 2015, 16:48:53 »
It's originally $50 I got it for $25 (newegg flash sale)
