Author Topic: What makes Topre Topre?  (Read 6565 times)
Offline moshimalloe
« on: Sun, 01 November 2015, 21:07:19 »
I'm so in love with my Novatouch right now, and I was thinking about this. Couldn't quite find an answer online, but what is it in a Topre switch that differentiates it from a regular rubber dome?
I know that it's capacitive as opposed to by-contact, but that shouldn't change the feel of it. What makes the Topre rubber domes feel so much better than a mushy regular rubber dome?
Offline Hblue
  • mad props to the hood yo
Re: What makes Topre Topre?
« Reply #1 on: Sun, 01 November 2015, 21:17:22 »
The "stiffness" of the dome is much more even, meaning that the force required to depress it is pretty much equal from start to finish, which eliminate the god awful "dome break" that cheap rubber dome keyboards have in order for you to actuate the "switch". This also provides a smooth travel that mechanical switches tend to offer.
That alone makes Topre a lot better already then regular rubber domes, but having the option for high end caps in your case (and stock thick PBT caps on the HHKB/Realforce for instance) makes the typing experience even better while also providing a more solid feel as well as longer lasting caps.
The build quality is also often a lot better in Topre keyboards. The Realforce, Leopold, Novatouch, HHKB are all pretty solid keyboards.
Those are the reasons why I prefer Topre anyway. Others may have better explanations of how Topre works exactly if you're curious about that.
HHKB & MJ2, Typing & Gaming.
S e r e n d i p i t y
Offline beehatch
  • baehatch
« Reply #2 on: Sun, 01 November 2015, 21:24:22 »
That's like asking what makes boobs boobs. You don't question it, just enjoy them.
Offline ghostjuggernaut
« Reply #3 on: Sun, 01 November 2015, 21:28:40 »
This is some gospel level ****.
Offline Charizard
« Reply #4 on: Sun, 01 November 2015, 23:18:05 »
I agree with the earlier replies. For me the keypress is much more consistent than a rubber dome board. You never have to really mash on a key to get it to register the press on a topre like I find myself having to do from time to time on a rubber dome. I also greatly prefer the sound of typing on a topre when compared to a standard rubber dome.
Of course, your own impressions and opinions may vary.
Offline joc
« Reply #5 on: Sun, 01 November 2015, 23:42:38 »
High quality components - Topre uses the best rubber available.
Offline jerue
  • (Whenever that happens :P)
« Reply #6 on: Sun, 01 November 2015, 23:43:57 »
Knowing you have become one with cup rubber...is there really any other way to describe it?
Offline Polymer
« Reply #7 on: Mon, 02 November 2015, 00:35:18 »
They do have dome break..as in the pressure isn't equal from start to finish..but that doesn't matter..
For me sliders and how they're made is key...They add a lot of stability to the key from the time you press it till the time you bottom out.  There isn't a lot of play and when it hits bottom it is an even solid feel across the key without a lot of excess squeek/movement you get from regular rubber dome keyboards which, when you hit bottom, you can continue to push it down further, move it around, etc..  The sliders stability also helps for the smoothness of the key.
That solid feel is really what separates the two...
Topre also feels a lot more responsive because it is actuating before you bottom out..It lets you be a bit lighter on your key presses as well as just feels like it is responding faster and with less effort...
Add to that the reliability...not requiring contact leaves very little for things to go wrong on the keyboard...
Offline oxchamballs
« Reply #8 on: Mon, 02 November 2015, 08:47:23 »
There's something in the rubber that makes it so good.. The Royal Kludge comes close but the dome sheet in it feels mushy compared to both my Topre boards.
btw 2nd post ever hi :D
Offline tronbeaver
« Reply #9 on: Mon, 02 November 2015, 09:00:30 »
HHKB is gods layout.
Offline Bucake
« Reply #10 on: Mon, 02 November 2015, 09:26:22 »
the high price tag
Offline keshley
    • Blog n stuff
« Reply #11 on: Mon, 02 November 2015, 09:49:16 »
Oneness with cup rubber!
Its a pretty luxurious feeling. I've had people try out my HHKB and absolutely love the feel without knowing it was an 'expensive' board.
Also, Type Heaven boards don't have high price tags.
HHKB Pro 2       Pok3r
Offline ice31000
  • Just a block of ice on a journey of clacking.
« Reply #12 on: Mon, 02 November 2015, 12:20:11 »
thock and the HHKB layout.
iceyy
Offline Lurch
« Reply #13 on: Mon, 02 November 2015, 12:22:28 »
Quote from: Flyersfan1
Offline GL1TCH3D
« Reply #14 on: Mon, 02 November 2015, 13:25:38 »
Thock thock thock thock
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #15 on: Mon, 02 November 2015, 13:53:10 »
because you get to be part of the  super awesome elite topre club.
Offline keyboardia1
« Reply #16 on: Mon, 02 November 2015, 14:22:10 »
Offline GL1TCH3D
« Reply #17 on: Mon, 02 November 2015, 14:24:06 »
Yea
no newbs #420toprelyfe
« Reply #18 on: Mon, 02 November 2015, 16:21:56 »
* The stroke is very stable and smooth. There is no binding on off-centre key presses, very little wobble and no rattle.
Hitherto I have not tried any mechanical key switch that is as smooth as Topre, but I have heard that vintage hall-effect switches would come close.
* Actuation in the middle of the stroke (like mechanical metal-contact switches)
* Rubber dome tactility, except that
* There is no mushiness on bottoming out, but bottoming out is just right soft, not hard.
Offline SamirD
« Reply #19 on: Mon, 02 November 2015, 19:21:58 »
This sounds really good.  I'll have to definitely try one someday.  :thumb:
Offline gadzkun
« Reply #20 on: Tue, 03 November 2015, 05:34:57 »
what makes topre topre i think..
rubber dome feels but still mech keys  :thumb:
Offline slaction
« Reply #21 on: Tue, 03 November 2015, 22:56:04 »
They are really expensive, so people assume they are good.  It's all hype/marketing.  HHKB people sold a rubber dome keyboard to mech keyboard fans and charged them 2x more than a mech...that's some marketing genius right there.
Offline oxchamballs
« Reply #22 on: Tue, 03 November 2015, 23:10:16 »
Offline Glenmael
« Reply #23 on: Tue, 03 November 2015, 23:31:39 »
preaaach!
Offline fuzzybaffy
« Reply #24 on: Wed, 04 November 2015, 06:00:28 »
Apparently slaction doesn't understand the concept of higher quality components being more expensive for manufacturers to make.
People can subjectively hate on Topre switches all they want, but objectively there is flat-out no denying that they are better built and better quality than Cherry MX switches.
Offline Polymer
« Reply #25 on: Wed, 04 November 2015, 08:20:57 »
That was a long time excuse....until cheaper Topre came out and then it wasn't really a factor vs. MX boards...and suddenly a ton of Topre users came out of the woodwork because it was cheaper...No more excuses any longer...
Offline swimmingbird
  • keyset hoarder
« Reply #26 on: Wed, 04 November 2015, 16:48:29 »
Yeah this belief that mechanical switches are always better than anything else is something that I think stems quite a lot from Corsair marketing and reddit users who haven't even used Topre before.
I can honestly say that while I love my GON with Ergo Clears, the typing experience on my RF 87u 55g still feels more refined
Offline tronbeaver
« Reply #27 on: Thu, 05 November 2015, 10:56:39 »
Wait, I've used both Topre and Reddit before.
Your correlation is flawed.
  • keyset hoarder
« Reply #28 on: Thu, 05 November 2015, 22:46:01 »
I never stated that reddit users who have never used topre before were all reddit users
lrn to rd
Offline Weltschmerz
« Reply #29 on: Mon, 09 November 2015, 04:27:28 »
That sounds like some premo rubber right there.
Offline ideus
  • Björkö.
« Reply #30 on: Tue, 10 November 2015, 08:04:59 »
After reading the posts at this thread, and this in particular, I was almost talked into the Topre madness.  :p
Offline MeltingTeeth
« Reply #31 on: Tue, 10 November 2015, 11:06:23 »
Topre is worth trying.
Offline jerue
« Reply #32 on: Tue, 10 November 2015, 11:44:47 »
Just make your 2nd mech a Topre one ideus. Do eeet. Do eeet NAO
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #33 on: Tue, 10 November 2015, 11:48:09 »
+1
but in all seriousness, Topre is just a very high quality rubber dome. I mean have you seen the logic board on those things? ziiing
« Reply #34 on: Tue, 10 November 2015, 11:57:40 »
****'s cash.
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
« Reply #35 on: Tue, 10 November 2015, 12:40:18 »
The noise the keys make is definitely part of the appeal for me. Also the lack of key wobble Cherry switches can have. Quality PBT keycaps as standard, a nice profile and a very predictable keyswitch action that varies little between keys.
May all your key presses strike true.
  Choc Mini         HHKB
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #36 on: Tue, 10 November 2015, 12:56:39 »
Being one with the cup rubber
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
