Author Topic: Acrylic Case  (Read 2441 times)
Offline bocahgundul
  • a seal
Acrylic Case
« on: Tue, 03 November 2015, 06:39:43 »
Worth it? or just save more for Alu?
Offline bocahgundul
  • a seal
Re: Acrylic Case
« Reply #1 on: Tue, 03 November 2015, 07:14:59 »
Anyone?
Offline lolpes
Re: Acrylic Case
« Reply #2 on: Tue, 03 November 2015, 07:20:48 »
It's a matter of taste really, they are both pretty resilient. Also acrylic is lighter if that influences your decision
Re: Acrylic Case
« Reply #3 on: Tue, 03 November 2015, 07:23:06 »
It's all personal preference.
Offline bocahgundul
  • a seal
Re: Acrylic Case
« Reply #4 on: Tue, 03 November 2015, 07:27:38 »
is it better than stock plastic?
Offline lolpes
Re: Acrylic Case
« Reply #5 on: Tue, 03 November 2015, 07:29:14 »
Offline CannabisWeekly
    • Tech Nerd / Cannabis Weekly
Re: Acrylic Case
« Reply #6 on: Tue, 03 November 2015, 07:30:10 »
I love clear acrylic cases! I know its not everyone's thing but I think it looks good.
Re: Acrylic Case
« Reply #7 on: Tue, 03 November 2015, 07:31:41 »
You might mention what keyboard you are asking for.
Offline bocahgundul
  • a seal
Re: Acrylic Case
« Reply #8 on: Tue, 03 November 2015, 07:38:00 »
like the sturdy kul es 87 case
Re: Acrylic Case
« Reply #9 on: Tue, 03 November 2015, 07:39:23 »
I don't think you will find an acrylic or aluminum case that fits the kul 87 so you really have no choice but to use the stock case.
Offline lolpes
Re: Acrylic Case
« Reply #10 on: Tue, 03 November 2015, 07:46:55 »
There aren't many if any aftermarket cases for that board, other than the ones provided by KUL. Bu you can always try to make one in acylic ;)
Offline Pwner
  • soon™
Re: Acrylic Case
« Reply #11 on: Tue, 03 November 2015, 07:52:54 »
Are there any decent clear acrylic cases out there or is the frosted tex the best option?
Offline bocahgundul
  • a seal
Re: Acrylic Case
« Reply #12 on: Tue, 03 November 2015, 09:39:14 »
No I mean i have a friend that have a cnc machine so i want to try it out
Re: Acrylic Case
« Reply #13 on: Tue, 03 November 2015, 09:41:11 »
See this is the kind of information that's important to include in your original post.
I'd start with acrylic to get the feel for what fits good and to work out any bugs out and then transition to aluminum.
Offline gadzkun
Re: Acrylic Case
« Reply #14 on: Tue, 03 November 2015, 10:16:50 »
if you can make it for free just do it man :) hhe..
Offline ideus
  • Björkö.
Re: Acrylic Case
« Reply #15 on: Tue, 03 November 2015, 12:47:45 »
I prefer my acrylic case to stock ABS ones, I prefer it even over aluminum, because I do not need, as most do, my keyboard to weight a ton.
Offline bocahgundul
  • a seal
Re: Acrylic Case
« Reply #16 on: Wed, 04 November 2015, 08:22:07 »
thx man for the tips
