Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 268632 times)
Offline p3lim
Re: [GB][SHIPPING] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #600 on: Fri, 15 January 2016, 12:42:15 »
Is there any information about the supplied firmware and bootloader?
Offline tDr1v3r
« Reply #601 on: Fri, 15 January 2016, 14:14:06 »
Mine arrived too in Tuesday! I can't express how happy I am seeing the quality of the PCB... it's really good.
razer blackwidow tournament edition w/ mx blues, vortex pok3r w/ mx browns, b.face x2 - wip w/ tex acrylic case, silver plate and 65g tactile zealios
Offline chancellorr
« Reply #602 on: Fri, 15 January 2016, 14:19:37 »
http://blog.winkeyless.kr/183
Offline f1xedgear
« Reply #603 on: Fri, 15 January 2016, 14:22:51 »
Not sure if this helps, but the source for the firmware is on GitHub here. I think the bootloader is the default one that comes with the atmega32 microcontroller.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #604 on: Fri, 15 January 2016, 14:24:59 »
https://geekhack.org/index.php?topic=58945.0
Or you can follow this guide.
Offline f1xedgear
« Reply #605 on: Fri, 15 January 2016, 14:29:06 »
Note that the B.face runs ps2avrGB, while the FaceW in those examples runs ps2avrU. The guide should be the same for both other than you need to remember to flash the right firmware :D
Offline p3lim
« Reply #606 on: Fri, 15 January 2016, 14:51:51 »
Right, I was thinking of flashing TMK on mine, but I have to drill new holes on the PCB first (didn't support my flipped off-center-stem spacebar :p).
As soon as I've done that I could go about figuring the pinouts for each row/column and do some tests.
Offline f1xedgear
« Reply #607 on: Fri, 15 January 2016, 14:57:18 »
Were you going to replace the microcontroller? The B.face/FaceW boards do not support TMK because of they lack hardware USB and the USB stack used by ps2avrGB is not supported by TMK.
Edit: Regarding the spacebar stem, maybe it would be easier to graft a new stem onto the spacebar from a key you dont mind destroying?
Offline p3lim
« Reply #608 on: Fri, 15 January 2016, 15:13:08 »
That makes it a bit more challenging, I thought it was using the U4.
Drilling three holes and jumpwiring it to the pins next to it is a better long-term solution IMO.
Offline f1xedgear
« Reply #609 on: Fri, 15 January 2016, 15:17:19 »
Just be extremely sure that there are no traces where you drill :) AFAIK, the PCB is just 2 layers, so you should be able to see all traces since they run on the outside where they are visible.
Edit: remove dangling half-though-out sentence that wasnt supposed to be there :P
« Last Edit: Fri, 15 January 2016, 15:34:08 by f1xedgear »
Offline p3lim
« Reply #610 on: Fri, 15 January 2016, 15:28:30 »
Since you can mount the switches to the plate
I'll have to cut the MISO trace (which I have no use for myself anyways), as it's pretty much directly where the top pin would be.
Kind of considering selling the kit instead, should've done more research beforehand.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #611 on: Fri, 15 January 2016, 15:29:40 »
Well, if you do that, there is definitely people around that is willing to pick it up.
Offline p3lim
« Reply #612 on: Fri, 15 January 2016, 15:45:19 »
No doubt :thumb:
Offline techmattr
« Reply #613 on: Fri, 15 January 2016, 21:44:48 »
Got my order today. Thanks LeandreN! Great job!  :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #614 on: Sat, 16 January 2016, 04:56:31 »
Hopefully you have enough stabilisers for a lifetime :D
Offline flob_ert
« Reply #615 on: Sat, 16 January 2016, 05:37:48 »
I am still waiting on keycaps, but I couldn't  resist the urge to build...
124500-0
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #616 on: Sat, 16 January 2016, 05:40:06 »
wooo!
That looks really nice.
Is that the Vortex CNC case?
Offline flob_ert
« Reply #617 on: Sat, 16 January 2016, 05:48:22 »
wooo!
It is the Vortex case, I got it from pexon during the sales. It needed a little modding for the PCB to fit as the fins blocked some of the controller parts.
124502-0
124504-1
Offline kevral
« Reply #618 on: Sun, 17 January 2016, 06:20:04 »
Oh joy, I was planning on using that exact case and wasn't prepared to dremel it...
Which plate is that? Steel or grey aluminium? End product looks good :)
Offline flob_ert
« Reply #619 on: Sun, 17 January 2016, 10:53:06 »
Thank you. I wouldn't worry about it, using a Dremel it only took a couple of minutes to grind down the fins. I ordered the steel plate in the GB but used a grey plate (also bought from LeandreN) for this build.
I would love to see some pictures when you finish your build  :)
Offline bloodl1n3
« Reply #620 on: Sun, 17 January 2016, 17:59:27 »
I received my package this weekend and the plate looks awesome! This is the first build I've done and have a couple questions :)
I bought some zealios when he had his sale a few weeks ago and it looks like the two plastic pieces on the switches are preventing the metal contacts to go all the way through the PCB. Do I need to clip those off first?
I also wanted some LEDs for my switches and wanted to know if there were any recommendations for the Winkeyless PCB. If I could get them on Amazon, that would be great.
One last question - is there a guide or YouTube video of someone assembling everything? I'd like to follow along with someone elses build to make sure I don't mess anything up! :P
Offline Numpy
  • The feels man
« Reply #621 on: Sun, 17 January 2016, 18:42:31 »
Here's https://www.youtube.com/watch?v=gdLAdci6p-w a super useful video that I'm going to use to build my keyboard.
Hope it helps!  :D
Custom 60%: Cherry MX blues with 62g gold springs and PBT Black on Black dyesub keycaps.
Other Keyboards: Deck Hassium Pro (MX Browns), the underated Leopold FC660M (MX Browns)
Offline f1xedgear
« Reply #622 on: Sun, 17 January 2016, 19:18:12 »
You don't need to clip anything, the two plastic pins on PCB mount switches are supposed to go into the corresponding holes on the PCB. They are supposed to have an interference fit, and sometimes feel like they actually "snap" into place once you get them seated all the way (at least mine did).
I think pretty much any 3mm LED will work.
LeandreN made this video of a B.face build a short time ago, which should help.
Offline nmur
  • ಠ_ಠ
« Reply #623 on: Mon, 18 January 2016, 03:13:54 »
got my stuff!
build is imminent
Offline Jumie
« Reply #624 on: Mon, 18 January 2016, 03:14:51 »
When I finish this build later, do I still need to flash firmware even though I'm using default layer and function?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #625 on: Mon, 18 January 2016, 03:15:32 »
got my stuff!
build is imminent
Wow, this is going to be a beautiful build. Thanks for posting and have fun!
Offline nmur
  • ಠ_ಠ
« Reply #626 on: Mon, 18 January 2016, 03:16:28 »
got my stuff!
build is imminent
thank you!
I'll make sure to post back here when I'm done
Offline TalkingTree
    • My projects
« Reply #627 on: Mon, 18 January 2016, 03:45:01 »
I received my package a few minutes ago. I'll post some pictures as soon as I've assembled my board.
Thank you LeandreN.
Offline Numpy
  • The feels man
« Reply #628 on: Mon, 18 January 2016, 04:19:16 »
got my stuff!
build is imminent
Wow, you're going to pull off a professional looking white board super well.
If you don't mind me asking, what's the blue sheet of paper for?
Offline nmur
  • ಠ_ಠ
« Reply #629 on: Mon, 18 January 2016, 04:24:57 »
got my stuff!
build is imminent
thanks dude
those are switch stickers. they're meant to reduce wobbling between the bottom and top half of the switch housing, but the difference is minimal, if noticeable at all. it's more for aesthetics.
Offline Numpy
  • The feels man
« Reply #630 on: Mon, 18 January 2016, 06:03:49 »
got my stuff!
build is imminent
thanks dude
Oh right, thanks for your opinion on them or I would have felt obliged to go out and get some  :))
Offline Jumie
« Reply #631 on: Mon, 18 January 2016, 06:11:24 »
When I finish this build later, do I still need to flash firmware even though I will be using default layer and function?
sorry for bumping.. anyone can advise?
Offline TalkingTree
    • My projects
« Reply #632 on: Mon, 18 January 2016, 06:13:38 »
Most PCBs come with a preloaded firmware. Just plug it in and see what keys register. You might want to flash your firmware anyway. It's very easy with the GUI software.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #633 on: Mon, 18 January 2016, 06:25:40 »
It will come pre flashed. Also left alt and left CTRL won't work, you need to reassign them from Korean letters.
Offline Jumie
« Reply #634 on: Mon, 18 January 2016, 07:39:56 »
nice, thanks :thumb:
Offline TalkingTree
    • My projects
« Reply #635 on: Mon, 18 January 2016, 07:51:52 »
Tuberous picture of my ongoing project. Switches aren't soldered in yet.
Some layout details anyway:
1. ANSI enter;
2. Two 1u keys in place of a 2u backspace;
3. ISO left shift;
4. Short right shift;
5. 7u Spacebar with 1.5u, 1u, 1.5u modifiers;
6. Stepped caps lock (which is going to be Ctrl);
7. Two stabilizers only.
Offline chancellorr
« Reply #636 on: Mon, 18 January 2016, 08:57:59 »
Just curious, how long did it take for you to receive your packages once they shipped?
Offline braidn
« Reply #637 on: Mon, 18 January 2016, 09:09:09 »
1. ANSI enter;
3. ISO left shift;
Pretty much what I am building but without the 1u's (winkeyless)
Offline chancellorr
« Reply #638 on: Mon, 18 January 2016, 09:19:29 »
1. ANSI enter;
3. ISO left shift;
Same here.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #640 on: Mon, 18 January 2016, 10:35:04 »
1. ANSI enter;
3. ISO left shift;
1. ANSI enter;
3. ISO left shift;
This is a cool layout. Eliminating stabilisers, i see.
Offline TalkingTree
    • My projects
« Reply #641 on: Mon, 18 January 2016, 11:33:10 »
Twelve days including shipping and delivery days. Pretty much the same timespan on everything I got from LeandreN.
Offline TalkingTree
    • My projects
« Reply #642 on: Mon, 18 January 2016, 11:34:13 »
Indeed, on the other board I might probably go for 2.25u right shift because it's easier for keycaps.
Offline chancellorr
« Reply #643 on: Mon, 18 January 2016, 11:35:55 »
Awesome! Thank you.
Offline f1xedgear
« Reply #644 on: Mon, 18 January 2016, 11:50:05 »
Awesome! Thank you.
Wow, might take a while for stuff to reach Michigan then...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #645 on: Mon, 18 January 2016, 11:51:18 »
Awesome! Thank you.
Shipping to USA is often faster than some European countries.
Offline chancellorr
« Reply #646 on: Mon, 18 January 2016, 11:54:15 »
Awesome! Thank you.
Even better. Thanks again LeandreN
Offline Sisric
« Reply #647 on: Tue, 19 January 2016, 09:55:12 »
Got mine! Thanks LeandreN! Now I need to figure out how to build the bloody thing... :D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #648 on: Tue, 19 January 2016, 10:05:25 »
Use on of my builds as a refrence :D
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #649 on: Tue, 19 January 2016, 12:01:17 »
