Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 268632 times)
Offline Numpy
  • The feels man
Re: [GB][SHIPPING] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #700 on: Sat, 23 January 2016, 21:01:09 »
Woooo it all came! Thanks LeandreN for this great GB! :D ... Though you forgot to change my shipping address that i emailed you about Thats ok though, i was lucky someone was here to take the package :D
have some pics:
(Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link)
And yes, the ugly USB cable will be replaced :D
ISO GER, white in-switch LEDs, PBT Vortex set for now ... really waiting for their doubleshot PBT backlit ISOs
Wow, your build looks amazing. Makes me even more excited to get my stuff  ;D
Did your PCB happen to come with resistors for the in switch LEDs?
All the PCBs have resistors for switch leds.
Ok, good to hear! Thanks.
Also, should switches be soldered in before the switch LEDs or other way around?
I always do the switches first.
Ah ok. Thank you I will probably do it this way then  :)
Custom 60%: Cherry MX blues with 62g gold springs and PBT Black on Black dyesub keycaps.
Other Keyboards: Deck Hassium Pro (MX Browns), the underated Leopold FC660M (MX Browns)
Offline faxe
« Reply #701 on: Sun, 24 January 2016, 08:50:55 »
Hardware and basic keysetuo down, now time to tinker with the blinkenlights!
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline beltet
« Reply #702 on: Sun, 24 January 2016, 10:43:05 »
Forgot to tell everyone that I got my order lika a week ago. All looks good. The stainless plate look a bit "dirty" but as I have understood that's normal.
Thanks for a quality service!
Offline faxe
« Reply #703 on: Sun, 24 January 2016, 11:38:40 »
Pic or it didn't happen: http://imgur.com/qgajH9s
Round 4 Round 3 Style Dolch, Cherry Clear switches, Green Plate, Tier 3 PCB, split right shift, cheapo transparent plastic case.
Thanks Leandren for organising this group buy. I hereby declare that my 60% buying is finished. Next project will be something  completely different :)
P.S. How do I change RGB mode via keyboard? I can't get it to work...
« Last Edit: Sun, 24 January 2016, 11:48:22 by faxe »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #704 on: Sun, 24 January 2016, 11:45:18 »
Pics or it didn't happen:
:D Fantastic. Where is that keyset from?
This means i need to do a GB for other layouts...
I think you only can change the RGB LEDs from the software, or add it as hotkeys, not entirely sure.
Offline faxe
« Reply #705 on: Sun, 24 January 2016, 11:52:58 »
Keyset is https://deskthority.net/wiki/Round4_Round3 from deskthority user 7bit. DCS profile dolch. Was very lucky to find it used from a guy in finland who had a german layout :)
Hotkeys let me turn them on and off, nothing else sadly.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #706 on: Sun, 24 January 2016, 12:00:00 »
Ahh! he did DCS before SA. I understand.
Offline wodan
« Reply #707 on: Mon, 25 January 2016, 03:12:33 »
Got my order/s :)
Thanks LeandreN
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #708 on: Mon, 25 January 2016, 05:40:35 »
Got my order/s :)
Thanks LeandreN
Fantastic, looking forward to some pictures.
Offline wodan
« Reply #709 on: Mon, 25 January 2016, 06:08:18 »
Here's a pic, the key caps could use a good scrubbing but I was so excited to put them on I skipped that ...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #710 on: Mon, 25 January 2016, 06:13:17 »
Dude! You have OG skidata! That's awesome. I also have that one. Gonna be using it with a true Winkeyless plate ;)
Offline wodan
« Reply #711 on: Mon, 25 January 2016, 06:27:32 »
Ha glad you like it. The OG Skidata set is just perfect for this layout with the short right shift and right profile cursor keys to fill in the gaps ... so happy with the result :)
Skidata keyboards were available on ebay here in large amounts for 90€. That's already a steal for the incredible amount of MX Clear switches you can harvest from those things ...
Offline Crossfire
« Reply #712 on: Mon, 25 January 2016, 10:40:29 »
My highly anticipated package finally arrived!
Thanks to my man LeandreN for making it happen, great service, communication and friendliness!
10/10
A quick preview....
Delicious!
Offline TalkingTree
    • My projects
« Reply #713 on: Mon, 25 January 2016, 14:03:38 »
A quick preview....
No stabilizers?
Offline Crossfire
« Reply #714 on: Mon, 25 January 2016, 14:11:27 »
It was mainly a fast color check ....still undecided on the layout though...completely.
Was dead sure to use korean style 7u spacebar with 1.5u bottom row but now I'm playing around with different possibilities...which is nice too  :))
Offline f1xedgear
« Reply #715 on: Mon, 25 January 2016, 14:11:40 »
A quick preview....
Your right shift key switch is in the spot for a 2.75u key, but you have also have a switch in the spot for the split shift option.
Offline TalkingTree
    • My projects
« Reply #716 on: Mon, 25 January 2016, 14:13:28 »
This.
Offline Crossfire
« Reply #717 on: Mon, 25 January 2016, 14:23:03 »
A quick preview....
No worries, was only making sure I have enough ergo clears lubed and sip'ed for the worst case layout scenario :)
Offline ekx
« Reply #718 on: Mon, 25 January 2016, 15:40:13 »
Mine arrived last week. Had to wait for the acrylic case from massdrop which arrived yesterday. Dermeling the case wasn't as hard as I thought. Had a small issue with the spacebar stabilizer wire not fitting between the pcb and the plate though, but nothing a little bending couldn't fix. I'm really happy with how it turned out. The frosted acrylic case from massdrop looks great with the RGB leds.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #719 on: Mon, 25 January 2016, 16:11:51 »
This build is damn gorgeous. It's such a shame oversold the blue plates, so i have none for myself.
I love it!
Offline chancellorr
« Reply #720 on: Mon, 25 January 2016, 19:38:47 »
My stuff arrived today but unfortunately my plate was damaged in shipping as you can see below. Luckily I didn't need it for this build, still a bummer though.
http://imgur.com/AzntPLD
The build
http://imgur.com/YPxnn3u
Offline f1xedgear
« Reply #721 on: Mon, 25 January 2016, 19:41:09 »
The build
I hope this means I get mine tomorrow! (I live on the west side of Michigan)
« Last Edit: Mon, 25 January 2016, 19:53:07 by f1xedgear »
Offline chancellorr
« Reply #722 on: Mon, 25 January 2016, 21:23:43 »
The build
I hope so too!
Offline Steezus
  • Keeper of Facts
« Reply #723 on: Mon, 25 January 2016, 22:35:43 »
The build
The plate should still be fixable, aluminum is very malleable.
Offline Vimto
« Reply #724 on: Tue, 26 January 2016, 04:29:08 »
My stuff arrived in Hong Kong today, unfortunately the box was damaged.
I can't remember what I ordered, is there anywhere I can check? Just to make sure everything arrived OK.
For the PCB do we have to remove the edges of the PCB which look kind of perforated, and whats the best way to remove them?
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #725 on: Tue, 26 January 2016, 04:31:00 »
Just PM me.
Hopefully everything was alright. You need to break of the PCB parts on the sides.
Offline Vimto
« Reply #726 on: Tue, 26 January 2016, 06:46:12 »
Another dumb question.
What kind of stabilizer is this? Cherry or Costar?
Offline TalkingTree
    • My projects
« Reply #727 on: Tue, 26 January 2016, 06:57:50 »
Cherry, either PCB or plate mounted.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #728 on: Tue, 26 January 2016, 06:59:36 »
Cherry, PCB mounted.
Offline TalkingTree
    • My projects
« Reply #729 on: Tue, 26 January 2016, 07:17:05 »
Confirmed? If not I'll try the one plate mounted stab I got.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #730 on: Tue, 26 January 2016, 07:20:03 »
Yes, confirmed.
PM me about the Gaterons tonight.
Offline TalkingTree
    • My projects
« Reply #731 on: Tue, 26 January 2016, 07:22:51 »
Yes, confirmed.
Alright then.
Sure will.
Offline bloodl1n3
« Reply #732 on: Tue, 26 January 2016, 09:51:00 »
All the completed builds look great!
Unfortunately I broke one of the stems(?) on a stabilizer when trying to snap it into the PCB. Does anyone know where I can buy another stabilizer set? Or is it possible that it'd be ok with just 3/4 of the corners in place?
I saw ortholinear kb sells them, but when I try to checkout it says there are no shipping methods for my address. ZealPC also sells sets, but I'm trying to avoid the $15 shipping for a $1 part :P
Offline chancellorr
« Reply #733 on: Tue, 26 January 2016, 10:03:05 »
I have some extras. Pm me your address and I can ship them sometime this week. If you are in the US that is.
Offline bloodl1n3
« Reply #734 on: Tue, 26 January 2016, 11:18:30 »
PMed. Thanks!
Offline ClosingCircuits
« Reply #735 on: Tue, 26 January 2016, 14:41:40 »
Not sure if this is the place to ask or if I should be PMing, but are there any unpaid for PCBs available still? I see a few unpaid for orders in the Google doc in the OP.
If not, is there any idea when another GB like this is going to occur? I'm dying to break in my new soldering iron on something more exciting than the Falcon-8.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #736 on: Tue, 26 January 2016, 14:45:02 »
All of the orders are long gone. Sorry mate.
Offline eksuen
  • Ambassador of explosions.
« Reply #737 on: Tue, 26 January 2016, 20:36:51 »
My order arrived in California today. The package was pretty banged up, but thankfully, nothing was missing or damaged.
Offline f1xedgear
« Reply #738 on: Tue, 26 January 2016, 21:41:18 »
Still no package for me yet :(
I did however get my new Nexus 6P today which will be used for taking some nice photos once my build is completed :D
Offline chancellorr
« Reply #739 on: Tue, 26 January 2016, 22:45:47 »
Mmmmmmmmmmmm. Jealous.
Offline rabs
« Reply #740 on: Wed, 27 January 2016, 04:52:41 »
Got my order! Thanks LeandreN for making such a great group buy :)
I don't have full build pics yet, but here are a few:
« Last Edit: Sat, 30 January 2016, 03:51:04 by rabs »
Offline rotciveel
  • Fugu Curator Extraordinaire
« Reply #741 on: Wed, 27 January 2016, 21:23:40 »
Got my stuff today!
Quick question: Does anyone else have trouble fitting Zealios flush with the PCB without cutting the PCB pins on the switch? Or is cutting those pins something you have to do with Zealios on this board?
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #742 on: Wed, 27 January 2016, 22:25:33 »
I got plate today. Packing is very professional. This is first time I touch carbon filber. It's really very light. Awesome. I like this.
But plate is still have some swarf. Hope you 'll clean it in future GB. Anyway, thanks for your effect, LeandreN :thumb:
Some pics:
Full album here: http://imgur.com/a/JjCQi
« Last Edit: Thu, 28 January 2016, 06:59:59 by quochung1989 »
Offline eksuen
« Reply #743 on: Wed, 27 January 2016, 23:46:09 »
Got my stuff today!
Yeah, my Zealios aren't quite flush either, but they seem to be in as far as I can get them. At this point it's too much of a hassle to take all the switches out to clip the legs. I don't think there will be any issues, but we'll see.
Offline Jumie
« Reply #744 on: Thu, 28 January 2016, 06:31:28 »
hmmm it has reached Vietnam.. Mine should be received anytime soon in Jakarta.. really can't wait for it
Offline nmur
  • ಠ_ಠ
« Reply #745 on: Thu, 28 January 2016, 06:56:22 »
Got my stuff today!
hey guys I made a tutorial for just this problem
better than clipping the nubs because you retain the stability, and quicker than filing them down too.
Offline chancellorr
« Reply #746 on: Thu, 28 January 2016, 07:03:14 »
Got my stuff today!
Nice! I wish I had thought of this before. I just pushed hard. Lol.
Offline f1xedgear
« Reply #747 on: Thu, 28 January 2016, 08:24:09 »
I got my stuff today! Well, actually yesterday, but I was working from home and didn't feel like driving an hour in the snow to pick it up.
There was basically zero shipping damage to my order. The box looked completely intact:
Everything unpacked:
It turned out that the plate was bowed downwards slightly (I didn't notice until I set it on a flat surface), but I fixed that with some very gentle bending. Other than that, everything was perfect. 10/10 would buy again.
Thanks, LeandreN!
  • Frenzy Classic.
« Reply #748 on: Thu, 28 January 2016, 08:27:11 »
Thanks, LeandreN!
Sound good when it's fixed. I had same trouble in first round.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #749 on: Thu, 28 January 2016, 08:32:11 »
Thanks for the updates people.
Do any of you guys now if i am allowed to use my Heatware to get feedback from this GB?
