Author Topic: [GB][FINISHED] Plates, PCBs and stabilisers - LeandreN Round 3  (Read 268631 times)
Offline reddragon394
Re: [GB][SHIPPING] Plates, PCBs and stabilisers - LeandreN Round 3
« Reply #650 on: Tue, 19 January 2016, 14:08:27 »
A scale with a piece function, nice :D
Offline xondat
  • i'm not a star
« Reply #651 on: Tue, 19 January 2016, 14:10:37 »
That looks so much easier.
Offline TalkingTree
    • My projects
« Reply #652 on: Tue, 19 January 2016, 15:46:44 »
Another potato picture of mine.
I completed (one of) my board(s).
I decided to go for a 2.25u right shift to match the set.
Happy building everyone, enjoy the amazing GB.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #653 on: Tue, 19 January 2016, 15:56:36 »
That set looks great! Where is it from?
Offline TalkingTree
    • My projects
« Reply #654 on: Tue, 19 January 2016, 15:59:16 »
Original Cherry G81-3000/SAI (PBT dyesub) except Enter and pipe/backslash that are ABS doubleshot from an original US set.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #655 on: Tue, 19 January 2016, 16:00:35 »
Wow. Thats a good score.
Offline TalkingTree
    • My projects
« Reply #656 on: Tue, 19 January 2016, 16:03:16 »
Very good score considering that I bought each second hand keyboard for € 35, shipped.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #657 on: Tue, 19 January 2016, 16:17:47 »
That's a steal!
Offline TalkingTree
    • My projects
« Reply #658 on: Tue, 19 January 2016, 16:22:50 »
That's a steal!
Offline Atredl
« Reply #659 on: Tue, 19 January 2016, 20:39:58 »
Sent you a PM LeandreN
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #660 on: Tue, 19 January 2016, 22:09:41 »
My plate and stabs came in today. Big thanks LeandreN  :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #661 on: Wed, 20 January 2016, 02:16:54 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #662 on: Wed, 20 January 2016, 06:56:48 »
Offline tofgerl
« Reply #663 on: Wed, 20 January 2016, 07:21:11 »
"Add 500.000 flours, and stir. Next, take a pinch - say 40.000 sugars and add while stirring."
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #664 on: Wed, 20 January 2016, 08:17:50 »
I have started measuring baking ingredients in the unit "Gaterons" now.
Offline Tachi
« Reply #665 on: Wed, 20 January 2016, 12:58:30 »
Damn these Gateron blues are nice! Now I wish I'd had the money to get the pcb too!
 Shall have to look for a board to build.
Offline TalkingTree
    • My projects
« Reply #666 on: Wed, 20 January 2016, 13:40:32 »
@LeandreN: Got 50 more Gateron blues by any chance?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #667 on: Wed, 20 January 2016, 14:48:31 »
Yes i do have that, however i have very little time to ship it :/
Offline TalkingTree
    • My projects
« Reply #668 on: Wed, 20 January 2016, 14:54:40 »
PMed.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #669 on: Wed, 20 January 2016, 14:55:10 »
PMed.
No you didn't :P
Offline TalkingTree
    • My projects
« Reply #670 on: Wed, 20 January 2016, 14:56:35 »
PMed.
No you didn't :P
I posted here before actually PMing you. You're too quick.
Offline Sisric
« Reply #671 on: Thu, 21 January 2016, 13:40:23 »
I've built it! However I have no idea how to work the firmware and now half my board isn't working... Anyone have an easy tutorial and know how to reset it to default? Also some of my LED's aren't working, don't know if it's just another firmware issue or if it is a problem with the keyboard :(
Offline dae1
« Reply #672 on: Thu, 21 January 2016, 13:45:02 »
This was a learning experience.  I found a few Zealio purples that were bad meaning a slight touch activates the key press and would see double characters before I hit bottom.  Accidentally putting the switches in the W/L holes, oops.  The clear acrylic case frop Ziptyze was causing the pcb stabilizer for the space bar to dislodge and causing a 'sticky' effect on the space bar.  I thought I put the stabilizer wrong, but noticed that it was hitting some sort of lip inside of the case.  I used a dremel to clear space.  Works great now.  The RGB leds looks beautiful with it.
I do have a question.  With the tier 3 pcb with the RGB leds, would it be ok to add LEDs to keyswitches?  I haven't seen anyone with both yet.  Also, I guess you can't map mouse controls with the bootmapper editor right?
Offline chancellorr
« Reply #673 on: Thu, 21 January 2016, 13:47:03 »
I've seen a few online with both the RGB led and in key leds. You should be good! This is what I'm planning on doing.
Offline dae1
« Reply #674 on: Thu, 21 January 2016, 13:48:44 »
I followed the instructions here if you haven't already done so:
http://blog.winkeyless.kr/183
I had the same issue with the LEDs like you did, too.  But if you use the BootMapperClient, you can go to Options->Num of RGB Leds and set that to 16.
I actually mapped the ROW-COLUMN.  Follow this: http://www.keyboard-layout-editor.com/#/gists/5f7fa6abb1a691714953
It's very small but you can see the row-column values that map to that key.
Offline dae1
« Reply #675 on: Thu, 21 January 2016, 13:55:00 »
Awesome!  Thanks!  This is how it looks like right now:
http://imgur.com/p9gFEew
Offline chancellorr
« Reply #676 on: Thu, 21 January 2016, 14:25:43 »
Mmmmmmm. Love Deep Space. I plan on building a Deep Space Planck one of these days.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #677 on: Thu, 21 January 2016, 14:37:50 »
Follow this guide: http://blog.winkeyless.kr/183
And flash the default file.
Offline xondat
  • i'm not a star
« Reply #678 on: Thu, 21 January 2016, 14:38:25 »
Still looking for Zealio :( Want them sooner than the GB.
Offline Relaxbro
« Reply #679 on: Thu, 21 January 2016, 15:14:46 »
Got the package today! Thanks LeandreN
Offline Sisric
« Reply #680 on: Thu, 21 January 2016, 17:15:56 »
Thank you for your help, but really I am just an idiot :p I sorted it now and this thing is beautiful! No key caps on it yet but I brought it to work to sort it out. Thank you again for the group buy, this has been awesome and I've already ordered by Zealios keys for my next keyboard ;) Hope to see another group buy from yourself soon! I'll post a picture tomorrow :)
« Reply #681 on: Thu, 21 January 2016, 22:50:34 »
Woooo, where do you live? Yours probably was sent with my lot together, but I'm still desperately waiting for it :D
Offline Butter
« Reply #682 on: Thu, 21 January 2016, 23:00:00 »
I hope the PCB get here tomorrow before the storm hit.
Offline faxe
« Reply #683 on: Fri, 22 January 2016, 05:45:05 »
I have a package waiting, don't know what it is, but I am not expecting anything besides this pcb/plate :) I think i will be tinkering tonite. Can't wait.
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline itzmeluigi
  • ПБТ
« Reply #684 on: Fri, 22 January 2016, 17:31:13 »
The grey plate arrived today, extremely fast shipping  :D This is certainly the nicest plate ive used.
Incoming PM.
« Last Edit: Fri, 22 January 2016, 17:40:01 by itzmeluigi »
Offline Numpy
  • The feels man
« Reply #685 on: Fri, 22 January 2016, 21:32:08 »
Does the Tier 2 PCB come with pre-soldered resistors for in switch LEDs or will I need to get some myself?
Custom 60%: Cherry MX blues with 62g gold springs and PBT Black on Black dyesub keycaps.
Other Keyboards: Deck Hassium Pro (MX Browns), the underated Leopold FC660M (MX Browns)
« Reply #686 on: Fri, 22 January 2016, 23:20:40 »
Woooo it all came! Thanks LeandreN for this great GB! :D ... Though you forgot to change my shipping address that i emailed you about :P Thats ok though, i was lucky someone was here to take the package :D
have some pics:
125467-0125469-1125471-2125474-3125476-4125480-5
And yes, the ugly USB cable will be replaced :D
ISO GER, white in-switch LEDs, PBT Vortex set for now ... really waiting for their doubleshot PBT backlit ISOs
« Last Edit: Fri, 22 January 2016, 23:58:11 by reddragon394 »
Offline Numpy
  • The feels man
« Reply #687 on: Sat, 23 January 2016, 02:41:30 »
have some pics:
(Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link)
Wow, your build looks amazing. Makes me even more excited to get my stuff  ;D
Did your PCB happen to come with resistors for the in switch LEDs?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #688 on: Sat, 23 January 2016, 02:55:28 »
Woooo it all came! Thanks LeandreN for this great GB! :D ... Though you forgot to change my shipping address that i emailed you about Thats ok though, i was lucky someone was here to take the package :D
have some pics:
All the PCBs have resistors for switch leds.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #689 on: Sat, 23 January 2016, 06:03:17 »
have some pics:
That was probably why it took a while, it really shouldnt have taken more than a day. Sorry about that. Your build looks great. Hopefully you like it!
Offline faxe
« Reply #690 on: Sat, 23 January 2016, 08:50:16 »
PCB and plate arrived, my cheap transparent aliexpress case needs some dremeling though, so no complete build this weekend :)
And plans changed back to green plate and dolch because I found the 1.75 right shift I thought I didn't have for the split right shift.
« Last Edit: Sat, 23 January 2016, 08:53:23 by faxe »
« Reply #692 on: Sat, 23 January 2016, 11:44:54 »
i dont think it would have been any faster with the other address, but no worries, its all good now! :D And yes, i like the build! :D
Edit: I seem to just have 6KRO, wasnt the driver claiming to be NKRO? Anyone knowing if there is a setting for it?
« Last Edit: Sat, 23 January 2016, 11:52:46 by reddragon394 »
Offline faxe
« Reply #693 on: Sat, 23 January 2016, 12:00:55 »
Will this case also need some dremeling?
http://www.aliexpress.com/store/product/Mini-Keyboard-GH60-plastic-Case-for-60-Mechanical-Keyboard-Compatoble-PBT-Keycaps-Poker2-Pok3r-Faceu-60/1555390_32311183273.html
This is exactly my case (the non mentioned but available transparent version). Further investigation reveals no dremeling neccessary!
Offline FoC_Tow
  • Brokehlicious
« Reply #694 on: Sat, 23 January 2016, 12:09:13 »
Received my two Pcbs and stabilizers sets yesterday!
Thx a lot LeandreN!  :thumb:
From the looks everything looks pretty much perfect to me!
One little thing tho:
A stabilizer bars escaped the small plastic bag and almost made it out of the box,
but its all good and Im super happy to have some smexy pcbs for upcoming builds!
No issue, just figured Id mention it! =)
Offline TalkingTree
    • My projects
« Reply #695 on: Sat, 23 January 2016, 12:58:13 »
I owned this case before giving a board to a friend. It's a bit taller than the others and there's more room on the bottom. I guess you don't need any cutting.
Offline TalkingTree
    • My projects
« Reply #696 on: Sat, 23 January 2016, 12:59:25 »
It's 6KRO under USB and NKRO on PS2. I guess you can try with an adapter.
Offline Numpy
  • The feels man
« Reply #697 on: Sat, 23 January 2016, 18:04:54 »
have some pics:
Ok, good to hear! Thanks.
Also, should switches be soldered in before the switch LEDs or other way around?
Offline chancellorr
« Reply #698 on: Sat, 23 January 2016, 18:13:29 »
have some pics:
I always do the switches first.
Offline Jumie
« Reply #699 on: Sat, 23 January 2016, 19:45:20 »
Ahh so glad to hear no dremeeling necessary. I don't own one..
