Author Topic: How to put a Cherry G80-3000 apart?  (Read 4226 times)
Offline simon1234
« on: Mon, 16 November 2009, 11:04:01 »
Hi everybody, new here!
Anyway i recentley got a hold of a G80-3000. It awsome, but it's a bit dirty. So i whanted to take it apart to clean it with water. But i dunno how to. There are, "clip on" things on the front that i "uncliped" but it's still holding together in the front. Can anyone tell me what i should do?
Thanks and forgive my bad english. :roll:
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Mon, 16 November 2009, 11:49:46 »
Old-style or new-style case?
For the new-style case, there are clips all around.
The old-style case should come open quite easily now. You just need to push the circuit board to the front, then it will separate from the top case which can subsequently be taken off. Dead easy once you get the hang of it. When you take out the PCB, be sure to remember how the cable went into the strain relief.
The case parts can be cleaned easily with water and a bit of dish cleaning liquid, same goes for the cable. For the keycaps I would recommend sixty's method, i.e. use denture cleaning tabs in a bowl of water. Do not attack the circuit board with water, just dust it off with some big brush.
Offline lowpoly
« Reply #2 on: Mon, 16 November 2009, 12:23:53 »
Quote from: simon1234;132864
Some 3000s have screws, some not. It's either that or some clip is still clinging.
Offline simon1234
« Reply #3 on: Mon, 16 November 2009, 12:27:09 »
Quote from: keyb_gr;132894
OK i got the cuircuit board to seperate but the top case won't move and i'm not shure in which way to push it cuz i'm afraid that i might brake it.
Offline simon1234
« Reply #4 on: Mon, 16 November 2009, 12:33:43 »
Quote from: lowpoly;132906
Mine doesn't. And there is no clips at the front. Would pictures help?
Offline keyb_gr
  • Cherrified user
« Reply #5 on: Mon, 16 November 2009, 13:48:06 »
Just wiggle the top case up and down. At some point it should come loose at the lower end. Things can be a little sticky if the board has never been opened before.
Well, you don't need to feel too bad, when I tried for the very first time I also gave up...
