Author Topic: Unicomp Keyboard.  (Read 20502 times)
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Unicomp Keyboard.
« Reply #50 on: Fri, 11 December 2015, 12:03:21 »
If you really want to see some of the things involved with Model M restoration, feel free to look at my gallery as well.
http://snowdog993.imgur.com/
There are some models that I couldn't restore, and I had to send those particular keyboards to Phosphorglow.  Well worth it to ME, but not everybody.
Offline 1391406
« Reply #51 on: Fri, 11 December 2015, 18:48:41 »
Are you referring to restoring models that weren't working properly or for some other reason?
Offline Snowdog993
« Reply #52 on: Fri, 11 December 2015, 21:30:53 »
Simple enough.  I failed doing a bolt-mod, and got a referral to Maxx from Phosphorglow from Brandon at ClickyKeyboards.com.  All the bolt-modded keyboards I have are done by Phosphorglow.  The Lexmark SSK has the LED mod done by Phosphorglow as well.  My other keyboards I have done on my own.  I gave credit to every keyboard Phosphorglow has done for me.  I highly recommend him.
Edit: I know my own limitations.
« Last Edit: Fri, 11 December 2015, 21:52:05 by Snowdog993 »
« Reply #53 on: Fri, 11 December 2015, 21:58:35 »
I don't know what he charges, but it is a fussy, tedious job.
It is no harder, probably easier than doing a Model F, but not nearly so satisfying.
- D Trump 2026-10-24
Offline E TwentyNine
    • Some of My Keyboards
« Reply #54 on: Sat, 12 December 2015, 08:31:55 »
No way.  An F is simple.  M is a much bigger pain in the ass.
« Reply #55 on: Sat, 12 December 2015, 08:34:34 »
That micro M pic always makes me happy
« Reply #56 on: Sat, 12 December 2015, 09:24:46 »
When I do an F, I always "go all the way" and clean every single part, strip and paint the plate, paint the bottom pan, cut new foam, floss mod, etc.
All that adds up to a lot more hours, and usually several days if you are waiting for paint to cure 24 hours between coats.
Not to mention fitting and wiring in a Teensy, if that is part of the program. With an M you are mostly just taking it all apart and putting it all back together.
« Reply #57 on: Sat, 12 December 2015, 11:20:38 »
Not if you're doing a bolt mod.
It may be more time consuming to fully refurb an F, but there's no step involved comparable to bolt modding of an M.
Offline 1391406
« Reply #58 on: Sat, 12 December 2015, 14:36:55 »
If I recall, you stated in a previous thread that you no longer recommend bolt modding a 122-key Model F, though I forget the reason why.
« Reply #59 on: Sat, 12 December 2015, 22:52:36 »
Out of frustration on my first F-122, and since I had done enough M bolt-mods that they were no longer intimidating, I drilled about 8-10 holes around in places where they seemed appropriate and then cut off the tabs, since they were giving me the trouble. I used 4-40x1/2" machine screws and nuts with washers, and the results were pleasing.
Afterwards, on the 2nd try, I got my holes off a bit and they did not work properly, so I deprecated the procedure and recommend leaving the tabs in place to ensure accurate alignment of all the plates. With low-end equipment, a hole drilled in metal plate and off by 1/4 of a diameter is almost impossible to rectify.
I do, however, always add 2-3 bolts along the center of curvature of any Model F that I refurbish and I believe that it does a lot for stability, and is particularly helpful if you have replaced the foam with something firmer. I don't know whether the plates get "un-sprung" when you take them apart, but pulling them snug in the center seems to make everything much better. A couple of times, there were several keys that did not work at all until I cranked them down tight.
« Reply #60 on: Sat, 12 December 2015, 22:54:25 »
With an M you are mostly just taking it all apart and putting it all back together and adding bolts.
Offline Snowdog993
« Reply #61 on: Sat, 12 December 2015, 23:23:57 »
I am gonna let you guys talk about it like it's a walk in the park.  There's quite a bit involved with doing a bolt mod for a Model M.  I'd rather have Maxx do it for a fair, reasonable price.
Enjoy the movie!
« Reply #62 on: Sun, 13 December 2015, 09:42:40 »
If anyone got that impression from my comments, then they clearly took them the wrong way. Bolt-modding an M is a tedious, fussy job that is always frustrating.
After doing it a few times, however, it is no longer intimidating, but still just as tedious.
Offline SamirD
« Reply #63 on: Mon, 14 December 2015, 00:45:25 »
Great info on the bolt-mods.  Thank you both!
