Author Topic: The long journey of the WhiteFox  (Read 362390 times)
Offline ideus
  • Björkö.
Re: The long journey of the WhiteFox
« Reply #300 on: Mon, 14 December 2015, 09:26:15 »
With the group buy being extended to 2000 units (two deployments),  what is the likelihood of the second date having the special edition inclusion at this point?
Will this still be saved for a potential groupbuy in the future rather than this one?
What is a special edition?
Offline Vittra
  • Airflow Optimizer
« Reply #301 on: Mon, 14 December 2015, 09:28:29 »
See below:
okay so posting this again :)
(special edition, not sure it will be made, but the case will be gold anodized)
worry not, if the first group buy is successful we will have a second batch for sure (goooold!)
Filco MJ Linear R LE TKL
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #302 on: Mon, 14 December 2015, 09:33:33 »
if we sell all 2000 units we will probably run another batch later next year.
Offline NorrisB
« Reply #303 on: Mon, 14 December 2015, 10:30:37 »
Just a quick heads-up if you get the barebone kit without keycaps, Signature Plastics is selling the Midnight Set ( http://pimpmykeyboard.com/dcs-midnight-keycap-set-50-off/ ) with a 50% discount! Just remember to grab the additional modifiers to cover the whitefox!
(for those who don't know the Midnight set is also designed by me)
Could you explain that status on the purple kealios, I read somewhere you had more?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #304 on: Mon, 14 December 2015, 10:47:16 »
have to wait the west coast to wake up
« Reply #305 on: Mon, 14 December 2015, 10:52:42 »
Ugh. I keep forgetting they're in the west coast. Here I am, working almost two hours in the regular business day, and they're not even open yet!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #306 on: Mon, 14 December 2015, 11:02:41 »
I wish Earth were flat.
PS: actually it is flat for a muon...
Offline piemancoder
« Reply #307 on: Mon, 14 December 2015, 16:36:03 »
Sorry for the noob question, but is it $50 with or without the sale?
Yoda grammar best has
Offline ideus
  • Björkö.
« Reply #308 on: Mon, 14 December 2015, 16:39:53 »
A fox?
Offline f1xedgear
« Reply #309 on: Mon, 14 December 2015, 16:42:05 »
A fox?
That's a Smart68 (note the FN button below the spacebar on the front)
« Last Edit: Mon, 14 December 2015, 17:07:14 by f1xedgear »
« Reply #310 on: Mon, 14 December 2015, 16:42:56 »
A fox?
Foxy, but not the TrueFox.
Offline f1xedgear
« Reply #311 on: Mon, 14 December 2015, 17:39:10 »
$50 is the on sale price.
It is $20 for the base set and $30 for modifiers kit ($50 total to cover a tenkeyless board). Whitefox uses non-standard modifier key sizes though, so as Matt3o said, you also need the additional mods kit ($25). The keyset would cost you $75 total.
Offline piemancoder
« Reply #312 on: Mon, 14 December 2015, 18:10:32 »
Thank you! Still a bit expensive with everything though. But I guess it's probably worth it.
Offline FLFisherman
  • I'd rather be fishing.
« Reply #313 on: Mon, 14 December 2015, 18:35:39 »
You could also try the Classifieds and see if anyone is willing to part with one for less. You never know.  ;D
Offline NorrisB
« Reply #314 on: Mon, 14 December 2015, 22:16:11 »
If you buy the barebones there is no difference between the layouts am I right?
Offline ideus
  • Björkö.
« Reply #315 on: Mon, 14 December 2015, 22:18:36 »
You should get the plate you need, the plates make the difference between alternative layouts, unless you use PCB mounted switches.
Offline f1xedgear
« Reply #316 on: Mon, 14 December 2015, 22:27:06 »
It wouldn't look very good without a plate though... Lots of open space
Offline ideus
  • Björkö.
« Reply #317 on: Mon, 14 December 2015, 22:38:37 »
I know, just pointing that it is the only way you have not need to care about layouts and their appropriated plates.
Offline Hellmark
« Reply #318 on: Mon, 14 December 2015, 23:21:22 »
Question for you. Is there anyway to get one after the mass drop ends in 13 days, other than buying used? Recently laid off, so no spare funds, but I've been wanting a fox now for ages.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #319 on: Mon, 14 December 2015, 23:54:31 »
Just to be clear, the whitefox doesn't work without a plate. You could use just the PCB but you have to build your case then.
only in the classified I guess
Offline ideus
  • Björkö.
« Reply #320 on: Tue, 15 December 2015, 07:37:45 »
Good point, there is no way to affix the PCB inside the case because it does not have standoffs to bolt it on. Thank you for the clarification.
Offline swimmingbird
  • keyset hoarder
« Reply #321 on: Tue, 15 December 2015, 07:44:34 »
Would be awesome if a limited edition version of the board could come with the logo engraved in the back
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #322 on: Tue, 15 December 2015, 07:46:46 »
are you in the first batch?
Offline SwissFTW
« Reply #323 on: Tue, 15 December 2015, 08:52:59 »
I'm waiting for some more PCBs to make a full tutorial (and add LEDs)
AWESOME!
   WhiteFox  | HHKB Pro 2 | KBT Pure MX Browns | CM Storm MX Browns | Ducky YOTD MX Browns | Ducky Shine II MX Browns
    TrueFox
Offline pandaaqq
« Reply #324 on: Tue, 15 December 2015, 09:09:39 »
I'm in the first batch and that would be awesome!
Also Matt3o, do you have any plans on releasing some key sets for other layouts (ISO)? (i love your midnight set, for example).
« Last Edit: Tue, 15 December 2015, 09:17:41 by pandaaqq »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #325 on: Tue, 15 December 2015, 09:18:41 »
FIrst batch is actually a "limited edition".
Offline E3E
« Reply #326 on: Tue, 15 December 2015, 09:25:03 »
Despite not being in the buy, this sounds super awesome! I wonder what you have planned. :D
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #327 on: Tue, 15 December 2015, 09:28:52 »
we'll probably run more granite next year
Offline SwissFTW
« Reply #328 on: Tue, 15 December 2015, 09:30:33 »
First batch being the first 500 or the first 1000?
    TrueFox
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #329 on: Tue, 15 December 2015, 09:37:51 »
first batch has always been 1000. 500 is an urban legend.
Offline SwissFTW
« Reply #330 on: Tue, 15 December 2015, 09:42:09 »
haha - fair enough. well I made it into the first batch then - and now i'm even more excited! Didn't think that would be possible. ALL HAIL WHITEFOX!
    TrueFox
Offline Jedi
« Reply #331 on: Tue, 15 December 2015, 10:21:47 »
Probably?  Is it because SP is backlogged (urban legend lol) or something else?  We need an IC started soon here on this one so this stays on point with Whitefox though I can't help but wonder what your thoughts are.
Offline f1xedgear
« Reply #332 on: Tue, 15 December 2015, 10:27:02 »
There was some discussion about Granite round 4 on Reddit a few months back. Target date was January 2016 and I haven't read anything different since then.
Offline Dernubenfrieken
« Reply #333 on: Tue, 15 December 2015, 10:42:02 »
The "backlog" is for SA, so granite would be uneffected
Offline Steezus
  • Keeper of Facts
« Reply #334 on: Tue, 15 December 2015, 11:41:31 »
Yeah I believe it has more to do with the fact that granite has been ran numerous times already. It's nice to run the set multiple times so everybody can get a chance to grab a set but at the same time it's nice to have new sets coming in.
Offline iss
« Reply #335 on: Tue, 15 December 2015, 11:43:15 »
What's the secondary IC? Do you use it for LED control?
« Reply #336 on: Tue, 15 December 2015, 15:10:18 »
Well I finally ordered.  :D
Re: Batches
I ordered after the first 1,000 units sold, but when I was selecting all my options they let me pick the "batch" that my board would ship with.  Why would they do that?  What's the reasoning?  :confused:  Wouldn't you just ship them as they come in?  Why would anyone choose to have theirs shipped at a later date??
« Reply #337 on: Tue, 15 December 2015, 15:11:59 »
Re: Batches
If you were able to select it then someone in the first batch must've canceled. They opened a second batch because the first 1000 sold out, but people in that set may be canceling. I re-ordered this morning and scored a kit in the first batch.  :thumb:
« Reply #338 on: Tue, 15 December 2015, 15:13:17 »
Re: Batches
Oh, cool.  I must have ordered during the awkward transition from batch 1 to batch 2.  It would be nice if they explained what that meant / why there are 2 batch options.  ;)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #339 on: Tue, 15 December 2015, 16:47:36 »
you can choose to be part of batch two so you are billed a little later I believe. Someone shifted from batch 1 to batch 2 because they didn't have the funds right away but they will later.
Technically monkey around between batches and generally changing your order if you are in batch 1 is bad for MD, but a small % is tolerated.
Offline qwack
« Reply #340 on: Wed, 16 December 2015, 08:38:37 »
Looks like an IS31FL3731. LED driver indeed. The Ergodox from Input Club uses the same. I'd wait for the files to be released to be sure though.
Pure Pro w/MX Red - [review]
Offline NorrisB
« Reply #341 on: Wed, 16 December 2015, 11:01:23 »
Matteo anyway you could get massdrop to offer the cable and leds seperately  I want it added to my barebones
« Last Edit: Wed, 16 December 2015, 11:12:08 by NorrisB »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #342 on: Wed, 16 December 2015, 11:08:54 »
You mean on another drop? I don't think that would be possible at this stage.
Offline f1xedgear
« Reply #343 on: Wed, 16 December 2015, 11:15:42 »
Isn't it trivial to obtain these parts separately already? Tons of electronics parts vendors sell LEDs, and USB cables are also not hard to find.
Offline Hellmark
« Reply #344 on: Wed, 16 December 2015, 11:51:20 »
That blows. Always my luck.
Offline sircheddar
« Reply #345 on: Wed, 16 December 2015, 18:38:20 »
So, if we ordered before 1,000, we get in some sort of special limited edition o: how exciting hype hype!
" I hope that when the world comes to an end, I can breathe a sigh of relief, because there will be so much to look forward to. "
Offline alienman82
« Reply #346 on: Wed, 16 December 2015, 22:00:04 »
removed.
« Last Edit: Thu, 01 March 2018, 16:49:07 by alienman82 »
Offline trizkut
« Reply #347 on: Wed, 16 December 2015, 22:18:31 »
Sorry if asked already, but does this support off center caps lock?
PCB supports it, but the provided plates won't.
Offline alienman82
« Reply #348 on: Wed, 16 December 2015, 22:42:32 »
removed.
« Last Edit: Thu, 01 March 2018, 16:49:03 by alienman82 »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #349 on: Thu, 17 December 2015, 05:14:08 »
A question for Matt3o here;
Have elected to purchase a Complete WhiteFox using all CherryMX Clears but it needs to be assembled.  Hence paid for that 'service' to have it completely finished ready to be connected to a PC.
Would you know who will be responsible for the construction of this keyboard ?
