Author Topic: Difference between Korean spring and Chinese spring  (Read 2061 times)
Offline dungfrs
« on: Sun, 29 November 2015, 06:11:58 »
so i find this site
http://world.taobao.com/item/43471568632.htm?fromSite=main&spm=2013.1.20141001.4.bnr2Zy&scm=1007.10115.11446.100200300000000&pvid=a2bd84c8-c302-4544-8298-61f7bd4a5f9f
im not sure whether it 's the same with Korean stuff or not  :cool: im currently using Korean 62g spring and i find it 's fit for my hands
118573-0  ;D
Offline dungfrs
Re: Difference between Korean spring and Chinese spring
« Reply #1 on: Mon, 30 November 2015, 01:51:38 »
help ;D ;D ;D
Offline Oobly
« Reply #2 on: Mon, 30 November 2015, 08:04:00 »
It's a Chinese site, who knows what standard they've used (and what the tolerances are like). It's most likely that they're to bottom out like the Korean ones, but you never know unless they specify it. Better to get from a more trusted source like Zeal or Sprit.
For instance, the ones that were up on Massdrop recently were in "Cherry" measurements, measured to actuation instead of to bottom out like Korean ones.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline zhihuichan
  • Click,click,click
« Reply #3 on: Mon, 30 November 2015, 08:50:55 »
I have both Korean(SPRIT and KBD mod)and Chinese( By enjoypbt) spring. both 62G. As I can talk, there is no diference.
Offline jamster
« Reply #4 on: Mon, 30 November 2015, 09:17:20 »
Is Sprit still a 'trusted source' here? There seem to be some long multi-year dramas in his buys- have they finally been resolved?
Not trying to stir things up, just wanting the OP to enter any of those buys with his eyes open.
Zeal on the other hand is fantastic, but I last time I checked he wasn't carrying springs apart from those that came with the Zelio switches.
Offline Homenubbie
« Reply #5 on: Mon, 30 November 2015, 11:12:44 »
Stay away from SPRiT if you want it soon.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6 on: Tue, 01 December 2015, 15:37:23 »
Not if you want to get anything anytime soon
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #7 on: Tue, 01 December 2015, 17:14:27 »
Sprit will mail you your order if you are vigilant about it.
I got mine without any drama, but I literally sent emails constantly to confirm stock, before placing my order.
As long as you're within the PayPal chargeback period, you are golden. That said, it isn't fun to do so, but had to be done.
