Author Topic: Realforce screw  (Read 4171 times)
Offline bocahgundul
  • a seal
Realforce screw
« on: Tue, 01 December 2015, 22:56:57 »
Can someone hlp me what to do with broken realforce screw? Like this
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Offline bocahgundul
  • a seal
Offline bocahgundul
  • a seal
Re: Realforce screw
« Reply #3 on: Tue, 01 December 2015, 23:22:26 »
Well i think theres no hope yeah?  :'( :'(
Offline jonathanyu
Re: Realforce screw
« Reply #4 on: Tue, 01 December 2015, 23:50:28 »
try to use a pliers to unscrew it. you need to be very careful to not damage the pcb
Offline ika
Offline bocahgundul
  • a seal
Re: Realforce screw
« Reply #6 on: Wed, 02 December 2015, 00:18:19 »
I think i need to go to proffesional repair to pull the screw
Offline remdell
Re: Realforce screw
« Reply #7 on: Wed, 02 December 2015, 23:16:25 »
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline Homenubbie
Re: Realforce screw
« Reply #8 on: Wed, 02 December 2015, 23:29:35 »
Sears sells a stripped screw puller.
Offline swimmingbird
  • keyset hoarder
Re: Realforce screw
« Reply #9 on: Thu, 03 December 2015, 00:36:52 »
I had a stripped screw inside my macbook pro and I very carefully removed it by drilling it out with a powerdrill
Bit of a last resort but got the job done
Offline bocahgundul
  • a seal
Re: Realforce screw
« Reply #10 on: Thu, 03 December 2015, 01:29:46 »
Pulled it out already thx man
Offline Homenubbie
Re: Realforce screw
« Reply #11 on: Thu, 03 December 2015, 13:57:27 »
Great!  Thanks for the update.
