Author Topic: Ergo clears: How are they?  (Read 4780 times)
Offline macguy80
« on: Sun, 06 December 2015, 23:46:17 »
So, I know that Ergo clears are clear switches using springs of blues, browns, or reds.
But is the tactile bump still as defined as stock clears?
And does anyone prefer panda clears instead of ergos? I assume the black springs are just a little lighter than stock, or...?
Offline Flossed
  • Hai
Re: Ergo clears: How are they?
« Reply #1 on: Mon, 07 December 2015, 00:08:16 »
They still have the nice bump of clears, but are so much easier on the fingers. They're great.  :thumb:
Offline trenzafeeds
  • **** off
« Reply #2 on: Mon, 07 December 2015, 01:09:34 »
I loved ergo clears, but they are a pain in the ass to be honest. I would totally go with zealios if you are interested in that feel. I think they are worth the extra money, very nice switches.
demik will never leave.
Unless he gets banned.
Offline macguy80
« Reply #3 on: Mon, 07 December 2015, 01:58:48 »
I haven't heard of Zealios, but they look interesting. What made the ergo clears a PITA for you?
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #4 on: Mon, 07 December 2015, 02:02:02 »
This is my first time reading about Zealios switches as well. I want just because purple.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline trenzafeeds
  • **** off
« Reply #5 on: Mon, 07 December 2015, 02:02:50 »
The mod just takes a while, and if you don't do it meticulously then you end up with different switches having slightly different feels. I got fairly good at it, but it's amazing to have Zealios that are basically pre-done. If you're not familiar with them, they're very nice quality switches that are basically ergo clears without the lube (so it's still pretty labour intensive if you want the full effect), but the switches are actually so smooth that I've found I prefer them unlubed. You can find them here: http://zealpc.net/collections/switches/products/zealio
They're $1 a piece at the moment, which is very price for switches but zeal frequently has deals that lower the price, and people do groupbuys sometimes that lower it as well.
Offline jonathanyu
« Reply #6 on: Mon, 07 December 2015, 02:17:28 »
ergo clear feels a little bit weird to me. I still prefer stock clear
Offline trenzafeeds
  • **** off
« Reply #7 on: Mon, 07 December 2015, 02:27:56 »
That's funny, stock clears literally feel broken to me. I can't use them without lube.
Offline darkclone24
« Reply #8 on: Mon, 07 December 2015, 02:56:31 »
Haven't used actual ergo clears, but Zealios don't feel as good as stock clears to me - they feel a little mushy. Stock Cherry Clears give you a crisp "pop" as you actuate that I love.
RS84 67g Zealio Purple | Choc Mini MX Black | WASD V2 MX Clear | Golbat 78g Zealio Purple | Duck Octagon V2 MX Clear
Offline trenzafeeds
  • **** off
« Reply #9 on: Mon, 07 December 2015, 02:57:17 »
Which weight of zealios do you have?
Offline ika
« Reply #10 on: Mon, 07 December 2015, 03:12:07 »
Zealios have an issue with the lubing from the factory that results in them being a little mushy to begin with. After about a week or two of use it clears up. Also the polycarbonate clear top changes the feel/sound of bottoming out that some people might not like.
Offline Oobly
« Reply #11 on: Mon, 07 December 2015, 07:21:47 »
ErgoClears are more tactile than stock Clears, and Purple Zealios just a little more tactile then ErgoClears due to the stronger contact leaf "spring" compared to the slider spring.
In order:
65g Zealios > 62g lubed ErgoClears > 62g ErgoClears > Panda Clears (slightly more tactility, but less resistance after actuation compared to stock Clears) > Stock Clears > Browns.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Lepidus
« Reply #12 on: Mon, 07 December 2015, 07:36:34 »
Wont a clear switch with a brown/blues/red spring stick?
Anyway, I agree with Oobly, ergoclears do feel more tactile than regular clears. Usually the stiffer the spring is, the less you can feel the tactile bump.
About zealios, the only thing I did not enjoy was the fact that it wobbles a lot more than cherry ergo-clears. But maybe thats the reason for it being smoother.
« Last Edit: Mon, 07 December 2015, 07:38:44 by Lepidus »
Offline trenzafeeds
  • **** off
« Reply #13 on: Mon, 07 December 2015, 07:37:48 »
About zealios, the only thing I did not enjoy was the fact that it wobles a lot more than cherry ergo-clears. But maybe thats the reason for it being smoother.
Have you seen oobly's mod for this? It's easily fixable with some cheap copper tape.
Offline Lepidus
« Reply #14 on: Mon, 07 December 2015, 07:40:14 »
n-no ;_;
where?
Offline trenzafeeds
  • **** off
« Reply #15 on: Mon, 07 December 2015, 07:42:30 »
n-no ;_;
where?
If you scroll through the Zealio groupbuy thread you should be able to find it. Basically he put a tiny bit of copper tape on either side of each stem, and it seems like it made them a lot sturdier. I'm going to try the mod myself in a couple days hopefully.
Offline ideus
  • Björkö.
« Reply #16 on: Mon, 07 December 2015, 07:48:19 »
n-no ;_;
where?
You should post a picture of it, I would try to do it with my ergo clears.
Offline trenzafeeds
  • **** off
« Reply #17 on: Mon, 07 December 2015, 07:52:03 »
https://geekhack.org/index.php?topic=74807.0
In there somewhere lol. Maybe if he comes back he will post the picture again, I don't really want to dig through the thread.
Offline ideus
  • Björkö.
« Reply #18 on: Mon, 07 December 2015, 07:53:11 »
I wanted you to help saving that time.
 :p
Offline Oobly
« Reply #19 on: Mon, 07 December 2015, 15:01:52 »
n-no ;_;
where?
https://geekhack.org/index.php?topic=74807.msg1902748#msg1902748
Smoothness seems unaffected and they seem to last (playing with a modified switch while watching movies, enjoying the sweet tactility of the Zealio), but I haven't tested long term yet since the board I'll be putting them on hasn't arrived yet.
Offline ideus
  • Björkö.
« Reply #20 on: Mon, 07 December 2015, 15:03:21 »
n-no ;_;
where?
Thank you.
Offline darkclone24
« Reply #21 on: Mon, 07 December 2015, 15:52:46 »
67g
I hope so!
