Author Topic: did i brick it?  (Read 3389 times)
Offline Jixr
did i brick it?
« on: Fri, 18 December 2015, 09:28:50 »
Hi all, one of my redscarfs is failing to connect to my computer ( and have tried two computers )
One works fine, the other isn't being found by windows, but I can boot it into its reflash mode to re-program the keyboard, but when plugged in normally, I got nothing.
Any ideas?
Re: did i brick it?
« Reply #1 on: Fri, 18 December 2015, 09:31:05 »
Any ideas?
Is it in PS2 mode? Is that a thing on the Red Scarf?
Offline dgneo
  • Supervillain
Re: did i brick it?
« Reply #2 on: Fri, 18 December 2015, 09:31:56 »
Any ideas?
Have no experience with a redscarf, but have you tried the reflashing guide here? https://geekhack.org/index.php?action=dlattach;topic=69282.0;attach=92536
Offline Jixr
Re: did i brick it?
« Reply #3 on: Fri, 18 December 2015, 09:34:58 »
I have no idea, I don't think there is a ps2 mode,
there isn't much info out there on these, and the pdf user guide is pretty poor english and doesn't cover much.
Offline Jixr
Re: did i brick it?
« Reply #4 on: Fri, 18 December 2015, 09:35:47 »
I don't know where to find the hex file to reflash the whole unit.
I've never seen it posted anywhere.
Offline dgneo
  • Supervillain
Re: did i brick it?
« Reply #5 on: Fri, 18 December 2015, 09:38:50 »
The guide I posted has all the information, it sounds like you'll wanna try #3, the Online Reflash, as that can provide the .hex to you as well.
Offline jaffers
Re: did i brick it?
« Reply #6 on: Fri, 18 December 2015, 09:45:38 »
its dead, just send it to me.
reflash usually fix, you cant truely 'brick' a device if you are determined enough
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: did i brick it?
« Reply #7 on: Fri, 18 December 2015, 10:12:22 »
I had trouble with mine. It is very picky. what are you using for the file when you reflash it?
Offline Jixr
Re: did i brick it?
« Reply #8 on: Fri, 18 December 2015, 10:23:17 »
i've been using the offline mode, and now trying to figue it out, I can't get my other one to work, and i havent done anything.
I'd like to try the online reflash, but I can't get the online version to find the keyboard.
and I can't get etiher one to go into reflash mode
Offline dgneo
  • Supervillain
Re: did i brick it?
« Reply #9 on: Fri, 18 December 2015, 10:24:10 »
i've been using the offline mode, and now trying to figue it out, I can't get my other one to work.
Did you go through the steps regarding Java? If you're not using IE, you may need to for this, as Chrome/FF dislike Java now.
Offline Jixr
Re: did i brick it?
« Reply #10 on: Fri, 18 December 2015, 10:42:21 »
i've done all that, and cant get online to work, and can't get offline to work either.
Not sure what the hell is going on with these things.
I've tried reflashing the eep several times, but can't get it to stick. The printer shows up, its clear of any documents in its queue, and no dice.
Offline 1391406
Re: did i brick it?
« Reply #11 on: Fri, 18 December 2015, 11:00:17 »
This is just a suggestion, but have you tried connecting either keyboard to a different PC?
Offline Jixr
Re: did i brick it?
« Reply #12 on: Fri, 18 December 2015, 11:12:58 »
yes.
Offline Jixr
Re: did i brick it?
« Reply #13 on: Fri, 18 December 2015, 20:43:15 »
anyone familiar with TKG and hex files?
From what I understand, I want to reflash the hex file to reset the keyboard, but am unable to with the tool.
