Author Topic: Which Model M would you choose?  (Read 3376 times)
Offline bopdiddy
« on: Fri, 20 November 2009, 21:17:06 »
I have two Model Ms and plan to give one to a friend.  The question is which one?
An older, 87 Mexican.  More loved, but still a nice keyboard:
Or a newer, 93 American.  Drainage holes, louder and cleaner:
I like 'em both (but man, the spacebar on the 93 is loud!).
Opinions?  Which has more or less cachet?
Offline ch_123
« Reply #1 on: Sat, 21 November 2009, 04:48:18 »
When you say  'more loved' do you mean that it's more worn out, or that you like it more than the newer one?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #2 on: Sat, 21 November 2009, 07:02:44 »
I wouldn't really mind the difference between them; I bet they both feel perfectly fine.
Offline Oqsy
« Reply #3 on: Sat, 21 November 2009, 14:11:19 »
I suggest you flip a coin...
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
« Reply #4 on: Sat, 21 November 2009, 14:22:50 »
I do the same too. (I've only given away stick rubber dome keyboards)
Offline bopdiddy
« Reply #5 on: Tue, 24 November 2009, 09:18:41 »
I meant "more loved" as "more worn out" and a bit less clean.  However the typing is a touch quieter and still feels fine, and the spacebar doesn't sound like a sledehammer.
In the end I basically tossed a coin and gave away the 87 and kept the 93.
Thanks for the advice, once again!
A
Offline ch_123
« Reply #6 on: Tue, 24 November 2009, 10:03:43 »
The 93 was probably the better keep considering that it has the drainage channels.
Offline ch_123
« Reply #7 on: Tue, 24 November 2009, 10:14:45 »
I'm pretty sure you could swap those labels around. Or even just swap the front covers... I think the old Black logo looks nicer anyway.
Offline ch_123
« Reply #8 on: Tue, 24 November 2009, 10:41:48 »
I really wouldn't be surprised at all if that was true...
Although I notice that he has double piece keycaps on all his 42H1292s, when alot of the ones on Clickykeyboards only have single piece ones. He probably just has a stack of keycaps from defunct boards that he puts on to working ones.
Offline ch_123
« Reply #9 on: Tue, 24 November 2009, 11:40:51 »
All I know is that when I order a keyboard from him, it gets here quick with no questions asked at the customs (he marks all overseas packages as gifts even if you don't ask)
