Author Topic: 1206 SMD LED question  (Read 4016 times)
Offline appleonama
  • Trollo en USA
« on: Thu, 31 December 2015, 12:19:51 »
Hey Guys
the 1206 SMD LED is a led that work on GON TKL v2 pcbs. I recently bought a gon from another user but the smd leds that are installed aren't bright enough for my liking.
my question is if there is another smd led that is very bright with the same dimensions as the 1206.
any info is appreciated thanks
Re: 1206 SMD LED question
« Reply #1 on: Thu, 31 December 2015, 12:40:47 »
You might want to try using a different resistor value to increase the brightness. Lesser resistance means more power to the leds
Offline appleonama
  • Trollo en USA
« Reply #2 on: Thu, 31 December 2015, 13:00:11 »
it has a 1330 resistor
wish i knew more about lights
well ill have to research I thought it was the led
« Last Edit: Thu, 31 December 2015, 13:02:53 by appleonama »
« Reply #3 on: Thu, 31 December 2015, 13:01:58 »
1330???
Thats really high, are you sure you don't mean 133 ohm? 133 is more normal and should be more brightness than you'd ever need.
Offline appleonama
  • Trollo en USA
« Reply #4 on: Thu, 31 December 2015, 13:03:17 »
1330???
broken img fixed here is what is has
sorry im a noob with this
I just noticed the solder is really shiny. They didn't let the solder flow enough
« Reply #5 on: Thu, 31 December 2015, 13:06:10 »
Okay yeah that's 133 ohms which is normal. That's strange then that they're not bright enough.
1206 is the correct size of smd led too. You might have just got a bad bunch?
Offline appleonama
  • Trollo en USA
« Reply #6 on: Thu, 31 December 2015, 13:10:55 »
It might just be me but they are no where near as bright as the 2x3x4 led that goes on the switch but then again it is a much bigger led.
I guess I can buy some smd led's from aliexpress theyre pretty cheap to test them out.
« Last Edit: Thu, 31 December 2015, 13:14:57 by appleonama »
Offline Steezus
  • Keeper of Facts
« Reply #7 on: Thu, 31 December 2015, 13:11:43 »
Is it me or is that SMD LED sideways? I would personally redo it completely show the light shines directly up.
Edit: I have never used a GON but I realized that it may be to direct the light towards the sides of the acrylic case, either way the soldering doesn't look too good.
« Last Edit: Thu, 31 December 2015, 13:14:25 by Steezus »
« Reply #8 on: Thu, 31 December 2015, 13:13:36 »
They're sideways because you want the light to be facing outwards to produce the underglow effect. They are not as bright as 2x3x4 but close. Have you manually maximized your light settings via nerdy Gui?
Offline appleonama
  • Trollo en USA
« Reply #9 on: Thu, 31 December 2015, 13:14:21 »
Looking at other GON builds it is pretty common to solder the smd sideways to make sure the light is reflecting towards the acrylic middle piece.
« Last Edit: Thu, 31 December 2015, 13:23:32 by appleonama »
Offline Steezus
  • Keeper of Facts
« Reply #10 on: Thu, 31 December 2015, 13:16:13 »
Yeah I just realized that after the fact, actually edited my post and then realized you commented as well haha. The resistors are definitely the right ones you need for SMD LEDs, it seems kind of odd that it's not that bright. Do you mind showing a pic with LED on?
Offline appleonama
  • Trollo en USA
« Reply #11 on: Thu, 31 December 2015, 13:16:49 »
now that I look at it closely you are right lol. I will redo the solder but I need some wick to remove that solder pretty hard to reach with a sucker.
« Reply #12 on: Thu, 31 December 2015, 13:18:57 »
You turned the brightness all the way up in the program right? Obvious question but just making sure.
Offline appleonama
  • Trollo en USA
« Reply #13 on: Thu, 31 December 2015, 13:21:45 »
yeah I made sure that the brightness was all the way up
Ill take picture to show the brightness
« Reply #14 on: Thu, 31 December 2015, 13:24:37 »
Hmm okay. Well yeah, might be a bad connection or could try different 1206 leds.
Offline appleonama
  • Trollo en USA
« Reply #15 on: Thu, 31 December 2015, 13:33:26 »
well my camera keeps picking up the light very but it is not this bright in person
I guess ill just try to buy more smd leds or maybe this is normal :^)
« Reply #16 on: Thu, 31 December 2015, 13:41:15 »
http://i.imgur.com/6WmBfbQ.jpg
Mine isn't particularly bright either but diffuses better.
Offline appleonama
  • Trollo en USA
« Reply #17 on: Thu, 31 December 2015, 13:52:33 »
that is very bright in a lit room
I can sell you my blue screws once I get my hyperfuse gmk I'm using TA temporarily. I want to but purple screws but I wonder how long that would take :(
