Author Topic: IBM Model M 1391401 Spacebar Rattle  (Read 3039 times)
Offline spanyam
  • Enjoy the gift of life!
« on: Fri, 08 January 2016, 14:46:31 »
I recently purchased a bolt-modded Model M that's clean and fully functional. The only minor gripe I have with it is that the space has a slight rattle to it (no wobble, just a minor rattle).
Video here:
The rattle persists even when fully pressed. Any way to reduce or remedy that?
SKCM Orange ALPS on Infinity 60% bent-metal case w/ hasu ALPS64 PCB and PBT blank DSA caps | KBP V60 w/ Matias Quiet Linears | IBM Model M | QFR w/ MX Blues
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM Model M 1391401 Spacebar Rattle
« Reply #1 on: Fri, 08 January 2016, 14:55:02 »
You're sure the stabilizer wire is seated correctly under the tabs?
« Reply #2 on: Fri, 08 January 2016, 15:19:17 »
That kind of thing is pretty typical. You can gently bend a slight bow into the wire, but I suggest you just live with it for a while. Also, I use a fairly thick grease in the mouth of the retaining tab, but that will not change the action too much.
- Franklin Roosevelt 1933
Offline spanyam
« Reply #3 on: Fri, 08 January 2016, 15:23:48 »
Yes definitely seated correctly. The stabilizer bar just slips in to the small slots under the ',' and 'c' keys rather than snapping in, but I'm not sure if the Model M's are designed that way.
Okay, that's fine. It's certainly livable with.
