Author Topic: [IC] The Amazing Chocolatier SA Keycap Set  (Read 223832 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« on: Tue, 16 February 2016, 11:38:42 »
This thread has been locked, GB thread here
GROUP BUY LINK
Background Story
Greetings to you, the lucky finder of this keyset, I shake you warmly by the hand! Many wonderful surprises await you! For now, I do invite you to come to my factory and be my guest for one whole day - you and all others who are lucky enough to find this set. I, Zambumon, will counduct you around the factory myself showing you everything that there is to see, and afterwards, when it is time to leave, you will be escorted home by a procession of SA keycaps.
Inpired by the 2005 motion picture adaptation of Roald Dahl's Charlie and the Chocolate Factory, The Amazing Chocolatier will take your keyboard into the most famous chocolate factory that has ever existed.
Although my idea was to make three of these variants (Blue, Red and Brown). It would be impossible and some novelties wouldn't look great. In addition: three variants means that base kits are huge since they have to contain the non-standard, winkles, etc mods.
So I opted just to do Whipple-Scrumptious Fudgemallow Delight since it was by far the most elegant of those 3.
Details
  • Designed by Zambumon
  • Manufactured by Signature Plastics
  • MX compatible (Cherry, Gateron, Kailh and Novatouch Sliders)
  • SA 1-1-2-3-4-3 Profile in thick ABS
  • Doubleshot legends
  • Semi-Matte finish
Child Deals
  • Base kit
  • Modifiers
  • Tsangan/Whitefox
  • Numpad
  • 40%
  • Ergodox
  • Dvorak & Colemak
  • UK
  • International
  • Novelties
  • Community
Child deals renders:
Render Gallery
FAQ
Does [insert a kit] include [insert a keycap]?
All kits include ***only*** the keys pictured.
I have an ISO board, which child deals would cover my board?
You'll need the base kit + the ISO kit (which includes an ISO enter and 1.25U R4 Shift) and **either the UK kit or the NorDe** child deal + any other additional kits (Numpad, Tsangan…).
Does ISO include UK keycaps?
No it doesn't.
Are the Corsair Strafe and Logitech G710 covered?
No, Signature Plastics doesn't manufacture 6.5U SA space bars.
Is this a Group Buy?
No, this is an **Interest Check**. Kits are not final.
Was Esteban bitten?
No, Estaban was chewed.
Special thanks to MiTo, livingspeedbump, T0mb3ry, Matt3o, HoffmanMyster, Steezus, ideus, Data, LeandreN, Trydan, and Ra.
« Last Edit: Wed, 03 August 2016, 10:51:46 by Zambumon »
Offline Zambumon
    • Keyset projects
Re: The Amazing Chocolatier SA Keycap Set
« Reply #1 on: Tue, 16 February 2016, 11:38:58 »
  • Feb 19: Added ISO ES
  • Mar 5: Added White Chocolate Renders to OP
Want to show your support for the set? You can place this in your signature to do it!
Guide:
1. Select and copy this code
Code: [Select]
[url=https://geekhack.org/index.php?topic=79722.0][img]http://i.imgur.com/CbYfwfX.jpg[/img][/url]
1. Go to the "Profile" tab
2. Press "Forum Profile"
3. Paste the code into the "Signature" box.
4. Press Save
« Last Edit: Sat, 05 March 2016, 08:51:21 by Zambumon »
Offline ironpup
  • Good feeling of oneness with cup rubber
« Reply #2 on: Tue, 16 February 2016, 11:42:20 »
This looks awesome, great work man  :thumb:
Offline 64rky
« Reply #3 on: Tue, 16 February 2016, 11:46:51 »
A lot of effort has gone into this!  Looks amazing!
Offline neverused
« Reply #4 on: Tue, 16 February 2016, 11:47:25 »
Looks great, nice retro vibe. I will say that it does seem odd that CTRL is the only modifier not spelled out.
Offline FLFisherman
  • I'd rather be fishing.
« Reply #5 on: Tue, 16 February 2016, 11:50:05 »
What do you mean? Isn't that always the case? "Alt" isn't spelt out, either.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #6 on: Tue, 16 February 2016, 11:51:22 »
Looks pretty damn good so far! Novelties are always what really does it for me through, so maybe add some more? I'm just not sure what.
Offline Zambumon
    • Keyset projects
« Reply #7 on: Tue, 16 February 2016, 11:51:35 »
I opted for the standard way. The only place where you can read "Control" is on the caps lock replacement keycap.
Offline neverused
« Reply #8 on: Tue, 16 February 2016, 11:52:32 »
Perhaps, but look above and you'll see a Function key, usually I see Fn. That sort of pushes the modifiers over to being spelled out at that point. Also Alt could stand alone as just alt rather than alternate but either way I think this is a very nice looking set.
« Reply #9 on: Tue, 16 February 2016, 11:53:13 »
Scrumpdillyicious.
Offline neverused
« Reply #10 on: Tue, 16 February 2016, 11:53:14 »
That's fair, just pointing it out. I did not mean it as a criticism.
Offline Zambumon
    • Keyset projects
« Reply #11 on: Tue, 16 February 2016, 11:53:15 »
Twice in a row (here and GC) you were the first one to show your appreciation for my work.
Thanks you very much!
Offline Baddy126
« Reply #12 on: Tue, 16 February 2016, 11:53:19 »
That golden ticket key... I must have it...
Offline DannyHuynh
« Reply #13 on: Tue, 16 February 2016, 11:54:15 »
I have always wondering what the SA profile keycaps look similar to. Now I know, they look like candy/chocolate, confirmed by this design
Offline Jolikki
« Reply #14 on: Tue, 16 February 2016, 11:59:44 »
Wow, that's beautiful! The only thing I'd like changed is the dots and rings on ÅÄÖÜ and so on. They should be a little bit bigger :)
"I would stand in line for this" - Moby
Offline Zambumon
    • Keyset projects
« Reply #15 on: Tue, 16 February 2016, 11:59:58 »
I have compared the TGH color chip (alphas) with Lindt Chocolate and they look exactly the same.
Offline Zambumon
    • Keyset projects
« Reply #16 on: Tue, 16 February 2016, 12:02:20 »
That's a render issue, so you shouldn't worry about it since the set would use Signature Plastic's standard font.
I'll fix those legends tomorrow
Offline xondat
  • i'm not a star
« Reply #17 on: Tue, 16 February 2016, 12:05:49 »
Lot's of effort has gone into this - not my piece of cake but I'm sure this will get to the GB phase soon.
Offline calvinhousecat
« Reply #18 on: Tue, 16 February 2016, 12:17:46 »
Love this concept
Offline DannyHuynh
« Reply #19 on: Tue, 16 February 2016, 12:32:08 »
Dammit I know I am going to have chocolate for lunch now, thank you!  :mad: And you have to wait until Valentine is over to post this. Was it intentional ?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #20 on: Tue, 16 February 2016, 12:38:30 »
WOO! Finally. This set looks great.
Offline Zambumon
    • Keyset projects
« Reply #21 on: Tue, 16 February 2016, 12:42:41 »
It wasn't intentional, today I didn't have classes and finally got some time to write the IC posts.
Even though I'd like to have this set done as soon as I could, it would be the best not to rush since the IC will solve some issues that I haven't noticed.
Offline torafuma
« Reply #22 on: Tue, 16 February 2016, 12:49:38 »
Wow! This set looks amazing! Love the colors as well. Would there be an option for another color for the Glass Elevator cap?
White is really nice, but that Golden Ticket yellow is amazing! Would make an amazing Escape key, for us vim users.  ;D
Offline xondat
  • i'm not a star
« Reply #23 on: Tue, 16 February 2016, 12:51:35 »
There aren't many faults at all, that's what I meant.
Offline popkorn62
  • No keyboards for old men
    • Mekibo
« Reply #24 on: Tue, 16 February 2016, 12:56:47 »
Yes yes yes
https://mekibo.com/
Offline bbrotha
« Reply #25 on: Tue, 16 February 2016, 13:30:41 »
Great looking set, and the amount of renders is just perfect.
Norbaforce 87U 45g  -- HHKB Type S Blanks-- Kira Keyboard -- M65-A -- Novatouch
Offline thaddeus
« Reply #26 on: Tue, 16 February 2016, 14:35:17 »
Interested :)
Offline MikeTheTiger
« Reply #27 on: Tue, 16 February 2016, 14:41:14 »
Damn...another set I need!!
"all the numbers or none of them cmon man" -Kokaloo
Offline Zambumon
    • Keyset projects
« Reply #28 on: Tue, 16 February 2016, 14:54:28 »
I thought about instead of having those R1 W in different colors, I could add a red Elevator, for instance.
Planck render:
Offline DannyHuynh
« Reply #29 on: Tue, 16 February 2016, 15:23:57 »
I suppose there's no way to get white chocolate if even if I want, right?  :-[
Offline Kirfloof
« Reply #30 on: Tue, 16 February 2016, 15:36:01 »
I like this a lot, been after a dual tone brown & cream set for a while.
Retro came close.
Something higher quality than the OEM coffee set that was recently done as it's the closeness to coffee in theme that's the draw for me.
Offline Zambumon
    • Keyset projects
« Reply #31 on: Tue, 16 February 2016, 15:42:40 »
I've been trying to figure out a good color way to make the white chocolate alphas. When I figure everything out, I'll add it to the IC and the webpage.
Offline Malenky
« Reply #32 on: Tue, 16 February 2016, 17:58:56 »
I would absolutely love to own this. Actually hoping the interest check/group buy phase takes a while so that my wallet has time to recover from previous group buys.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #33 on: Tue, 16 February 2016, 19:44:02 »
Golden Ticket! :))
Great theme on this one.
Do you plan on having a single Tsangan kit?
Offline MiTo
  • にんたい
« Reply #34 on: Tue, 16 February 2016, 19:54:22 »
Was Esteban bitten?
¿Ellos estaban a hacer buceo?
Let me tell you about my boat.
Offline Jumie
« Reply #35 on: Tue, 16 February 2016, 20:03:08 »
OMG... This is so beautylicious... I can't stop staring all those amazing renders. Why not include the R3 Function key in the base set ala pulse?
« Last Edit: Tue, 16 February 2016, 20:11:20 by Jumie »
Offline 1deeg
« Reply #36 on: Tue, 16 February 2016, 20:03:32 »
Another SA set :confused:
Looks good though, I would get it if not SA
Offline pr0ximity
« Reply #37 on: Tue, 16 February 2016, 20:37:10 »
Don't know that I could support a GB themed after the 2005 movie rather than the 1971 version :P
« Reply #38 on: Tue, 16 February 2016, 20:39:26 »
Right?! The Burton version was so much better.
Offline njbair
    • nickbair.net
« Reply #39 on: Tue, 16 February 2016, 20:47:30 »
Hey can we get an [IC] in the OP subject line? Makes it easier to browse through Unread, and it's the rules. Thanks.
My boards:
Offline Zambumon
    • Keyset projects
« Reply #40 on: Wed, 17 February 2016, 03:47:49 »
Thanks for pointing that, already fixed.
Roald Dahl hated the 1971 version and it took Warner Bros 15 years to get the film done since Dahl's heirs had to approve the direction, script, and even the cast.
It is offered on a child deal called "Extras" which also includes stepped keycaps and homing bumps!
Offline ntitco1
« Reply #41 on: Wed, 17 February 2016, 06:15:08 »
Doesnt the letters color already match white chocolate?
I has been lurking over the brown set IC of jil for a while seeing no progress. Super excited to see this  :-* Thanks for the nice work
Re: [IC] The Amazing Chocolatier SA Keycap Set
« Reply #42 on: Wed, 17 February 2016, 08:29:00 »
I'm confused. It took them 15 years to make the Burton version?
Offline Zambumon
    • Keyset projects
« Reply #43 on: Wed, 17 February 2016, 11:26:47 »
The project was started in 1991, multiple directors were considered for the film as well an actors such as Bill Murray, Nicolas Cage, Jim Carrey, Michael Keaton, Brad Pitt, Will Smith and even Adam Sandler where considered for the role of Willy Wonka.
« Reply #44 on: Wed, 17 February 2016, 11:31:52 »
Holy wow.
Well, I liked the result. Sure, there were some unnecessary additions (Wonka's father, the perverted jokes), but overall I think it was much better than the original film. It followed the book more closely, albeit modernizing some aspects--the songs used the lyrics right from the book, and even the title of the film is correct.
I've had many arguments with older people regarding the two films, who've said the recent film is not as good as the original, and when I asked if they read the book they'd say "no."
Offline My_Thoughts
« Reply #45 on: Wed, 17 February 2016, 12:15:21 »
I love this set and looking forward to getting it.  My only key comment would be, would you consider offering the Alt Gr in the ISO base set?   Some sets do and others don't.
Offline Jedi
« Reply #46 on: Wed, 17 February 2016, 13:13:37 »
What color chip are we going with for Brown?  Hoping for TGH.
The SA Retro was WCK letters on TBN (I think).  TGH will keep my boards looking unique
:thumb:
« Last Edit: Wed, 17 February 2016, 13:27:53 by cswanic »
Offline ntitco1
« Reply #47 on: Wed, 17 February 2016, 15:14:57 »
Since space bars are included in planck and ergodox kits can you put a 7u space bar in tsangan kit also?
Offline Zambumon
    • Keyset projects
« Reply #48 on: Wed, 17 February 2016, 17:16:34 »
Well, the International and UK kits doesn't include the Alt Gr legends, so it wouldn't make much sense to include one.
:thumb:
Alphas are TGH with TM legends, modifiers TBN with WCK legends (TM legends didn't look good on them).
I think that space bars should have their own child deal.
« Last Edit: Wed, 17 February 2016, 17:22:30 by Zambumon »
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #49 on: Thu, 18 February 2016, 01:35:40 »
Beautiful renders, absolutely lovely.
