Author Topic: [IC] Phantom Skeleton Kit  (Read 49233 times)
Offline asura
  • not a duck
Re: [IC] Phantom Skeleton Kit
« Reply #50 on: Sun, 17 January 2016, 05:37:55 »
you could just order plates if thats all you need
Please.
Which plates are you planning on producing?
Offline afonsoocosta
« Reply #51 on: Sun, 17 January 2016, 08:32:51 »
Can I only ask for 1 plate? The top? I want a wood case with a metal/aluminum plate on the top, and the plate is like you have :p how i put only the top plate on the IC?
I want the top Plate, the PCB the Teensy 2.0 Controller, the diodes and the LED's for Caps... The switchs depends the price of them...
Thanks and I hope the GB runs
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #52 on: Sun, 17 January 2016, 09:59:54 »
I'd be interested.
[WTB] HHKB Black
Offline roostrc0gburn
  • its just plastic
« Reply #53 on: Sun, 17 January 2016, 11:19:23 »
Please.
Working on a render this week, but see JDCarpe's photos for reference for now.
Thanks for the interest :-) plates will be sold in sets - top and bottom. If you haven't already, please fill out the form linked in OP
  • its just plastic
« Reply #54 on: Sun, 17 January 2016, 11:22:49 »
Submitted IC!
Thanks! Input from the forms will set prices when this goes to group buy.
  • its just plastic
« Reply #55 on: Wed, 20 January 2016, 12:03:53 »
so far, we only have 14 orders + mine. this is probably enough to do the plates, but not enough orders to really get a price break on anything else.
Offline asura
  • not a duck
« Reply #56 on: Wed, 20 January 2016, 12:54:45 »
Please.
ANSI 1.25
ANSI 1.5
ISO 1.25
ISO 1.5
7BIT
PROF 1.25
PROF 1.5
I was part of the round 2 buy, and have everything except my plate* - a PROF 1.5.  I keep meaning to get one made (or a unique layout which I'd prefer even more) however, crap keeps getting in the way.
*having only ordered the plate and PCB half my order just vanished into...
  • its just plastic
« Reply #57 on: Wed, 27 January 2016, 17:18:23 »
FYI erybody.
I'll leave this IC up for the rest of the week and probably post to reddit to see if there's any more interest over there. From the feedback so far, looks like we're doing just plates. Group Buy will start early Feb. I still have some stuff to do to set up before we can run
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #58 on: Wed, 27 January 2016, 20:35:06 »
Just plates? Welp, count me out.
  • its just plastic
« Reply #59 on: Fri, 29 January 2016, 01:27:44 »
so... 14 plates
Offline asura
  • not a duck
« Reply #60 on: Fri, 29 January 2016, 15:19:24 »
I'm interested in one, and maybe a base plate, but not knowing what styles you plan on producing don't feel it would be fair to put my name down as a yes - only to turn to rescind at a later date if you're not producing the layout I want.
  • its just plastic
« Reply #61 on: Fri, 29 January 2016, 15:33:57 »
you're right - i never did specify. sorry! as of right now, I have developed a CAD file for standard ANSI layout. I modified it slightly to have a winkeyless plate made also. Other layouts are possible, but probably outside the scope of this little group buy. PM me if you want something else made. we might be able to do it
Offline Dernubenfrieken
« Reply #62 on: Fri, 29 January 2016, 16:05:03 »
I'm only really interested if there's baseplates/standoffs included. A non universal plate is actually preferred for me.
  • its just plastic
« Reply #63 on: Fri, 29 January 2016, 16:49:41 »
If you're okay with Costar, they are very inexpensive from WASD.
Doesn't Zeal have stabilisers in his store? Maybe only worth it if you are buying Zealios because of the shipping cost.
Will this need standoffs for the LEDs?
yes, plates must be orders in sets - top and bottom. you can easily source standoffs and screws yourself from McMaster Carr.
« Last Edit: Tue, 01 March 2016, 00:43:51 by roostrc0gburn »
« Reply #64 on: Fri, 29 January 2016, 21:52:48 »
yes, plates must be orders in sets - top and bottom. you can easily source standoffs and screws yourself from McMaster Carr. Here's links to what I will use:
Standoffs: http://www.mcmaster.com/mv1453753815/#91125a613/=10wbq69
Screws: http://www.mcmaster.com/mv1453753815/#90910a710/=10wbq8f
That sounds perfect then.
Offline ehwc
« Reply #65 on: Mon, 01 February 2016, 17:59:56 »
I hadn't checked on that Deskthority thread in a white because I was so annoyed with the "resolution" of that GB, haha. Glad to hear you're still looking to produce the plates! In for one :thumb:
A question on the standoffs and screws for whoever has experience to answer this: a 1/2 inch standoff like this should be enough clearance, correct? Also, would a GON-style countersink screw link this sit relatively flush to the hole, or would I have to look for a screw that's much smaller and has a head that's just larger than the holes on the plate? And if the latter, I guess my question is then how large are the holes for the screws on the plate?
Thanks in advance!
  • its just plastic
« Reply #66 on: Mon, 01 February 2016, 18:19:53 »
Thanks in advance!
bolt holes are 0.0650" (1/16 = 0.0625) Holes will not be countersunk. Your standoffs are fine. I suggested some hardware earlier in the thread. When this goes to GB I will be sure to list all the (suggested) parts, where to get them, and how much they cost.
Offline ehwc
« Reply #67 on: Mon, 01 February 2016, 18:21:44 »
Thanks in advance!
  • its just plastic
« Reply #68 on: Sat, 06 February 2016, 21:14:02 »
update bump. check OP
« Reply #69 on: Sun, 07 February 2016, 13:12:05 »
Not a fan of winkeyless myself. Probably would only buy if its standard ansi.
Offline tuco
« Reply #70 on: Sun, 07 February 2016, 14:16:51 »
Me too.
  • its just plastic
« Reply #71 on: Sun, 07 February 2016, 16:54:33 »
roger that. i think i will be able to make both layouts available in either stainless or aluminum
Offline TalkingTree
    • My projects
« Reply #72 on: Mon, 08 February 2016, 05:19:37 »
The strike out on PCB and controller means that they won't available in the GB anymore?
  • its just plastic
« Reply #73 on: Wed, 10 February 2016, 14:19:02 »
i crossed them out with the assumption that we dont have enough people to get a significant discount on those items. I am currently trying to determine if we can get a complete set in the ~ $100-$120 range before starting the Group Buy phase, so this could change.
small update, GB will be starting in a couple weeks. the delay is mainly due to chinese new year
Offline TurtleHat
« Reply #74 on: Wed, 10 February 2016, 16:44:32 »
I'm interested in an ANSIWIN Phantom plate, but it doesn't look like that's on the table here. Maybe if there's a future group buy.
Offline axtran
« Reply #75 on: Thu, 11 February 2016, 22:44:08 »
I recommend considering JD's offer as he can help with plates to meet International layouts too (if desired).
MX Silent > MX Vintage Black > Everything Else
  • its just plastic
« Reply #76 on: Thu, 11 February 2016, 23:03:31 »
yes, a good suggestion. i wanted to keep this simple in the beginning, but perhaps offering multiple layouts could gain interest. i dont know if multiple patterns will add complexity (price) to the order, or if it even matters.
since we'll be stuck in IC for a couple more weeks, i will put up a poll for multiple layouts. can i get suggestions?
Offline axtran
« Reply #77 on: Thu, 11 February 2016, 23:15:49 »
I honestly think you'll need four major ones--ANSI 1.25, ANSI 1.5 WKL, ISO 1.25 and ISO 1.5 WKL.
Offline skiwithpete
« Reply #78 on: Sat, 13 February 2016, 19:46:26 »
I'm in for one of these BTW.
Please let me know if this is going to happen.
P
Co-Founder of 1upkeyboards.com
QFR Brown + PokerII Clear
  • its just plastic
« Reply #79 on: Sat, 13 February 2016, 21:55:25 »
P
definitely going to happen - just a question of when (after chinese new year), what all people want, and what we can get
Offline mrging
« Reply #80 on: Sun, 14 February 2016, 12:00:07 »
i'm in , cant wait to see this GB happen
  • its just plastic
« Reply #81 on: Sun, 14 February 2016, 12:34:04 »
@jdcarpe,  sent you a PM on this.
Offline kebby
« Reply #82 on: Tue, 16 February 2016, 07:45:09 »
I hope you could consider including the 7BIT plate as an option. I'd go for even multiple if that helps the case. Being able to get a split space is so rare and the Phantom would offer it but not being able to get the plates anywhere keeps me from building one.
  • its just plastic
« Reply #83 on: Tue, 16 February 2016, 16:46:29 »
If you (or JD) have a CAD file for the layout, it would be pretty easy. I talked to the plate fab shop agian today to confirm prices and lead times. they can do pretty much any TKL layout we want (within reason) for the same price. they can also do aluminum and have some basic finishing capabilities. I am not familiar with the 7BIT layout, so please enlighten me
OP has been updated
Offline kebby
« Reply #84 on: Tue, 16 February 2016, 19:34:50 »
OP has been updated
Looks like you could get the CAD files for it and some other Phantom plates here:
https://geekhack.org/index.php?topic=47744
The default variant is shown here https://deskthority.net/wiki/Phantom and there's also a download for some CAD files but it looks like it's a less complete archive.
Offline mrging
« Reply #85 on: Fri, 19 February 2016, 07:31:52 »
Which better? steel or aluminum?
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #86 on: Fri, 19 February 2016, 07:33:20 »
steel is harder but aluminum wont rust  but you can paint either or anodize them. so it could be a toss up.
aluminum is softer and is faster/easier to machine out if your using a CNC.
just depends on the manufacturing or your requirements for the part.
Projects
  • its just plastic
« Reply #87 on: Fri, 19 February 2016, 11:58:06 »
these are all great points, but let me add some perspective - these parts will all be lazered, so material type is almost moot. stainless steel will be heavier and more rigid, which is better for linear switches. aluminum has a bit of flex, which is better for tactile or clicky switches. The aluminum plates available will not be anodized. aluminum will oxidize, but at a very slow rate. nevertheless, i would still suggest that people who select an aluminum plate provide some layer of protection - anodizing or painting. the steel plates will be stainless #304, so oxidization is not an issue.
Offline mrbishop
  • Evil Genius
« Reply #88 on: Fri, 19 February 2016, 12:02:15 »
 :thumb:
Projects
Offline mrging
« Reply #89 on: Sun, 21 February 2016, 10:00:51 »
hmmm nice, but how about shipping? shipping to vietnam cost how much ?
Offline braidn
« Reply #90 on: Sun, 21 February 2016, 12:45:10 »
Hmm, if there was a 7bit option thrown in here, especially with WKL... I might have to be in.
Offline mrging
« Reply #91 on: Mon, 22 February 2016, 04:52:58 »
hmm.. what is ansi 1.25 and 1.5 diff? bottom row?
Offline kenshinjeff
« Reply #92 on: Mon, 22 February 2016, 22:32:54 »
Filled up the form : )
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #93 on: Mon, 22 February 2016, 23:48:42 »
+1
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
  • its just plastic
« Reply #94 on: Tue, 23 February 2016, 18:50:07 »
Update Bump!
you wanted layouts? You got layouts! OP updated. Also, it might again be possible to offer kits for a full keyboard! all parts included! i'm psyched on this
it's happening, guys!
  • its just plastic
« Reply #95 on: Thu, 25 February 2016, 15:17:17 »
update bump. OP updated
we will now have all the parts needed to build the keyboard available in the group buy - except stabilizers. if anyone knows of a source, please PM me. even if they are not included in the group buy, i would like to be able to point people in the right direction to find all the parts to build the board.
still finishing up a couple things. it has been my goal to start the GB this week, but that may be a little rushed. I will try for this weekend, but if not - next week is looking pretty doable.
Thanks everyone!
Offline TalkingTree
    • My projects
« Reply #96 on: Thu, 25 February 2016, 15:30:40 »
Is anyone proxying in Europe?
  • its just plastic
« Reply #97 on: Thu, 25 February 2016, 15:54:20 »
i haven't heard anyone volunteer, but i bet there are a couple people we could ask...
Offline mark_thaddeus
« Reply #98 on: Thu, 25 February 2016, 21:47:04 »
I'm interested and did the survey!
Offline s3vv4
« Reply #99 on: Fri, 26 February 2016, 08:16:24 »
Does the Phantom PCB need diodes? I thought you only need those when you do manual wiring in the form of a matrix.
