Author Topic: **Update 2-6** [IC] GMK CMYK 6.25u and 7u spacebars  (Read 23871 times)
Offline tigersharkdude
« on: Sun, 17 January 2016, 08:43:58 »
Update 2/6
Do note that GMK has told me that there is a MOQ of 150 for each color and size.
POLL - please vote only ONCE
https://docs.google.com/forms/d/13oL47btr-4pvCyBdHfTKCM-jmZEFCSchdoBTpNEG1kw/edit?usp=forms_home
Update Jan 20
Had an idea last night.
Have you guys/gals seen JDCARPE'S buy where he is doing a single color GH key each month? The key comes in a pack of 2; one mx and one alps.
I had the thought to do a similar buy with bars. A single color monthly or every 2 months, packs would be 2 bars; one 6.25u and one 7u.
Thoughts?
Hello all, Im wanting to see if there is enough interest to try get a Group Buy going for some GMK spacebars.
Wanting to do a CMYK pack in 6.25u, if the interest is there either buy #1 will also include 7u OR there will be a second buy after 6.25u for the 7u bars.
If you are interested, please post below and list which pack you would be interested in.
GMK color codes would be ;
  • Cyan - UN6037
  • Magenta - UN33656 (afaik)
  • Yellow - N6
  • Black - N9 or CR
« Last Edit: Sat, 06 February 2016, 09:46:30 by tigersharkdude »
Offline TalkingTree
    • My projects
Re: [IC] GMK CMYRGB 6.25 Spacebars
« Reply #1 on: Sun, 17 January 2016, 09:01:02 »
Interested in CMYRGB. What material anyway?
Offline joey
« Reply #2 on: Sun, 17 January 2016, 09:02:23 »
Good luck with the IC/GB tigersharkdude!
Doesn't GMK only do ABS?
Offline whmeltonjr
« Reply #3 on: Sun, 17 January 2016, 09:04:14 »
I'm down for either one
Offline Dernubenfrieken
« Reply #4 on: Sun, 17 January 2016, 09:05:52 »
Would be interested in the CMYRGB, would be even more interested if it were RGBY without the CM.
Offline VinnyCordeiro
« Reply #5 on: Sun, 17 January 2016, 09:05:52 »
First of all: a picture with the standard colors used by GMK
124643-0
Now you need to define the ones that going to be used.
My suggestions (which are not perfect):
  • Cyan: UN6037
  • Magenta: UN5045 (I think this is the code, it isn't very much legible)
  • Yellow: N6
  • Red: V1
  • Green: N7
  • Blue: V4
From this list, I don't like the cyan. It isn't really cyan, more like a light blue. You can try finding a custom plastic for that color. Intelli78 bought lots of plastic Pantone® chips before choosing the colors used on TA keyset.
Offline HannahPeach
« Reply #6 on: Sun, 17 January 2016, 09:10:22 »
What about pricing?
« Reply #7 on: Sun, 17 January 2016, 09:14:12 »
CM is a definite for this guy, they are the sole reason for starting this IC
What about pricing?
This is just an interest check to see if its even worth contacting them. I dont want to waste their time with getting all of the info, only for the IC to never get off of the ground
« Last Edit: Sun, 17 January 2016, 09:16:04 by tigersharkdude »
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #8 on: Sun, 17 January 2016, 09:23:16 »
M is supposed to be magenta, not purple. Just want to point out that that makes it a CPY set.
Offline user 18
« Reply #9 on: Sun, 17 January 2016, 09:25:18 »
Would this be a buy for 6.25 bars only, or 6.25 and 7u bars?
Avatar by ashdenej
« Reply #10 on: Sun, 17 January 2016, 09:29:53 »
6.25, if the interest is there I will ask about 7u bars
Offline user 18
Re: [IC] MX GMK CMYRGB 6.25 Spacebars
« Reply #11 on: Sun, 17 January 2016, 09:33:26 »
Interested depending on price. More interested in CMY than RGB.
I'd personally only be interested in 6.25u.
Avatar by ashdenej
Re: [IC] MX GMK CMY and/or CMYRGB 6.25 Spacebars
« Reply #12 on: Sun, 17 January 2016, 09:35:16 »
same on both. I only added RGB for those that want that option.
Offline 64rky
Re: MX GMK CMY and/or CMYRGB 6.25 Spacebars
« Reply #13 on: Sun, 17 January 2016, 10:12:22 »
Down for either
Offline 1deeg
« Reply #14 on: Sun, 17 January 2016, 10:45:10 »
Same. But I might want a red one too. So I'll buy a 6 piece CMYRGB kit if that ends up being that way.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #15 on: Sun, 17 January 2016, 11:13:02 »
I love small simple GBs. I'm in! Would like a lime one too.
Offline lolpes
« Reply #16 on: Sun, 17 January 2016, 11:23:12 »
Could you add eletric blue and black? those are some of the spacebars I would be very interested in seeing, aside from joining the current lineup of spacebars ;)
Offline roostrc0gburn
  • its just plastic
« Reply #17 on: Sun, 17 January 2016, 11:26:30 »
I am definitely in for a set. Please inquire about non-standard stem patterns. I would love to use these on my FC660M
« Reply #18 on: Sun, 17 January 2016, 11:38:22 »
When Christoph gets back to me I will ask.
I dont want to go over board with options, since this is my first try at a GB, so maybe I could do a CMY kit and then a kit with various colors?
« Reply #19 on: Sun, 17 January 2016, 13:37:28 »
Yeah thats fine, I'm OK with getting more spacebars, but those spacebars are going to be shipped with Miami Nights, although that GB has dragged out at this point.
« Reply #20 on: Sun, 17 January 2016, 13:45:16 »
Not everyone is in that GB though. If I could've ordered just the bars I would've
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #21 on: Sun, 17 January 2016, 17:06:31 »
I apologize if I miss-spoke. I was looking at this on my phone earlier and the outside lightning might have messed with the colors.
« Reply #22 on: Sun, 17 January 2016, 17:50:57 »
Its all good. I just selected the color off of a picture, didn't notice that it was off so much.
I changed the pics in the op after you posted
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #23 on: Sun, 17 January 2016, 18:50:42 »
Ahh. I thought I was going crazy because I definitely remembered purple =P
« Reply #24 on: Sun, 17 January 2016, 20:01:56 »
Interested, depending on price and time frame.
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #25 on: Sun, 17 January 2016, 20:54:17 »
This is cool. You should throw in the purple too.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #26 on: Sun, 17 January 2016, 21:06:22 »
I agree with this!
« Reply #27 on: Sun, 17 January 2016, 21:25:55 »
 CMYRGBPOBWG ... lol
Offline DukeMugen
  • +1
« Reply #28 on: Sun, 17 January 2016, 21:37:57 »
IN!!!! i CMYRGB plus purple! CMYRGBP!!!!  ;D
let me check my wallet.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #29 on: Sun, 17 January 2016, 21:44:29 »
While we're at it, we should add black & white... CMYRGBPKW =]
« Reply #30 on: Sun, 17 January 2016, 21:46:03 »
You forgot Orange and Grey
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #31 on: Sun, 17 January 2016, 22:11:32 »
Alright, so we're up to 11. That's not too bad, right?
Offline DukeMugen
  • +1
« Reply #32 on: Sun, 17 January 2016, 22:23:46 »
CMYRGBPKWOG  :))
Offline jerue
  • (Whenever that happens :P)
« Reply #33 on: Sun, 17 January 2016, 23:05:37 »
7u CMY and hopefully Purple!
« Reply #34 on: Sun, 17 January 2016, 23:13:26 »
Or maybe an option for an Ultra Space Bar Pack: all the colors!
I've already ordered all space bars in 6.25u from Ivan's Miami Nights GB, but I'd be down for this as well, especially for 7u bars as I didn't order any of those.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #35 on: Sun, 17 January 2016, 23:14:42 »
Interested in 7U so I'll watch this & see if that happens :)
Offline jaffers
« Reply #36 on: Sun, 17 January 2016, 23:20:34 »
I'd be interested in CMY with 7u and 6.25u spacebars
I'd also be interested in this colour
124782-0
« Last Edit: Sun, 17 January 2016, 23:23:20 by jaffers »
Offline lashiel
« Reply #38 on: Mon, 18 January 2016, 01:30:56 »
Interested.
Offline TalkingTree
    • My projects
« Reply #39 on: Mon, 18 January 2016, 03:46:43 »
If 7u happens I'll be interested in a CMYRGB set as well.
Offline swimmingbird
  • keyset hoarder
« Reply #40 on: Mon, 18 January 2016, 05:10:18 »
Even though I got in on Miami Nights and bought a bunch of spacebars there I would probably buy some of these as well
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #41 on: Mon, 18 January 2016, 06:08:59 »
Down 4 both
 Mostly interested in 7u
« Last Edit: Mon, 18 January 2016, 06:10:42 by cooldiscretion »
« Reply #42 on: Mon, 18 January 2016, 08:22:26 »
Will ask gmk about 7u and an 'ultra pack' when they reply
Offline DukeMugen
  • +1
« Reply #43 on: Mon, 18 January 2016, 10:41:23 »
ULTRA PAAACK! Yeeeaaaah! Love it!
Offline Alex92
« Reply #44 on: Mon, 18 January 2016, 10:58:49 »
I'd be interested in lime green (AE), but it looks like there might be too many colors already  :))
Perhaps you should make a poll and the top color choices get put into the ultra pack.
Offline LXXXIX
« Reply #45 on: Mon, 18 January 2016, 11:04:51 »
Ultra pack, ultra pack, ultra pack!
« Reply #46 on: Mon, 18 January 2016, 11:57:16 »
Ultra pack shall be 20 bars ... lol
« Reply #47 on: Mon, 18 January 2016, 12:14:10 »
Aww yiss!!
How much will that be? $100?
« Reply #48 on: Mon, 18 January 2016, 12:20:58 »
Aww yiss!!
Who knows. Once gmk gets back to me I'll post up.
I won't be making any money off of this. Price will be
Cost + Paypal fees + shipping (actual shipping + materials)
Offline lashiel
« Reply #49 on: Mon, 18 January 2016, 16:10:50 »
I'd definitely be interested in the Ultra Pack.
Probably normal CMY too, but definitely an ultra pack.
